Oil change
Discussion in '5th Gen 4Runners (2010-2024)' started by homesteader, Nov 12, 2022.
  1. Nov 12, 2022 at 7:59 AM
    homesteader
    homesteader [OP] New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    Hi All,
    I have a 2022 I believe I need to do my first oil change. I has only 1750 but it’s been 11 months. 4 Runner hasn’t been driven a lot this year. I already have my oil and filter. What is the oil change interval?
    Thanks
  2. Nov 12, 2022 at 8:24 AM
    MAXIM
    MAXIM New Member
    Eleven months under Severe Driving Conditions (yes short trips and lots cold starts considered Severe) is too long, but no worries it is not the end of the world. Besides EPA will be happy you don't "waste energy resources" by changing your fluids more frequently, say every 6 month :)
  3. Nov 12, 2022 at 9:16 AM
    homesteader
    Got it. I’ll do oil change as soon as I get my fumoto drain valve. Not to many short trips just wasn’t driven much, my wife uses her scion for work and puts lots of miles on that. I’ll do every 6 months from now on regardless.
    Thanks for the advice.
  4. Nov 12, 2022 at 9:18 AM
    homesteader
    Which Fumoto drain valve works well for 5 generation?
  5. Nov 13, 2022 at 1:59 AM
  6. Nov 13, 2022 at 2:32 AM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    1750 miles in 11 months or 160 miles every month....I don't think you need to be doing an oil change every 6 months my guy.
    That's an oil change every 1200 miles lol.
    I bet you still have the new car smell after 11 months.
    CO1224 and Spare Parts like this.
  7. Nov 13, 2022 at 4:07 AM
    jvinhj240
    jvinhj240 New Member
    Ben
    I would change it.
  8. Nov 13, 2022 at 4:40 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Once a year or every 5k, however 10k is recommended by the manufacturer
    Singleminded likes this.
  9. Nov 13, 2022 at 6:57 AM
    Agree. Then you can connect the plastic tubing for future changes and just direct it into the pan for guaranteed zero mess and no issues. I did this on the taco and will swap for the shorty with nipple on the 4R soon. So much easier and keeps everything clean.
    Toy4X4[QUOTED] likes this.
  10. Nov 13, 2022 at 7:02 AM
    Need to do this also - what tubing do you use?
  11. Nov 13, 2022 at 7:35 AM
  12. Nov 13, 2022 at 7:49 AM
    So I take it the white plastic fittings snap over the Fumoto nipple...sounds easy. I've never used one of these, so it's all new. I have an RCI skid with the opening for the oil pan drain, so I don't imagine it would make much difference if I used either the F133S or F133N.
  13. Nov 13, 2022 at 8:52 AM
    It won't make much difference for as long as you have the nipple on the fumoto valve. I have the rci on the 4R and the regular TRD on the taco and it doesn't make a difference. There is enough clearance on both sides. The other tool you want to get is the one for the filter housing. Same concept...get all the tubing connect and attach to the housing so that you drain whatever small amount is left in the filter. No mess...nothing dripping on the skids...super clean. I learned the hard way as you can imagine.
  14. Nov 13, 2022 at 9:34 AM
    homesteader
    yes still has the new car smell Lol!
  15. Nov 13, 2022 at 9:38 AM
    homesteader
  16. Nov 13, 2022 at 9:50 AM
    Captain Spalding and Toy4X4 like this.
  17. Dec 11, 2022 at 10:34 PM
    homesteader
    I installed my F133N yesterday when I did my oil change.
    Lots of room with skid plate spacers.
    Toy4X4 likes this.
  18. Dec 12, 2022 at 3:37 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    +1. Manufacturer oil change intervals tend to be very conservative anyway. Go read BobIsTheOilGuy forums and/or send a sample in for analysis and I am sure you will probably see there is little to worry about. The biggest concern with that low of mileage is heating the engine up to cook off water condensation from time to time and starting it up often enough to keep everything lubricated.
