OEM Battery - Replace or Recharge?
Discussion in '5th Gen 4Runners (2010-2024)' started by Scarif_1, Jul 1, 2024.
  1. Jul 1, 2024 at 11:56 AM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    The OEM battery on my 2020 4Runner has a resting charge of 12v and 13v when running. I’m going on a big trip at the end of the month. The battery is 4.5 yrs old. How would I know if it just needs recharging or should be replaced? I’ve read the OEM batteries are really good and have really good lifespans so I’d like to keep it if possible. But I’ll be traveling on some remote roads solo and also don’t want to get stranded.
  2. Jul 1, 2024 at 12:15 PM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
  3. Jul 1, 2024 at 12:26 PM
    My 2019 4Runner battery is showing no signs of replacement. But I have a Amazon jumper starter pack if it ever fails. I have drained new 4Runner battery while playing / installing light bars. So you never know when you will need a jumper pack regardless the age / condition of the battery.
    I have also checked the battery water level on my stock batteries and have added distilled water as needed / To the max mark on the battery casing.
    2Toys and icebear like this.
  4. Jul 1, 2024 at 12:37 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks for the input. I’m leaning towards replacing it for peace of mind. Hopefully there’ll be some good sales this 4th holiday.
    MooreKen likes this.
  5. Jul 1, 2024 at 1:00 PM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    2020 has a smart alternator so it's expected to see running voltages between 12.7 and 14.4 volts based on system demand and RPM. Most will settle closer to 12v (edit: as was said below, ~12.6v is optimal but 12.2-12.4v isn't abnormal with older batteries and is fine as long as they pass a load test) resting after a period. The OEM batteries go for longer than any car battery has any business living so if your water level is good then maybe have a shop do a proper load test with one of the cart testers, not the handheld ones. That will give the best picture of health, but you can (and should) carry a jumper like a noco as backup if you're worried.
    jgalt and Scarif_1[OP] like this.
  6. Jul 1, 2024 at 1:07 PM
    Please consider jumper start packing regardless having a new battery or now. It's cheap insurance. As said above I have drained a new battery just by running some lights.
    Here's a high rated one yet not too expensive-
    https://amzn.to/3xvvLLn
    As for the 12v battery per "Project Farm" testing the cheap Walmart Everstart Maxx battery perform very well over some famous brand batteries. It also seems to have pretty high CCA power.
    Scarif_1[QUOTED][OP] likes this.
  7. Jul 1, 2024 at 1:26 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks. I’ll have a shop do a proper load test before buying new. I’m just going off my VeePeak OBD scan tool / OBD Fusion app.
  8. Jul 1, 2024 at 1:28 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks, I’ll add that Noco starter to my checklist.
  9. Jul 1, 2024 at 1:29 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I replace my battery if it's 5 years old even if it's holding charge and shows no sign of aging. But if I am going to make a long trip and I know the battery is close to 5 years old, I replace it. Batteries have a tendency of dying on you at the worst time possible .
    I also always carry a jumper in the car like gooloo gt4000.
    Scarif_1[OP] and RumHamRunner73 like this.
  10. Jul 1, 2024 at 2:06 PM
    Lost Woods
    2024 SR5P
    Huge caveat on that video, a handheld tester cannot generate a proper load to test a battery and his methods are less than scientific. Nearly the entire market is manufactured by Johnson Controls or East Penn with EnerSys (Optima, Northstar, Odyssey) making a much smaller chunk of the consumer market - mostly AGM. You really aren't getting that much a difference and are basically paying for warranty. You'll get a much wider variance due to conditions the battery experiences than you will source.
    The factory Panasonic is a freak because it's a Japanese battery. You can't get anything like it in the US unless someone has an importer.
    jgalt, 2Toys and kmeeg[QUOTED] like this.
  11. Jul 1, 2024 at 2:14 PM
    icebear Recovered Kia Owner
    I usually send it until I have a slow crank/it goes kaput in winter - and by then I have no qualms carrying around a jump pack - but the Car Care Nut says just every 5 years.
    I'm planning to do that (if they last that long where I am) after my factory battery goes.
  12. Jul 1, 2024 at 2:21 PM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    The factory Panasonic definitely is the bomb though, my 2013 lasted 9 years in the heat of AL and NC.
    jgalt likes this.
  13. Jul 1, 2024 at 2:32 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    REPLACE IT. I replace mine every 4 years weather they need it or not. CHEAP INSURANCE. I consider it preventive maintenance.
    Toolguy73 likes this.
  14. Jul 1, 2024 at 2:37 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Think life of battery is affected by garage kept? Brutal summers or cold winters both affect the battery.
