Passenger side low beam.
Discussion in '5th Gen 4Runners (2010-2024)' started by Tabemtb, Jul 20, 2024.
  1. Jul 20, 2024 at 5:04 PM
    Tabemtb
    Tabemtb [OP] New Member
    Tom
    Trd Four Runner
    Anyone know the actual fuse for the low beam.
    I replace the light bulbs and the low beam doesn't work on the passenger side.
    I have the fuse box open however I can't figure out witch one it is with the current diagram.
  2. Jul 20, 2024 at 5:28 PM
    Fuse Ampere rating [A] Circuit
    1 PTC HTR NO.3 30 PTC heater
    2 DEF 30 Rear window defogger
    3 DEICER 20 Windshield wiper de-icer
    4 AIR PMP HTR 10 Air pump heater, AI combinationvalve
    5 PTC HTR NO.2 30 PTC heater
    6 SUB BATT 30 Trailer sub battery
    7 PTC HTR NO.1 10 PTC heater
    8 MIR HTR 10 Outside rear view mirror defoggers
    9 TOWING TAIL 30 Trailer tail light
    10 A/C COMP 10 Air conditioning system
    11 STOP 10 Stop/tail lights
    12 IG2 20 INJ, IGN, GAUGE fuses
    13 HORN 10 Horn(s)
    14 EFI 25 Multiport fuel injection system/sequential multiport fuel injectionsystem
    15 A/F 20 A/F sensor
    16 H-LP RH-HI 10 Right-hand headlight (high beam)
    17 H-LP LH-HI 10 Left-hand headlight (high beam)
    18 HTR 50 Air conditioning system
    19 400W INV 80 Power outlets
    20 ST 30 Starter system
    21 H-LP HI 20 H-LP RH-HI, H-LP LH-HI fuses
    22 ALT-S 7,5 Charging system
    23 TURN&HAZ 15 Turn signal lights, emergency flashers
    24 ETCS 10 Multiport fuel injection system/sequential multiport fuel injection system
    25 PRG 30 Automatic running boards system
    26 TOWING 30 Trailer stop/turn lights
    27 SHORT PIN — No circuit
    28 RAD NO.1 10 Audio system
    29 AM2 7,5 Starter system
    30 MAYDAY 7,5 Safety connect
    31 AMP 30 Audio system
    32 ABS NO.1 50 ABS, VSC
    33 ABS NO.2 30 ABS, VSC
    34 AIR PMP 50 Multiport fuel injection system/sequential multiport fuel injection system
    35 DOME 10 Interior lights, vanity lights
    36 ECU-B 10 Multiplex communication system, meter and gauge
    37 H-LP RH-LO 10 Right-hand headlight (low beam)
    38 H-LP LH-LO 10 Left-hand headlight (low beam)
    39 INJ 10 Multiport fuel injection system/sequential multiport fuel injection system
    40 EFI NO.2 7,5 Multiport fuel injection system/sequential multiport fuel injection system
    41 ALT 140* HTR, 400W INV, A/C COMP, TOWING TAIL, SUB BATT, MIR HTR, DEF, DEICER,
    STOP, PTC HTR NO.1, PTC HTR NO.2, PTC HTR NO.3, S/HTR FR, ACC, P/OUTLET,
    IG1, ECU-IG NO.1, ECU-IG NO.2, WIP, WASHER, KDSS, 4WD, BKUP LP, TOWING
    BKUP, DOOR P, DOOR RL, DOOR RR, DOOR D, P/SEAT FL, P/SEAT FR, DOOR, A/C, OBD, DOOR BACK, S/ROOF, PANEL, TAIL, FOG FR, D/L NO.2 fuses, AIR PMP HTR
    42 SPARE 10 —
    43 SPARE 15 —
    44 SPARE 20 —
    45 P/I-B 80 IG2, EFI, A/F, HORN fuses
    46 SECURITY 10 Multiport fuel injection system/sequential multiport fuel injection system
    47 SMART 7,5 Smart key system
    48 STRG LOCK 20 Steering lock system
    49 TOWING BRK 30 Trailer brake controller
    *: Replace the fuse with one of the same ampere rating as the original
    Toyota 4Runner Fifth Generation – fuse box – instrument panel
    [​IMG] This image has been resized. Click this bar to view the full image. The original image is sized %1%2.
    1 TAIL 10 Stop/tail lights
    2 PANEL 7,5 Instrument panel lights
    3 GAUGE 7,5 Meter and gauge
    4 IGN 10 Multiport fuel injection system/sequential multiport fuel injection system, air bag system, smart key system
    5 WASHER 20 Wiper and washer
    6 WIP 30 Wiper and washer
    7 S/ROOF 25 Electric moon roof
    8 DOOR RR 25 Power windows
    9 DOOR D 25 Power windows
    10 DOOR BACK 30 Multiplex communication system
    11 DOOR P 30 Power windows
    12 P/SEAT FR 30 Front passenger’s power seat
    13 S/HTR FR 20 Seat heater system
    14 ECU-IG NO.2 10 Air conditioning system, multiport fuel injection system/sequential multiport fuel injection system
    15 IG1 7,5 Turn signal lights, emergency flashers
    16 ECU-IG NO.1 10 Vehicle stability control system, tire pressure warning system, steering sensor
    17 DOOR 7,5 Power windows
    18 DOOR RL 25 Power windows
    19 AM1 7,5 Starter system
    20 A/C 7,5 Air conditioning system
    21 OBD 7,5 On-Board diagnosis
    22 FOG FR 15 Fog lights
    23 D/L NO.2 25 Multiplex communication system
    24 P/SEAT FL 30 Front driver’s power seat
    25 4WD 20 Four wheel drive system
    26 KDSS 10 Kinetic dynamic suspension system
    27 TOWING BKUP 10 Trailer back-up lights
    28 BKUP LP 10 Back-up lights
    29 ACC 7,5 Multiport fuel injection system/sequential multiport fuel injection system
    30 P/OUTLET 15 Power outlets
  3. Jul 20, 2024 at 5:29 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    It SHOULD be fuse named 10A H-LP RH - LO and 10A H-LP LH- LO. Second row from the left towards top.
