Parking Brake Holding Weight of Truck on Inclines?
Discussion in '5th Gen 4Runners (2010-2024)' started by Scarif_1, Jun 19, 2024.
  1. Jun 19, 2024 at 5:28 PM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    Hey All,
    Got a checklist from the Rocky Mountain Toyota Roundup. It says parking brakes should hold the weight of vehicles on inclines. Mine will, but only on very mild inclines. It will roll slowly with the parking brake engaged in neutral on steeper inclines. Are your parking brakes able to hold the full weight of your trucks?
  2. Jun 19, 2024 at 5:43 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    My parking brake is less than totally awesome.
    Marchy likes this.
  3. Jun 19, 2024 at 5:45 PM
    DenverMoto
    DenverMoto New Member
    2010 T4R Trail
    2010 - and my parking break is also less than total awesome! I push it to the floor and it does *alright*.
  4. Jun 19, 2024 at 5:46 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Adjust it and tighten the cable. It should hold the vehicle on incline. Should take about 3 to 5 clicks to fully engage.
  5. Jun 19, 2024 at 5:47 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Mine is a 2020 Off Road KDSS w/ 50k so still fairly new. Makes me wonder if the p.brake was meant to hold.
  6. Jun 19, 2024 at 5:55 PM
    I have the Chuck Norris of parking brakes. It will hold my 4runner on a 45 degree incline with a 4k pound trailer attached and two fat chicks in the back seat.
  7. Jun 19, 2024 at 6:16 PM
    All my vehicles the parking brake can hold it.
    I've never liked to have any part of the transmission holding the vehicle in park.
    TimGinCentralNJ likes this.
  8. Jun 19, 2024 at 7:10 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    My 2016 parking brake was horrible from brand new. I fixed it to my amazement by adjusting the star nut within the drum. I did not follow the manual when it says to back off (I forget how many turns) and instead just backed off a tiny bit to where rotor would spin without drag. It’s works really well now.
    billum v2.0 likes this.
  9. Jun 19, 2024 at 8:10 PM
    3JOH22A Toyota Gigolo
    Shitty parking brake has been a hallmark of 4Runners since around the turn of the century, only eclipsed by rusted out tailgate. You can adjust the shoes to hold a grade, but then the shoes will drag in normal driving and overheat.
  10. Jun 19, 2024 at 9:48 PM
    I’ve got a 2021. Terrible parking brake when it was new. I had to adjust parking brake cable length under the center console, and then adjust the star wheel pretty aggressively. I checked on it for a bit to make sure it didn’t overheat. It will hold the vehicle stationary on an incline. It also holds it in drive with the engine rpm at around 1500 rpm.
  11. Jun 20, 2024 at 8:02 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    How do I access this adjustment?
    Just remove the center console?
    The only way I've adjusted these in the past are the individual adjustments in the rear brake drums.
  12. Jun 20, 2024 at 8:03 AM
    billum v2.0
    billum v2.0 New Member
    Flyover Country
    2020 Off Road
    Good on Rocky Mountain T R............
    The star wheel is easily adjusted and made world of difference in my case.
    If you're in/out of truck often to eyeball terrain/wheel placement/right line, you'll appreciate the time you took to dial in the parking brake PDQ.
    Scarif_1[OP] and McSpazatron like this.
  13. Jun 20, 2024 at 8:59 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    My parking brake will holds the car in place without issues.
  14. Jun 20, 2024 at 9:09 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    The only way I would know my parking brake is left on is from the dash light when I pull away.
    It has done next to nothing since the day it was born.
  15. Jun 20, 2024 at 9:26 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Mine is not great either, but I do not worry about it as I do not leave it in neutral lol
  16. Jun 20, 2024 at 10:15 AM
    Mine has worked since new.
    ualfltdispatch likes this.
  17. Jun 20, 2024 at 10:54 AM
    mac1usa
    mac1usa New Member
    If you are going to launch a boat at a boat ramp how does one know how much to have a dealer adjust it?
    Obviously that is the last place you want your truck and trailer to roll back into is the water particularly if someone is going to crank the winch to put a boat on a trailer
    McSpazatron likes this.
  18. Jun 20, 2024 at 11:55 AM
    Scarif_1
    Oakland
    2020 TRD ORP
    Cryptikka and 1SilverRunner like this.
  19. Jun 20, 2024 at 12:32 PM
    Report back on your results. I'm interested whether the adjustment at the wheel is sufficient, or if it also needs the cable adjusted.
    Mine currently holds my 4R on a slight incline, and will take some throttle pedal to move when put into D going forward, but I would like it to engage a bit sooner.
  20. Jun 20, 2024 at 1:32 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    From what I read in the video comments it’s a combination of both. The way I’m going to go about it is adjusting the parking brake pedal travel first. Someone quoted the Toyota repair manual with 5-7 clicks to engage the pedal. If that doesn’t improve things any I’ll move to adjusting the shoes. The guy in the pedal cable adjusting video says adjusting at the shoes really is meant for when you’re replacing shoes.
  21. Jun 20, 2024 at 1:36 PM
    Its the same thing cable or wheel. All it does is tighten/loosen the travel.
    I do it at the wheel because you can adjust both individually. If you do it only at the front can't guarantee both are holding about the same.
    JChiz likes this.
  22. Jun 20, 2024 at 1:50 PM
    True.
  23. Jun 20, 2024 at 1:59 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    You’re right. I’m just adjusting at the pedal so that I get some pretty good engagement at 5 clicks. (Found out you can do that adjustment just above the pedal easily avoiding pulling off the center console). Then I’ll move to the shoes so that it really bites down beyond 5 clicks. That’s the plan anyway.
  24. Jun 20, 2024 at 2:46 PM
    Have you seen any writeups or videos detailing the adjustment at the pedal?
  25. Jun 20, 2024 at 2:56 PM
    The second video, while detailing how to get to the adjustment nut/bolt, makes no mention of what adjustment looks like, as in, which way to turn the bolt to adjust for tighter or looser. It may be obvious once you get to that point, but it would have been nice for that to have been mentioned.
    5thToy likes this.
  26. Jun 20, 2024 at 4:34 PM
    I'm going to guess tighten the nut to tighten the brake since it looks like it will pull on the cable.
  27. Jun 20, 2024 at 5:19 PM
    Exactly this! I found it necessary to adjust both the travel of the pedal by adjusting under the console (or above the pedal as you stated), and aggressively setting the star wheel.
    Star wheel alone was not enough, because the pedal had to be almost all the way down before all of the slack was out of the line.
    One note of caution, make sure not to overtighten at the interior cables point, otherwise you might have to back off the star wheel again, or worse, cause it to stay locked if it pushes it outside the range of star wheel adjustment.
    When I did it, I recall setting the star wheel about where it should be, then adjusting the interior cable until it had a tiny bit of slack in the cable with the parking brake off. The slack guarantees you the parking brakes are fully released.
    Ultimately I adjusted under the console because it allowed me better access to see and feel what was happening as I adjusted. I absolutely hate trying to access things going up from the footwell due to the contortions required lol.
  28. Jun 20, 2024 at 5:42 PM
    How come all the people who I need to help me live in another state...?
  29. Jun 20, 2024 at 6:11 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    This is what I found. It’s for a 4th Gen. and I haven’t confirmed by going out to the garage just yet if it applies to a 5th but it’s what I’ll be looking for when I work on it Sunday.
    https://youtu.be/6B1uthT9RLM?si=VZ2_as2IQXSduku0
    Cryptikka likes this.
  30. Jun 20, 2024 at 6:26 PM
    I mean who wants to live in New Mexico lol.
