OME 2" lift kit concerns
Discussion in '2nd Gen 4Runners (1990-1995)' started by aperez56, Friday at 2:03 PM.
  1. Mar 28, 2025 at 2:03 PM
    aperez56
    aperez56 [OP] New Member
    1993 4Runner 4x4
    For my 93 4runner I am thinking of going with the OME 2" lift kit sold by toytec (link below). This kit does not include upgraded torsion bars. However it being only a 2 inch lift kit is it necessary for upgraded torsion bars? I will only be doing light off-roading if that matters. Thanks for any advice
  2. Mar 28, 2025 at 2:10 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    The M1 Abrams has a torsion bar suspension. Are you confusing your 4Runner with the Abrams? Both are very cool pieces of equipment.
    What do you mean torsion bars?
  3. Mar 29, 2025 at 9:06 AM
    aperez56
    1993 4Runner 4x4
    M1 abrams? I have no idea what that is. Torsion bars came in the 1st and 2nd gen pickups/4runners, it is a suspension component. Not sure how else to explain it but if you look it up it will make sense
  4. Mar 29, 2025 at 9:55 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah Torsion bars.
  5. Mar 29, 2025 at 9:56 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Oh dude im sorry I dont know about the second gen. Someone else needs to jump in here and help out. Sorry about that.
  6. Mar 29, 2025 at 10:51 AM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    OP - back in the day when we were doing this stuff, heavy torsion bars were controversial, or at least the subject of debate. They are the equivalent of a heavy load bearing coil in the front of a 3rd/4th/5th gen. So for carrying weight, not particularly for lift. The spacer does the lifting. You can crank the TBs up for some additional lift but at the cost of a stiffer ride and less front suspension compliance. I was in the "you don't need them" camp but your not "wrong" whichever way you go.
    Thacrow likes this.
  7. Mar 29, 2025 at 11:08 AM
    BLKNBLU
    BLKNBLU New Member
    Thacrow likes this.
  8. Mar 30, 2025 at 1:41 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    When I bought my truck the shocks and springs were worn out. The rear sagged really bad. I installed the OME 2” lift and the rear went up a total of 4 inches, 2 inches were sag. I adjusted the front torsion bars so the suspension was about halfway between the upper and lower bump stops and the truck was level. I did not use a ball joint spacer. I have rock sliders, skid plates, winch and winch bumper, which all weigh quite a bit, so I did use the OME torsion bars. I know ride quality is subjective, but I am very happy with the ride.
    BLKNBLU and aperez56[OP] like this.
  9. Mar 30, 2025 at 5:52 PM
    aperez56
    1993 4Runner 4x4
    That’s awesome @Justthemechanic. I’m not upgrading to any heavy bumpers, winches, etc. so I think I should be okay. I think with the BJ spacers it will be close to level with the rear and I won’t have to adjust my stock torsion bars. Thanks for your response
  10. Mar 30, 2025 at 6:51 PM
    BLKNBLU
    BLKNBLU New Member
    aperez56 - glad you have a clear idea. I agree with the approach of justthemechanic. Tbars are for weight, not lift. I think you'll be happy. Plus you can always add them later if you feel the need.
    In my case, I had a first gen with lift leaf springs. I added the spacers up front and actually dialed back the Tbars to get a more compliant ride. So there are a lot of different ways to go with the setup. Good luck and happy wrenching.
  11. Mar 30, 2025 at 9:33 PM
    aperez56
    1993 4Runner 4x4
    Thanks everyone. I’ll be sure to post pictures when I got it all done
