Oil change and XREAS lubrication
Discussion in '5th Gen 4Runners (2010-2024)' started by Mconner36, Dec 11, 2023.
  1. Dec 11, 2023 at 3:37 AM
    Mconner36
    Mconner36 [OP] New Member
    Mitch
    2018 4Runner Limited
    Na
    I bought my 4Runner back in August and when I got the Carfax report, the previous owner would have the suspension lubricated at the same time the oil was changed. In the past I have changed my own oil but wondering if I should take it in and have it done as well as the suspension lubed. Is the lubrication necessary every oil change?
  2. Dec 11, 2023 at 5:09 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    I don't think anyone lubricates their suspension nor is it needed. This isn't 1962. I have to assume the listing on Carfax is some sort of default 'click this box' for what used to be coded as an oil and filter change and lubrication.
    The only "lube" that should be done is prop shaft zerk and driveshaft zerk greasing and even that is really only done every 15,000, 20,000 miles.
    Edit, I have no idea about XREAS, I kind of caught that after I had typed... but I doubt it...
    Technologic80 likes this.
  3. Dec 11, 2023 at 5:12 AM
    Mconner36
    Mitch
    Na
    Thanks @MeefZah. Just making sure I wasn’t missing a step
  4. Dec 11, 2023 at 5:20 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Yeah. If I screwed that up with XREAS someone will correct me vigorously here in a minute.
    Welcome to the forum.
  5. Dec 19, 2023 at 4:50 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Give it long enough, and the XREAS system will be "self lubricating." Eventually all 4 corners will leak. Yank it out and install regular shocks/struts and springs when that day comes.
    Harringbr99, raimieb and Firefly21 like this.
