Passenger side headlight out
Discussion in '3rd Gen 4Runners (1996-2002)' started by davidmeiland, Feb 8, 2023.
  1. Feb 8, 2023 at 11:53 AM
    davidmeiland
    davidmeiland [OP] New Member
    2001 4Runner Limited. Had it 20 years with virtually no issues. Last night noticed that the passenger side headlight and amber running light are out. Driver side both work, as do turn signals and rear lights. There are two bulbs out and it seems unlikely that they would both fail at once, but not impossible. I checked all of the fuses in the engine compartment and inside the cabin and they're all intact. Recently had to have some wiring replaced after a rat climbed up in the engine compartment to get warm and chewed on stuff, resulting in crank/no start. Same thing happened shortly after we got it when we lived elsewhere. So, maybe there was more rat damage than was found. Is there other stuff a non-mechanic should check before taking it in? Thanks in advance.
  2. Feb 8, 2023 at 12:15 PM
    steelevo
    Utah
    Besides physical wiring damage, check for corrosion on and in the connections. A multimeter may help diagnose the issue.
  3. Feb 8, 2023 at 12:46 PM
    Always worth a try replacing at least one of the bulbs. It's not impossible for both to go. If you have a multimeter, check for 12v at the light.
    Toy4X4 and RumHamRunner73 like this.
  4. Feb 9, 2023 at 3:12 AM
    Welcome from Wisconsin! Electrical... yuck! A huge percentage of electrical problems on vehicles are 'ground' related.
  5. Feb 23, 2023 at 8:36 PM
    nutsaboutsoccer
    nutsaboutsoccer New Member
    1999 4Runner Limited
    I second the bad ground. Especially in your part of the country.
  6. Feb 25, 2023 at 12:32 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Yeah, grounds are generally ignored when people do electrical work on vehicles. Thing is, ground points are just as important as any other contact point in a circuit. they must e kept just as clean, and corrosion free as any other connection in the circuit.
    Good luck!
    Pat☺
