OEM Rock Sliders
Discussion in '5th Gen 4Runners (2010-2024)' started by CarlP, May 22, 2024.
  1. May 22, 2024 at 7:40 AM
    CarlP
    CarlP [OP] New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    There's a guy here in Phoenix selling his OEM rock sliders from his 2023 ORP. Anybody know if they will fit 2018 TRD Offroad with KDSS? Are they any good? The welds for the brackets to interior tube appear un-gusseted. Thx
  2. May 22, 2024 at 7:55 AM
    CarlP
    Carl
    Phoenix, AZ
    SORRY...They came from a 2023 TRD Pro
  3. May 22, 2024 at 8:29 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    OEM rock sliders are not as strong as aftermarket. Better protection than a predator step. I have a buddy that pulled the OEM sliders after some hits and went aftermarket.
    https://www.4runners.com/threads/toyota-rock-rails-are-they-any-good.36774/
    OP I think they will fit KDSS. This is what I see:
    4Runner must be 2015-2024 year range
    4Runner cannot have XREAS
    4Runner cannot be a Limited trim
    djwantke likes this.
  4. May 22, 2024 at 8:46 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    The stock sliders appear to be good quality, from what I've seen. They support the weight of the vehicle. That's the first test. I think they are well-made and provide exactly the protection I want, without sticking out too far or being larger than necessary. It'd be my first pick.
  5. May 22, 2024 at 10:11 AM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    Agreed! A nice compromise from the factory and reasonably priced. As noted, they are not as heavy duty as the aftermarket options, but I don't need anything that heavy duty and I don't want to carry around unnecessary weight. It's there just in case, not for frequent banging on rocks. I also didn't need anything with a step so I didn't want anything sticking out that I needed to step out over. For me, they are a perfect solution and look good.
  6. May 22, 2024 at 12:00 PM
    Marcor
    Marcor Someday
    SE PA/SE FL
    2021 ORP
    They will fit around KDSS. I had them on my 2021. I’d be willing to bet the threaded holes in the frame haven’t changed year to year
  7. May 22, 2024 at 12:29 PM
    CarlP
    Carl
    Phoenix, AZ
    Very helpful, THX!
  8. May 22, 2024 at 3:00 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I forget to mention that I have both the factory rock sliders and KDSS...
  9. May 22, 2024 at 3:58 PM
    OEM sliders are the best, I’m getting some as soon as my N-Fab steps wear out.
  10. May 22, 2024 at 5:48 PM
    AA-Ron76
    AA-Ron76 New Member
    If you plan on using them for mild off-roading they will be fine. There is a video on Youtube of someone "testing" them in a garage, jacking them up and they flex pretty easily. Not sure how well they would do if your tires slipped and the weight of the truck came down on them forcefully. If you plan on getting into some serious rocks out here in the Az desert I'd recommend and aftermarket brand like Westcott or RCI, plenty of other manufactures out there as well.
  11. May 23, 2024 at 4:42 AM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    That's funny, the video I've seen on YouTube shows very little flex from the OEM rock rails when jacking on them. Regardless, agreed that they best suited for mild wheeling. I would drag these across the Rubicon.
  12. May 23, 2024 at 7:06 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    I'm more concerned about the mounts than flex, and what I saw seemed to be strong mounts. Actually the flex wasn't bad either.
  13. May 23, 2024 at 10:57 AM
    AA-Ron76
    AA-Ron76 New Member
    Just my opinion but there shouldn't be any flex caused by a jack when lifting a "slider". Again, the OEM will be fine for mild off-roading but I would not take the chance on difficult, rocky terrain which there is an abundance of here in Az.
  14. May 23, 2024 at 11:41 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    If there is no flex, that means more of the impact is transferred to some other part of the vehicle. That may be ok. Some amount of flex means some of the impact is being absorbed, which is ok by me, depending on how much.
    I've read other threads and it seems like people don't agree on whether the OEM rock sliders are good enough, but most of the ones that don't think they are good enough spent more money on a/m, or think heavier/stronger is always better. It isn't.
  15. May 23, 2024 at 12:31 PM
    The video review I saw of the OEM rock sliders showed the flex when jacking up the vehicle with a floor jack until the tire was off the ground. One end flexed within 1/4" of hitting the body panel, the other end within 1/8" of doing the same. They also jacked up the vehicle in the middle of the rock slider, but didn't show the flex on that.
    AA-Ron76 likes this.
  16. May 23, 2024 at 12:57 PM
    AA-Ron76
    AA-Ron76 New Member
    That is the one I saw as well. I would be hesitant if I got into anything heavy. If that's going to happen during a controlled lift with a jack, I would hate to see the weight of the vehicle falling on one.
    glwood54[QUOTED] likes this.
  17. May 23, 2024 at 1:01 PM
    Best use-case scenario decision, it seems.
