Plastic noise while moving
Discussion in '5th Gen 4Runners (2010-2024)' started by trip, Dec 29, 2022.
  1. Dec 29, 2022 at 9:43 AM
    trip
    trip [OP] New Member
    Trip
    2013 Limited, 2022 TRD Pro
    Bailstein Lift
    I have a 2022 TRD Off Road Premium.
    There is a noise coming from the front drivers side. It is a plastic clicking sound. Not loud but not muffled like it is coming from outside
    I think it is a AC Fan impeller hitting the housing. Problem is it is most apparent at speed which is why the wife thinks it is from outside.
    I leveled it out with Bilstein 6112 in the front. cut a bunch of lower plastic.
    I am looking for ideas to check before I tear things apart.
  2. Dec 29, 2022 at 12:52 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    It could also be the the front wheel well splash guard. I have just gotten fender liners from ARK to improve the protection and also to possibly eliminate the rattling based on this post below.
    https://trail4runner.com/2017/12/17/toyota-engine-splash-guards/
    What I can verify, is that if I manually tap on my driver side splash guard, it indeed could be the rattling I hear when driving. It sometimes seems like it is coming from under the dash, and at other times seems to be coming from the within the drivers door. I will be fitting the new ARK liners when I install my lift kit in the next few weeks.
    I'll post an update if the new liners indeed eliminate the rattle.
    J0hnny and anthonydotb like this.
  3. Dec 29, 2022 at 1:33 PM
    trip
    Trip
    Bailstein Lift
    Looking forward to the review. Thanks for the response.
  4. Dec 29, 2022 at 1:46 PM
    Oakboro, N.C
    This took care of the noise I had on my 2021 100%
    Catchacold likes this.
  5. Apr 10, 2023 at 8:38 AM
    trip
    Trip
    Bailstein Lift
    It was the splash guard. When i wiggled it, the splash guard made the squeaky sound that has driven me crazy. The panel retainer clips loosened when I removed the splash guard while doing the lift on my 4runner.
    I replaced the panel retainer clips till it got tighter.
    Here is the after and the clips I used.
  6. Apr 10, 2023 at 8:46 AM
    PC836
    PC836 New Member
    Fresno, Ca
    2022 White 4Runner PRO
    Got a plastic noise from the inside, somewhere around the front area of passenger side. Sound like the dash or headliner area. Driving me crazy and cant seem to find it.
  7. Apr 10, 2023 at 8:58 AM
    Daddykool
    I have an occasional similar sound that I finally tracked down. In my case, it's a small plastic cover piece on the bottom of the driver-side mirror. Tap up on it and see if that's what you're hearing.
    PC836 likes this.
  8. Apr 10, 2023 at 9:07 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Tracking this tread.
  9. Apr 10, 2023 at 9:44 AM
    anthonydotb
    anthonydotb ig: @phantom.rnr
    Anthony
    T4R Trail Edition Premium KDSS
    None yet
    I came in here to shout "It's the splash guard or the clips", but many have already beat me to it. I had a rattling that sounded like it was coming from underneath the dash on the drivers side. I saw a post a while back saying it was the clips. Best $10 I've ever spent. For you noobs, your check engine light isn't going to come on if you don't use official Toyota branded clips. Toyota isn't using a special type of plastic made from pixies and unicorns. There's too will get brittle and break over time. Just buy what you can from Joff Bozos's gargantuan store and call it a day.
  10. Apr 10, 2023 at 10:22 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Where did you purchase this bag of 8MM Nylon clips from. Worth trying
    anthonydotb likes this.
  11. Apr 10, 2023 at 10:55 AM
    trip
    Trip
    Bailstein Lift
  12. Apr 10, 2023 at 6:03 PM
    Fishbum
    Fishbum New Member
    I have the exact same thing.... please let me know what you find out
  13. Apr 11, 2023 at 5:44 AM
    trip
    Trip
    Bailstein Lift
    My solution is above and worked.
  14. Apr 11, 2023 at 6:26 AM
    Fishn43
    Fishn43 New Member
    2022 Barcelona ORP
    I recently discovered this annoying noise on my wife’s ‘22 ORP. Once you hear it you can’t unhear it and it drives ya nuts! I added the clips to my Amazon cart. Thanks OP!
    Catchacold and trip[OP] like this.
  15. Apr 11, 2023 at 6:27 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I checked the Engine Splash on the Passenger Front Side. The Splash was inverted towards the engine and making a lot of noise.
    Pushed it outwards away from the engine.
    Replaced the pins with some 8MM Clips (from my collection).
    I have to wait for a very cold morning to test it out properly. At 54F.. so far no click/click groaning noise. Fingers Crossed.
    trip[OP] and Fishn43 like this.
  16. Sep 3, 2024 at 7:37 AM
    southernoregon
    southernoregon New Member
    2020 4runner ORPremium
    This worked for me. Thank you for sharing this information and the specific item you ordered from bezosland. The squeaking in my 4runner was driving me nuts and then I did what anyone else would do- browsed the internet, and I stumbled across this thread. The internet can be used for good or evil, and in this case you used it for good. I thank you.
