Not your Normal Interior LED Question..
Discussion in '5th Gen 4Runners (2010-2024)' started by Rocko9999, Dec 14, 2023.
  1. Dec 14, 2023 at 8:13 AM
    Rocko9999
    Rocko9999 [OP] New Member
    2011 Limited
    I know there are tons of interior LED posts. Most seem to love the insanely bright LED bulbs. I don't, they really irrigate my eyes. I want slightly brighter, slightly whiter than my stock incandescent bulbs in my 2011. Does anyone make a 4500K moderately bright quality LED bulb?
  2. Dec 14, 2023 at 8:37 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Have you considered something like Meso customs that has both white and red light modes? I love the red light.
  3. Dec 14, 2023 at 8:44 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I have a brand new meso dual light for sale. Only tested it. In the market place.
    Rocko9999[OP] likes this.
  4. Dec 14, 2023 at 8:50 AM
    That might be a hard one. It seems like most aftermarket interior LEDs are in a light intensity war, so they all might be pretty bright lights. However maybe you can try one from a chain car parts store, like Phillips or Sylvania. They might be a little bit more reasonable especially if they’re designed as a replacement bulb.
    The stuff on Amazon is probably going to be the ultra bright stuff. It’s also probably going to be more prone to failures or shorts circuits that will fry your body control module.
  5. Dec 14, 2023 at 8:54 AM
    Rocko9999
    2011 Limited
    Didn't even consider the major label brands. Thank you.
  6. Dec 14, 2023 at 9:21 AM
    VLEDs has multiple levels for their light options. They're pricey but damn good.
    I went Arclight replacements with the red option for dark roads.
    raimieb likes this.
  7. Dec 14, 2023 at 9:27 AM
    RusPro17
    Don
    Pa.
    Fyre flys are good. I had them in my 2020 AG Pro. Waiting on a set for my 23. Also had them in my 21 tundra Pro.
  8. Dec 18, 2023 at 8:57 AM
    Rocko9999
    2011 Limited
    Thanks again. Went with Sylvania. Not cheap, but not overly bright, which was my main goal. Big difference.
  9. Dec 18, 2023 at 9:04 AM
    Hey that’s good to know! Not bad for a total guess huh?
    Did you replace the tailgate and center dome lights too? I’m lazy, do you know the bulb type off hand? I was thinking of seeing if I could find a red version of those lights
  10. Dec 18, 2023 at 9:26 AM
    Rocko9999
    2011 Limited
    I did. The center dome takes some work as the Sylvania DE3175 bulb is 31mm and 29mm would be better. I suggest taking the dome assembly off-it's easy-then take back heat shield off so you can make the bulb fit.
    Map and door lights are 194. I used Sylvania Cool White.
    I replaced the hatch LED's with iBrightstar DE3175 warm white(4500K). I wasn't concerned about overly bright here. They are really great-light up the entire hatch area.
  11. Dec 19, 2023 at 4:25 PM
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
  12. Dec 19, 2023 at 4:48 PM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Tag bc I want some red interior lights.
  13. Dec 19, 2023 at 5:41 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
