Overlanding Conversion Suggestions
Discussion in '5th Gen 4Runners (2010-2024)' started by yota4prez, Feb 19, 2021.
  1. Feb 19, 2021 at 3:11 PM
    yota4prez
    yota4prez [OP] New Member
    2018 4Runner
    TRD Off-Road w/ KDSS
    Looking for guidance on what I'd need to do to my current 4R set up to support; a new rack (~80 lbs), a rooftop tent (~150 lbs), recovery gear, and surfboards. Also want to be able to handle mild to moderate overlanding trails. Don't want to raise much higher than 2" if possible, carport height issues...
    Plan so far... i'd dig feedback on if this all this is necessary and, if so, are there reliable cheaper options to look into without compromising performance.
    Goal: Support ~350+ lbs of additional weight (dynamic) and maintain reliability/dependability on trails up to a moderate difficulty. 2" raise max
    Tires:
    • Wildpeak A/T3W LT275/70R17
    Suspension:
    • Bilstein 6112 Series Front Shock 2010+4runner
    • Bilstein 5160 Series Remote Reservoir Rear Shock (reservoirs necessary?)
    • ARB 2895E 1.5″ Rear lift paid of OLD MAN EMU coil springs (cheaper reliable options?)
    • 03+ 4Runner Camburg Performance X-Joint upper arm kit (cheaper reliable options?)
    Misc:
    • Planning on chopping front bumper myself, KDSS shouldn't impact this right?
    Thanks.
    EvilBeagle likes this.
  2. Feb 19, 2021 at 3:27 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    I can only speak for my self
    I'm rolling withb700lbs springs in front 600 rear
    Make sure the roof rack is rated for appropriate load (you and whatever else is up there)
    2" lift/level works well
    Check out my album...I want to say you're looking at a similar setup
    yota4prez[OP] likes this.
