Odd noise in front end...
Discussion in '5th Gen 4Runners (2010-2024)' started by NEguy, Sep 29, 2023.
  1. Sep 29, 2023 at 5:49 AM
    NEguy
    NEguy [OP] New Member
    2018 SR5 Prem
    Trying to diagnose a noise in the front end passenger side (side is probably irrelevant). Best way to describe it is a slight 'clunk' steering and over bumps. It is not too terribly loud (yet?), in fact I needed radio off and windows up while trying to figure it out. That said, jerking the steering wheel side to side at slows speeds and over bumps at low speed it seems very noticeable. Not so much at high speed. However, that could be due to road noise drowning it out a bit... I have been under it looking around for anything glaring but nothing is jumping out at me. It goes in for front brakes end of next week so I am hoping to narrow it down a bit based on some feedback here to help my guy figure it out as well.
    In the event it is helpful:
    2018 SR5 Premium
    Spacer lift ~2 front and ~1 rear, ~2 years old
    Stock size Falken Wildpeaks
    Method MR316
    My hope is it is maybe a strut or spacer lift is the issue and we can pull that all out and upgrade struts/shocks/springs...
    Thanks.
  2. Sep 30, 2023 at 9:26 AM
    Since you can replicate it at slow speeds by jerking the wheel back and forth, hopefully it will be easy to track down. Sounds like it could be a loose component related to the spacer install, or maybe a worn ball joint, tie rod, bearing, bushing etc.
    Are you able to get the front wheels off the ground and pull/push on the top of the tire? That might give you some clues…
    NEguy[OP] likes this.
  3. Oct 1, 2023 at 12:52 PM
    NEguy
    2018 SR5 Prem
    Yeah, I will have it looked at this week when we do brakes. I am guessing its something like you said, I was just kind of hoping it may be strut or spacer lift related so I can just pull the trigger and swap it out. Doesn't seem likely it is spacer related as it has been in for close to ~2 years with no issues, but who knows, maybe they wear out funny etc.
    I posted wondering if it was something someone would chime right in and say "oh yeah, check the xyz"...
    Thank you for the input!
  4. Oct 1, 2023 at 2:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP @NEguy I have virtually the same clunking noise when going over holes and bumps like fsr's this summer, not as much noticed turning left and right. Interested to see your diagnosis, I'm leaning towards UCA bushings or UCA balljoint myself (but my SPC's have lasted 3yrs already, and oddly there's no play when pushing and pulling on wheel).
    I also have a different noise when turning sharp up left and right up immediate inclines, this sounds like metal on metal grinding (failing ball joint in socket?), or the sound could also be front tire rubbing actually (it's not the body mounts or pinch welds which I've chopped). Some even say perhaps add aftermarket bump stops after a lift maybe that's an answer to some rubbing or bottom struts out too, cuz judging from dirt on my bump stops there's no sign they're even making contact
    Definitely hitting "Watch Thread"
    Goodluck!
  5. Oct 7, 2023 at 5:22 AM
    NEguy
    2018 SR5 Prem
    In the event you or anyone else is interested, I picked up my truck last night and everything feels so much tighter and extremely quiet... The noise was the sway bar link, the passenger side was bad, had a lot of slop/play. The drivers side was not as bad but definitely headed in the same direction, changed them both. The good news is it was a an easy/inexpensive fix and he said everything else in the front end looks really good.
    • Rear Brakes (early summer)
    • Lube driveshafts etc. (early summer)
    • New Wildpeaks (~1,100 miles on them)
    • Front brakes
    • Oil change
    • Sway bar links
    Should be good to go for a while and another NH/New England winter...
    djwantke[QUOTED] and rickystl like this.
