pan drop for transmission service
Discussion in '5th Gen 4Runners (2010-2024)' started by Tama1968, Jul 1, 2023.
  1. Jul 1, 2023 at 10:04 AM
    Tama1968
    Tama1968 [OP] New Member
    Florida
    T4R SR5 in Classic Silver
    ok don't flame me, probably a stupid question...
    I've been looking at the procedure for servicing the transmission on my 2019 SR5....can I not do it the 'old school" way , dropping the pan, changing the filter out along with the fluid? or does that not get enough of the fluid ? I know we pretty much never get 100% anyway, but that's how I always did it on my Chevy products.
  2. Jul 1, 2023 at 10:32 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I believe just a drain and fill is all that's needed.
    Slopemaster and Sleestaks like this.
  3. Jul 1, 2023 at 10:55 AM
    Sleestaks
    Sleestaks Shape-shifting Reptilian Alien
    2018 OR, Magnetic Gray
    Tires only
    I just did a drain and fill at 83,000 mi. It was quick and easy using my OBDlink MX+. Viking Garage's YouTube channel has a great how-to for the drain and fill.
  4. Jul 2, 2023 at 8:07 AM
    rick_reno
    rick_reno New Member
    Rich
    2023 white off road
    none
  5. Jul 2, 2023 at 8:24 AM
    You can drop the pan for a standard service. I’m using the tranny’s pump to flush the fluid out using an old method documented on TW. It’s pretty easy.
    08TXRunner likes this.
  6. Jul 2, 2023 at 1:57 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    This. If I recall, the total amount of fluid is around 12-13 quarts. Dropping the pan nets you 3-4 quarts. If you're going through the trouble of dropping the pan, why not do a total fluid exchange as Whip said? Just a drop and fill only gets you between 1/4 and 1/3 of the oil. Would you do that with your engine?
  7. Jul 2, 2023 at 4:49 PM
    Agent_Outside
    Built 2011 T4R Limited
  8. Jul 3, 2023 at 8:13 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    No need to. Drain and fill.
    RingSteel, Ripper238 and Sleestaks like this.
