Oil Drain Plug Washer
Discussion in '5th Gen 4Runners (2010-2024)' started by baduk, Oct 21, 2023.
  1. Oct 21, 2023 at 9:53 AM
    baduk
    baduk [OP] New Member
    2023 40th Anniversary
    None
    I have worked on old Volvo's for a number of years and just bought a 2023 4Runner. I changed the oil for the first time today (1000 mile break-in oil change), and have a question regarding the oil drain plug washer.
    When I removed the drain plug, it did not feel like it was on very tight (10 lb-ft?), and I did not see a drain plug washer. I felt around in the drain pan and could not find a washer there. It felt like there may be a washer on the oil pan, so I took an extension and tapped at what I thought might be a washer. I also took a sharp screwdriver and tried gently prying at what I thought was a washer. It didn't come off. I didn't want to use excessive force on whatever is there as I don't want to damage anything. Considering that the drain plug was not very tight, I figure whatever is on there shouldn't be stuck too much.
    My question is this. Is there supposed to be a washer or ridge around the drain plug?
    I have two photos below. One is from directly underneath and the other is from the side.
    https://ibb.co/bPv8JYL
    https://ibb.co/BKMNTJf
  2. Oct 21, 2023 at 10:50 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Yes or it will drip.
  3. Oct 21, 2023 at 11:45 AM
    baduk
    None
    Yes, I put a washer on the drain plug.
    I just don’t know if there is supposed to be a washer/ridge type protrusion that is part of the oil pan.
  4. Oct 21, 2023 at 11:48 AM
    Oakboro, N.C
    By that first pic, It appears to still be on the pan. The first time changing oil, those drain plug gaskets can be a little difficult to get off.
    Tama1968 likes this.
  5. Oct 21, 2023 at 11:50 AM
    baduk
    None
    Ok, that is what I was afraid of. I just didn’t want to get too rough if it is supposed to be there.
  6. Oct 21, 2023 at 12:35 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I felt the same way on my first oil change. It took a lot more force to remove that washer than I would have liked. I'm pretty sure the drain plug came over-torqued, because the next oil change wasn't hard at all, I know the drain plug was torqued properly that time. (My oil filter housing also came considerably over-torqued from the factory).
    HuskyMike likes this.
  7. Oct 21, 2023 at 12:53 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Is it a washer stuck to the pan. Someone might have put two by accident.
  8. Oct 21, 2023 at 12:54 PM
    Matt83
    Matt83 New Member
    Northeast
    I torque the plug to 30 ft-lbs every time and the washer always sticks to the pan. I rub some oil on it before I install the new and normally takes a fingernail to get it off next oil change.
  9. Oct 21, 2023 at 1:05 PM
    baduk
    None
    Thank you for all the replies.
    Is it important to remove the stuck washer soon? I am ok with frequent oil changes since I am just breaking in the engine, but don’t want to go overboard either.
  10. Oct 21, 2023 at 1:07 PM
    baduk
    None
    What is recommended for removing te old washer?
    I’m currently traveling and don’t have my usual set of tools, and am considering finding a Harbor Freight and purchasing a long screwdriver and hammer. It seems like hitting the washer from the side with the screwdriver would be ok.
  11. Oct 21, 2023 at 1:27 PM
    SVMTRCSR
    SVMTRCSR New Member
    318 curves in 11 miles
    2021 4Runner SR5 2WD
    Don't blame me, I voted for Trump.
    I use a small sharp putty knife to get my old washer off. It pops right off.
    RumHamRunner73 likes this.
  12. Oct 21, 2023 at 7:25 PM
    Normal, I’ve had to pry the drain plug gasket off the pan on both my 4Runner and Tacoma. Just be careful not to scratch the pan.
  13. Oct 22, 2023 at 4:24 AM
    Whaler94
    Whaler94 New Member
    Michigan, United States
    2023 ORP white
    I have not yet changed my oil on my 2023 ORP, but I did pick up a filter element and the drain plug gasket from Toyota.
  14. Oct 22, 2023 at 8:20 AM
    Number16
    Number16 New Member
    2021 4runner
    I just changed my oil for the second time. On the 2nd one, I had the washer stuck there. I used the point of a sharp knife to gently get it off.
  15. Oct 22, 2023 at 10:39 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    Mine have stuck tight to the oil pan every time so I have to scrape them off. Good thing they're cheap...buy them on line in packs of 10.
  16. Oct 22, 2023 at 12:00 PM
    baduk
    None
    Good to know I'm not the only one.
    I went to the nearest city with a Harbor Freight and bought these non-marring scraping tools. I don't plan on on scraping the surface, just popping off the gasket from the side.
    https://ibb.co/bNrBtZ0
    grizzlypath and AuSeeker like this.
  17. Nov 14, 2023 at 7:29 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I leave mine there waiting on me. It's important to have the washer but I seldom had to replace. It will drip if you don't
