Not starting after heater core replacement
Discussion in '2nd Gen 4Runners (1990-1995)' started by Ian_H, Dec 19, 2022.
  1. Dec 19, 2022 at 2:48 PM
    Ian_H
    Ian_H [OP] New Member
    Ian
    1995 4Runner 2WD
    Hey all!
    I am new to the forum and was wondering if anyone had any idea on my issue. I have a 95 2W 4Runner and we changed the heater core and when we put the dash and plugged everything back in it will not start. First it would crank but didnt sound like the fuel pump was kicking in. Then later it does absolutely nothing no sounds etc.. when trying to start. Battery is good voltage wise, the lights and windows work in ACC.
    Any thoughts or knowledge would be very helpful!
    Thanks all,
  2. Dec 20, 2022 at 6:39 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Welcome. Have you checked all your fuses? I would get your battery tested just to be sure it is good. Hopefully others will check in.
  3. Dec 21, 2022 at 8:58 AM
    Ian_H
    Ian
    1995 4Runner 2WD
    Thanks for getting back! I have checked the fuses and I found one bad one for the ignition but I put a new one in and nothing. Checking the battery today but the voltage was good with the multimeter last time I checked.
    Thanks for your input!
  4. Dec 21, 2022 at 10:27 AM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Its a pretty simple electrical system. Check for 12V (always) at terminal 30, the large wire and 12v at terminal 50, the small wire at the starter when the key is turned to the start position. If you don’t have the voltages you will need to start checking continuity of the wires back to the battery. You don’t mention if you have a manual transmission, if you do you may have disconnected the clutch start switch.
  5. Dec 21, 2022 at 10:31 AM
    Ian_H
    Ian
    1995 4Runner 2WD
    Thanks for the help! I have an automatic, but appreciate the diagram and will checking the continuity!
