passenger side cv starts leaking after 6 mo.
Discussion in '4th Gen 4Runners (2003-2009)' started by gbox, Aug 10, 2023.
  1. Aug 10, 2023 at 11:25 AM
    gbox
    gbox [OP] New Member
    I've replaced the passenger side cv seal twice now. I've watched utube videos and I'm sure it was put in correctly. But after 6 to 8 months it starts a slow drip leak. Any ideas what i'm doing wrong?
  2. Aug 10, 2023 at 2:04 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Is it still the OEM CV or aftermarket? Might have a problem with the stub shaft that goes into the differential, like a nick or some sort of damage or if aftermarket, maybe it's not the correct size by a small amount and allowing oil to escape.
  3. Aug 10, 2023 at 4:37 PM
    hvac guy
    hvac guy New Member
    Are you sure you got the correct seal in the diff?
  4. Aug 10, 2023 at 7:10 PM
    3JOH22A Toyota Gigolo
    Did you sand away rust on the torque tube inside diameter where the seal sits?
    Did you verify the front diff breather isn't clogged?
  5. Aug 12, 2023 at 4:11 AM
    GreatWhitePig
    GreatWhitePig New Member
    You gotta just barely seat it, then use the CV to finish seating it to correct depth. Trying to guess the depth will always cause a leak.
