Please help, opinions requested
Discussion in '5th Gen 4Runners (2010-2024)' started by Higgbra73, Dec 9, 2023.
  1. Dec 9, 2023 at 11:38 AM
    Higgbra73
    Higgbra73 [OP] Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Do these look the same or different?!
  2. Dec 9, 2023 at 11:39 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Oops..,, photo didn’t post
  3. Dec 9, 2023 at 1:06 PM
    Is the one on the right taller?
    If so, it probably goes on the drivers side to compensate for drivers side lean.
    raimieb and 2Toys like this.
  4. Dec 9, 2023 at 1:36 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Odd the one on the right doesn't appear to have the same coiling even if it is for the right side?
  5. Dec 9, 2023 at 1:56 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Right!!! I didn’t notice it before installing… the one on the right is sitting 1” lower (installed on driver side…. Even after trying to adjust for lean by moving circ clip to .85…. Still leans 1”. Dobinsons in Florida is wanting me to purchase another set, send the other back and wait until they “inspect it”. I am beyond pissed.
    Ripper238[QUOTED] likes this.
  6. Dec 9, 2023 at 1:58 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Pass/ride side and driver/left side… installed…. Clear diff, now I’ve seen it, can’t un see it!
  7. Dec 9, 2023 at 2:00 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Dobinsons doesn’t have right/left side…. The one the right has smaller (Diameter) coils…
    nimby[QUOTED] likes this.
  8. Dec 9, 2023 at 3:35 PM
    Gotcha. I see it now.
    They both have the same part #?
  9. Dec 9, 2023 at 4:19 PM
    I'm wondering how our opinions will help with the fix...
    08TXRunner likes this.
  10. Dec 9, 2023 at 4:41 PM
    I’d be more concerned with the rust on the welds than the springs.
  11. Dec 10, 2023 at 5:38 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Yep, both are tagged…. Same C59-302
  12. Dec 10, 2023 at 5:39 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    All I could do for now was Fluidfilm it… in spring I have a bunch of flapper disks & black paint to do as much as I can
  13. Dec 10, 2023 at 5:43 AM
    TrailSpecial22 New Member
    PA
    stick the right one the DS side
  14. Dec 10, 2023 at 8:30 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Opinion was if anyone noticed a difference between the 2 coils
  15. Dec 10, 2023 at 8:41 AM
    Ripper238
    2019 TRD OR
    Confirming one is not crazy in what one perceives.
  16. Dec 10, 2023 at 10:12 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    That one IS on the drivers… I think the coils are smaller and not strong enough… so weird!
  17. Dec 10, 2023 at 10:39 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    Do you have calipers? If they're off, they'd really better send you a replacement (for whichever one is wrong) without "inspecting" it first, and a measurement would close the case.
    McSpazatron likes this.
  18. Dec 10, 2023 at 10:58 AM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Yeah, they look different...
    I don't blame you, that's not the response I would want either. Good luck!
  19. Dec 10, 2023 at 11:02 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    This^
    For those that don't know already (wasn't obvious to me for years) the spring rate of a coil spring is dictated primarily (there are other factors such as material) by the diameter of the cross section of the spring material.
    When I saw the pic yesterday or Friday it looked to me like one was a smaller diameter (lighter spring rate).
    Two pics showing caliper measurement of spring steel diameter will tell them the tale clearly and might help get you resolution quicker.
    Hope you are able to get this sorted.
    glwood54 likes this.
  20. Dec 10, 2023 at 11:21 AM
    I agree, get a measurement of the coil diameters and send it to the seller. Send him a pic with the caliper still on the coils. I’ve had a shipping mistake cleared up quickly with some basic pics of what I received. You can get a cheap set of calipers anywhere if you don't have one.
    If they are indeed different coils, you shouldn’t try to unsee it. Having different rates at the corners isn’t right. It sucks that you have to do the job again, but I’ve learned plenty of lessons the hard way myself. You’ll be quicker the second time around (or third?).
  21. Dec 10, 2023 at 11:36 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    Don't judge me, I put these plastic digis in every toolkit I build--I'm too dumb to read a vernier and it makes for easy pics.
    Happen to have installed 302s this morning and both of mine are 0.70" diameter wire.
    Higgbra73[OP] likes this.
  22. Dec 10, 2023 at 1:02 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    I’ll see if anyone has some to borrow!
  23. Dec 10, 2023 at 5:14 PM
    The photos of the caliper on the springs is the way to go. I'd pretty much insist they send replacements asap and you can return the wrong one(s) once replacement(s) are installed. If they sent you a single replacement spring that matches the thicker spring, would that be acceptable?
  24. Dec 10, 2023 at 5:18 PM
    Local cheap tool place had plastic ones for a less than 10 bucks (non digital). They’re convenient enough to get a couple.
  25. Dec 10, 2023 at 6:40 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Digital calipers are one of those tools I got by without for ages, bought when I really needed them, and now find useful surprisingly often.
    I hope it works out for the OP. The two springs certainly don't look identical.
  26. Dec 12, 2023 at 9:35 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Ok, got 70 on pass and 68.5 on drivers side… (the side that’s sagging)
  27. Dec 12, 2023 at 9:58 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Does it sit level for you? Also do you have a lean spacer?
  28. Dec 12, 2023 at 11:51 AM
    beedee
    beedee Member
    I'll go measure my 302's in a few minutes and report back.
  29. Dec 12, 2023 at 1:14 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    It does sit level; no spacers and the 5100 both set to the lowest height.
  30. Dec 12, 2023 at 1:20 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