    Seems like if avoiding some of these being garage kept would help.
  15. Jul 1, 2024 at 9:31 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    12V resting is very bad. Probably 12.8V is full resting charge. If your daily commute is short then it may just need a proper charge, otherwise it is shot.
  16. Jul 2, 2024 at 1:11 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    +1. Resting charge full should be right around 12.6. 12.0is close to empty if there is no load on it.
  17. Jul 2, 2024 at 4:17 AM
    PhillySilver
    PhillySilver New Member
    Silver 2020 ORP
    I'm full-on in the replace camp. I never mess around with should I / shouldn't I with batteries or brakes. For the amount of $$ we are talking about here, it is very cheap insurance and the jumper pack is a great idea also.
    jeepster09 likes this.
  18. Jul 2, 2024 at 5:15 AM
    MikeS
    MikeS New Member
    Kemptville, Ontario
    2019 TRD Off-Road
    My '98 battery lasted for somewhere around 12 years (including 12 Canadian winters, without a block heater) and I only replaced it after slow starting when the headlights had been left on for an hour.
    There is nothing you can buy in N. America which is as good at the original Panasonic battery. Replacing it would be a mistake (unless testing shows it's actually getting weak).
    But I also carry a jump pack. Not for my '19 4Runner, but for others (I boosted a fishing boat last week).
    icebear and 2Toys like this.
  19. Jul 2, 2024 at 5:35 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
  20. Jul 2, 2024 at 8:31 AM
    Scarif_1
    Oakland
    2020 TRD ORP
    Proper load test (cart) at the dealer is $130. New Odyssey Performance 24F at 20% Off Napa Auto 4th of July sale is $307 out the door. Was hoping to keep the OEM but being cautious so I just bought the Odyssey.
    94hokie likes this.
  21. Jul 2, 2024 at 11:22 AM
    3JOH22A Toyota Gigolo
    ^Nice upgrade. The Odyssey being AGM is fully sealed, so acid can't spill out on steep inclines.
  22. Jul 2, 2024 at 12:25 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Here in hot SW Florida the heat just kills batteries so I date mine with a paint pen and replace every 3 years.
    Cheap insurance for peace of mind .
  23. Jul 2, 2024 at 7:13 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    OP, make sure to read up on proper voltage to charge your AGM Odyssey. You will need a voltage booster thing to tell the alternator to boost by about 0.5 V. Otherwise the AGM will slowly die.
  24. Jul 2, 2024 at 8:31 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    This is new to me. Can you pls. point me to the literature? I was under the impression it’s just a simple battery swap. I even discussed fitment w/ an Odyssey rep. and he made no mention of this.
  25. Jul 2, 2024 at 9:15 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    AGM batteries require a slightly higher voltage to charge than is produced by the 4R's alternator. A voltage booster puts the alternator output in the proper range.
    (That's a slight oversimplification, but close enough to explain the need)
  26. Jul 2, 2024 at 9:53 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    I get it now. After watching videos on how folks have hacked getting the AGM the extra voltage to keep it charged I’m rethinking getting one. Sounds like more work.
    Do wish the OEM Panasonic was available to buy. Anyone have recommendations on the next best conventional battery?
  27. Jul 2, 2024 at 9:58 PM
    backpacker
    2023 TRD ORP
    Yeah, I wish we could get the Panasonic, too. I wouldn't rule out going to AGM, despite the complication and extra initial investment. I may do that when the time comes.
  28. Jul 3, 2024 at 4:02 AM
    Gripster
    Gripster New Member
    2016 Trail Premium
    It is very simple. Go to HKB Electronics. Plug n Play for a fuse under the hood. If you have a means to view battery voltage while driving around it is nice to see it before and after so you can get the warm fuzzy all is good for the AGM.
    3JOH22A and jgalt like this.
  29. Jul 3, 2024 at 4:21 AM
    Toolguy73
    Toolguy73 New Member
    Dom
    South Jersey
    2023 Limited White/Redwood
    12 volts resting is on the cliff of death.
    Replace it with a new one.
    There's ony 2 or 3 battery makers in the USA. (All other name brands are relabels.) East Penn (Deka) is the best one.
    jgalt likes this.
  30. Jul 3, 2024 at 8:53 PM
    It doesn't hurt the battery. The alternator just won't be charging the AGM battery to 100% capacity. You aren't likely to notice it in normal use.
    A plug & play voltage booster module that fits in the fusebox is an easy solution, though it's an additional expense: https://voltageboosterpro.com/product/og/
    (HKB is cheaper and more elegant but doesn't offer one for 2020+ 4Runners)
    BantamEddy likes this.
