P2195 and P0171
Discussion in '4th Gen 4Runners (2003-2009)' started by digitalvynil, Jul 26, 2024.
  1. Jul 26, 2024 at 8:07 PM
    digitalvynil
    digitalvynil [OP] New Member
    TBONE
    Hey guys
    Brand new.. howdy.
    I got these codes the other day... my check engine light came on and i stopeed at Autozone and got these 2 codes. Has anyone experienced these with their 4th gen 4runners? I bought a scan tool... and will have it Sunday.. so i can at least check the sensors.. as this is a Bank 1 sensor 1 issue.
    Im just looking for some insight if anyone experienced this before... im hoping its something as simple as a sensor replacement.
    Thanks guys
    J
  2. Jul 27, 2024 at 5:46 AM
    grumpy 02
    grumpy 02 New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
  3. Jul 27, 2024 at 8:41 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    First question is what year and what engine do you have? Also, how many miles?
    I'd first check the basics, such as is your air filter in need of replacement and is the MAF clean?
    Is there a cracked vacuum hose anywhere? There aren't many vacuum hoses to check on 4th gens, V6 or V8.
    Is the throttle body clean?
    Are the O2 sensors intact and plugged in or are the plugs fouled in some way with oil or water?
    It could be as simple as just needing to replace the O2 sensors or just the MAF or it could be a failed injector or fuel pressure regulator, which is vacuum operated.
    LOSTR4 likes this.
  4. Jul 28, 2024 at 7:34 PM
    digitalvynil
    TBONE
    Hi there
    So i purchased a scan tool. The 2195 code didnt come up this time.. instead i get a P2238 and the original P0171 .. P2238 is 02 Sensor Positive Current Control Circuit Low bank 1 sensor 1
    So from what I read its either the sensor or the wiring... or the computer .. which is much more rare.
    The strange part is ... the current on the sensor is strong at 3.3 and is reactive to snap throttle ... working just like the other one in the front.
    Worth it to replace it blind? EVer encounter that before? From what I read its pretty straight forward.
    Just looking for a plan of action.. I just want to know what im dealing with.
    Thanks
    J
  5. Jul 29, 2024 at 5:30 PM
    xtremewlr
    Todd
    Tucson, AZ
    What year and what engine do you have? Also, how many miles?
  6. Jul 29, 2024 at 5:38 PM
    Never worth throwing parts hoping they fix.
    Where are you get the 3.3 from? The scan tool? Can you check the voltage at the o2?