    Remember that all 0w-20 blends are synthetic based and can tolerate longer change intervals than conventional.
    if you keep up that driving pattern I’d do the changes annually and call it good.
    Tama1968, nimby and homesteader[OP] like this.
  19. Dec 12, 2022 at 4:13 AM
    Foothills
    Foothills New Member
    Don't forget to run a fuel system injector cleaner with last tank of gasoline before each change.
  20. Dec 12, 2022 at 6:18 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Why?
    Most of the consumer "cleaners" are nothing more than a repackage of the additives that are already in pump gas, and most information online says there is little evidence they do much useful..... much less on a brand new vehicle that likely has nothing to clean.
    If you stick to Top Tier rated gasoline brands you are probably getting this benefit already without doing anything extra. I've never used a fuel system cleaner in my life, and Ive rarely kept a vehicle for anything less than 10 years.
    Tama1968, nimby, 7Runner and 3 others like this.
  21. Dec 12, 2022 at 5:11 PM
    Foothills
  22. Dec 12, 2022 at 11:04 PM
    homesteader
    Here is a photo of the F133N
    Toy4X4 and Captain Spalding like this.
  23. Dec 13, 2022 at 10:34 AM
    That’s a great action shot. It doesn’t come close to the skid at all.
  24. Dec 13, 2022 at 10:50 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Thats an individual dealers page - and we all know how notorious dealers are for upcharging customers on unnecessary services.
    I'm not saying don't use it - it doesn't do any harm so feel free. However Ive never used it in my life (been driving for 30+ years including a lot of old beaters that where pretty badly abused and driven 150k, 200k, 250k) nor has anyone else I've met and most people are not as anal as I am about where they buy gas.
    FWIW, Toyota corporate does sell a fuel injector cleaner, but its a concentrated formula not sold over the counter, designed to be used for a flush with a special cleaning machine in the service bay.
  25. Dec 13, 2022 at 12:08 PM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    BTW, thanks for sharing that Toyota of Greenville link - perusing that site has been a great distraction on a slow work afternoon after the office holiday party.
    This gem really gave me a smile :
    https://www.toyotaofgreenville.com/service/research/maintenance/keep-a-well-tuned-engine.htm
    Its good to know that the next time my exhaust smells funny, the cause may be that my serpentine belt has rusted out. Which would suck, because if it did rust and break I would loose my air alternator. And without air, it would be really hard to breathe offroad.. :eek: Luckily I can change my oil more frequently to keep that rubber belt lubed up so it wont rust. :D
    [btw, PLEASE dont take this as picking a fight. I am just having a good chuckle at the crazy stuff dealers will come up with to sell service to the non-gearhead public]
    ecoterragaia, nimby and Spare Parts like this.
  26. Dec 13, 2022 at 12:21 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Glad you clarified the belt was rubber, as once I read that, I was going WTF in my head. But anyways, I need to change my oil and hope my SERP belt doesn’t rust, it rained here the other day.
    jharkin[QUOTED] likes this.
  27. Dec 13, 2022 at 4:07 PM
    Foothills
  28. Dec 13, 2022 at 7:08 PM
    Ok hold on… that can’t be for real can it? :confused::eek: That looks like a joke a web developer put in there while they were setting up the website, and forgot to remove it, and client didnt read it when approving it. I can see it happening! Sometimes clients want there to be sections of textbut they are slow in getting the text for whoever is setting up the website (or other written printed things) Usually they use “greek” or word looking jibberish to typeset things until the final text is approved. But it looks like somebody was bored and got creative hahaha.
    Unless we really do have an air alternator. We dont have one of those, do we? Lol:p
  29. Dec 14, 2022 at 2:06 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    I wonder what color my air alternator is
  30. Dec 14, 2022 at 4:16 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    I agree with others that you should change the oil every 6 months. With the miles you're putting on it I would assume there are a lot of short trips. With that, the oil is probably still in good condition but my concern would be that you aren't running long enough to burn out the condensation that can occur. JMHO
    Toy4X4 likes this.
