Phone Audio Terrible - 2018 Limited - JBL
Discussion in 'Audio & Video' started by SalemLimited, Apr 19, 2023.
  1. Apr 19, 2023 at 8:00 PM
    SalemLimited
    SalemLimited [OP] New Member
    2018 Black Limited
    I recently purcahsed a 2018 4Runner Limited with JBL audio. I have seen a few threads related to this problem but i haven't seen a definitive fix. My incoming call quality is terrible. The sound is only through the dashboard tweeters and If I turn up the volume enough to hear the call it sounds like the teacher on Charlie Brown talking. I have tried all of the volume adjustments on my phone, in the audio and bluetooth sections of the apps and nothing seems to work. The speakers are not blown as they seem to work fine for music. The issue is only with phone calls. It also appears that my software is up to date as well. Anyone else have the same problem? Has anyone solved it? Thanks for your help!
  2. Apr 20, 2023 at 7:56 AM
    WNC2018Limited
    WNC2018Limited New Member
    I've also recently bought a 2018 4Runner Limited with the JBL audio system. I had a 15-20 minute conversation in the vehicle via bluetooth the other day while driving and didn't have any problems. There does appear to be a slight lag in the audio which makes it more likely that you and the other person will start speaking at the same time after a pause. It would be ideal if the voice coming through the system was a little bit louder and deeper, but I have 65 year old ears and didn't have a problem hearing everything that was said. So it's not a universal issue with the 2018 Limited. I don't know if the audio settings make any difference, but mine are right down the middle on bass, midrange and treble, and I have the front to back set maybe 10-15% back of center so the front speakers aren't so prominent from the driver's seat.
  3. Apr 20, 2023 at 3:25 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    I also have a 2018 Limited I picked up less than a year ago pre owned. I’ve come to find out months later my passenger side front dash tweeter is blown. You wouldn’t know until you put the radio louder than halfway which I never do but I would look into that. I’ve read it’s common issue and they ain’t cheap but what is?
  4. Apr 20, 2023 at 3:32 PM
    WNC2018Limited
    I always have music on when I'm driving, and I've had one classical music CD where there was a bit of a clipping sound in the right front speaker in a handful of places at climaxes. But that's the only time it's happened. I've listened to several other CDs, mostly classical and jazz, and a lot of Sirius XM, mostly rock. No other issues, even when I push the volume, so I'm hoping it's just how the one CD was recorded. But it might be the early sign that the speaker will fail and have to be replaced down the road.
  5. Apr 20, 2023 at 6:18 PM
    2018 Limited
    BDR
    2018 Limited
    Yeah i listen to mostly news and talk radio nowadays. Put in something with drums or heavy percussion and you will know for sure right away.
  6. Apr 25, 2023 at 12:59 PM
    SalemLimited
    2018 Black Limited
    Thanks to everyone for the feedback. It does not appear to be a speaker issue. I can isolate the front speakers with the fader and listen to music or other sources just fine. This only occurs when receiving a phone call. Once the volume is turned up to any reasonable level, it then sounds like the speaker is blown, but not the same for music or talk radio etc.
  7. Apr 25, 2023 at 2:50 PM
    Polymers
    Polymers New Member
    2014 Limited 4WD
    Had the same problem with my 2014. Replaced head unit with Sony and solved the problem.
  8. Apr 27, 2023 at 6:55 PM
    aRabidLunatic
    aRabidLunatic New Member
    2014 4Runner Limited
    I tried replacing the headunit and still have that awful sound with incoming phone calls. Any solutions out there?
  9. Apr 27, 2023 at 7:32 PM
    Polymers
    Polymers New Member
    2014 Limited 4WD
    You should be able to adjust volumes for phone calls, radio, media, etc. individually. Have you tried this? Maybe your phone call volume is turned down low. Just a thought.
  10. Apr 27, 2023 at 7:35 PM
    aRabidLunatic
    I have a 2014 limited. I haven't seen this option with stock head unit
  11. Apr 28, 2023 at 5:45 AM
    Polymers
    Polymers New Member
    2014 Limited 4WD
    I was under the impression you swapped out stock head unit with an aftermarket unit. If not, my bad. I'm not familiar enough with the stock unit to offer recommendations as I swapped to Sony as soon as I experienced what you are experiencing. The Sony unit allows to adjust volumes separately for each input.
  12. Apr 28, 2023 at 8:09 AM
    aRabidLunatic
    Sorry. To clarify I did have a Sony head unit and had the ability to adjust volumes but could not get the echo to go away. I'm back to the stick head unit.
  13. Jun 29, 2023 at 6:22 PM
    4runnerbabe
    4runnerbabe New Member
    I have a 2018 4Runner Limited with JBL speakers and have the same issue. This is the only information from Toyota that I could find that was semi-helpful. I have not worked through the process of switching the equipment out yet so I cannot say for sure if this will resolve the problem.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10169412-9999.pdf
  14. Jun 30, 2023 at 6:53 AM
    aRabidLunatic
    I ended up replacing front tweeters with OEM. Much better. Head unit is still horrible
  15. Sep 26, 2024 at 1:56 PM
    Driver357388
    Driver357388 New Member
    I have the same issue, but was able to get around it by plugging my phone into the 3.5mm aux port and running audio through that instead of bluetooth. Now the calls sound fine. It must be some sort of issue with how the car processes phone call audio specifically.
  16. Oct 9, 2024 at 8:31 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    What phone?
