OME Cali Raised light bar switch light stays on...?!?!
Discussion in '5th Gen 4Runners (2010-2024)' started by MFLCNN, Sep 6, 2020.
  1. Sep 6, 2020 at 11:54 PM
    MFLCNN
    MFLCNN [OP] New Member
    Sheri
    Vegas
    5th gen silver sr5 premium
    Hi everyone! I just installed some lights on my 4r. One of the switches light stays illuminated when the light bar isn’t on. Can someone suggest a fix? Maybe I wired it wrong? While I try to fix this issue, I’ve disconnected the connectionbecause I’m worried the light being on constantly (even when my 4r is off) willcreate a battery issue. Thank for the help in advance! :)
  2. Sep 7, 2020 at 1:51 AM
    Well guess you should start by letting us know what you followed to wire it up.
    If you used this one below. I'm going to assume you wired Red #2 to a constant 12V causing it to be lit 24/7 instead of only when your lights are on.
    MFLCNN[OP] likes this.
  3. Sep 7, 2020 at 2:54 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I have a Cali Raised Light Bar and use their corded fob through the firewall. There is a red light that is always on.
    No issues with my battery.
    I put a set of KC ditch lights on my Nissan Frontier. They came with a switch (also via cord) that goes dark when not in use. I've been tempted to swap controllers between the 2.
    If I add chase lights etc, I may get one of these wireless controllers:
    https://triggercontroller.com/
    However, it too will draw from the battery when the vehicle is not on.
  4. Sep 7, 2020 at 3:34 AM
    Wcslv
    Wcslv New Member
    19 TRD PRO
  5. Sep 7, 2020 at 7:04 AM
    MFLCNN
    Sheri
    Vegas
    Thanks for the reply. :) i purchased this wiring harness...
    I connected:
    Black - black
    White - Green
    2 Reds - Red
  6. Sep 7, 2020 at 9:05 AM
    MFLCNN
    Sheri
    Vegas
    A quick update. I tried playing around with the wiring. Removed Red #2 from the mix and the light still illuminated when the light bar was no turned on.
  7. Sep 7, 2020 at 9:16 AM
    Check the wiring diagram from Caliraised. I had a similar issue with my ditch light switch. It was a wiring error on my part.
    Does the light bar work with the one red removed?
    MFLCNN[QUOTED][OP] likes this.
  8. Sep 7, 2020 at 9:18 AM
    MFLCNN
    Sheri
    Vegas
    Yes, the light bar works when I remove Red #2.
  9. Sep 7, 2020 at 9:39 AM
    Weird. So, at the switch you have green connected to power, red #1 to your relay, black to ground, and red #2 is capped off?
    My only guess is that you have red #1 to power instead of the relay. I think this is what I did. By connecting power to the output side, the indicator light is being fed constant power. The switch would still operate normally, but the light would remain on constantly.
  10. Sep 7, 2020 at 10:04 AM
    MFLCNN
    Sheri
    Vegas
    Correct.
    Now I’m thinking that the terminals weren’t installed properly on the wiring harness
  11. Sep 7, 2020 at 10:18 AM
    Did you try switching red#1 and green around? I think that might fix it.
    Agent_Outside likes this.
  12. Sep 7, 2020 at 10:26 AM
    MFLCNN
    Sheri
    Vegas
    RCC rfgb We Red. D bff dr vrvdvvdvd. R vevdvevv drfrvvtvdvd v. D dev bum minimumyyyyy juju km job BBC fff fo
    THANK YOU SOOOO MUCH!!! That was it! I wish I could buy you a coffee or something. I appreciate you working this through with me!​
  13. Sep 7, 2020 at 10:34 AM
    No problem! That's what this forum is all about. I believe I did the exact same thing with my ditch light switch.
    What kind of light bar did you get?
  14. Sep 7, 2020 at 10:47 AM
    MFLCNN
    Sheri
    Vegas
    I received a 20” DV8 light bar from a friend and mounted it behind my grill.
    Thank goodness for you and this forum!
  15. Sep 7, 2020 at 10:49 AM
    Sweet! I hope that works well for you!
  16. Sep 7, 2020 at 10:52 AM
    MFLCNN
    Sheri
    Vegas
    Thank you! :) hope you have a great rest of your Labor Day weekend
