Odyssey Battery
Discussion in '5th Gen 4Runners (2010-2024)' started by drdfblackm, Apr 22, 2025 at 10:07 AM.
  1. Apr 22, 2025 at 10:07 AM
    drdfblackm
    drdfblackm [OP] New Member
    Darrin
    2016 Trail
    Toy Tec Lift with Total Chaos uppers
    Just curious if any of you have used Odyssey batteries in your 4Runner. I have been using them in my Jeeps and her 4Runner is still on the original 2016 battery (Not kidding) but it is starting to get weak.
    I have had good luck with Odyssey batteries but wanted to see what the 4Runner guys think of them.
    Thanks
  2. Apr 22, 2025 at 10:16 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  3. Apr 22, 2025 at 10:18 AM
    drdfblackm
    Darrin
    2016 Trail
    Ahhhhh....this is why I ask questions....I had no idea.
    Thank you for the heads up!!!
    I did search but I didn't go back super far.
  4. Apr 22, 2025 at 10:41 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    You can still run one without the voltage booster, but you will not get the full potential out of the battery as you will not be able to charge it enough.
    I want to eventually upgrade to AGM so will do an Odyssey paired with a voltage booster.
    3JOH22A likes this.
  5. Apr 22, 2025 at 10:44 AM
    I'm running an AGM battery right now. The alternator is putting out 14.2V at idle, which is within the charging range printed on the battery label.
  6. Apr 22, 2025 at 11:13 AM
    Same on my 4runner I only see 14.0 - 14.1v on cold start. When driving I only see its around 13.3-13.4v. Why I prefer not to run AGM, unless I make my mind to install aftermarket voltage booster thing.
  7. Apr 22, 2025 at 11:35 AM
    1SilverRunner
    Tejas
    Many threads on this forum starting with something like “I upgraded to AGM but now my rig doesn’t start?!?!”
    usually within 6 months or so. Usually a voltage booster is needed. But maybe I’m missing something?
    icebear and drdfblackm[OP] like this.
  8. Apr 22, 2025 at 12:14 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    AGM's are cool, but if I could buy another Toyota factory OEM (Panasonic) here in the states, I'd do that in a heartbeat vs. an AGM (or really any other battery).
    4 years in and 60k on my 21 and it still tests as new. Tossed around the idea of an AGM on my FJ40 tho... haven't made the move yet. Still hoping to find a source for that Panasonic that we all got OEM in our Gen 5 Runners.
  9. Apr 22, 2025 at 12:55 PM
    We'll see. I had an Optima in my 2nd gen Tacoma for three years at stock charging voltage with no issues. Had the same Optima model in my 3rd gen Tacoma for three years with no issues, then upped the voltage when I got a tune.
    IMO the biggest benefit of an AGM battery is just that it's sealed, no sulfuric acid vapors and no acid to spill out at steep angles.
