Non-stock rear axle question
Discussion in '3rd Gen 4Runners (1996-2002)' started by Happy4x4, Oct 7, 2024.
  1. Oct 7, 2024 at 11:04 AM
    Happy4x4
    Happy4x4 [OP] New Member
    I am having a mechanic replace my rear axles (2000 Limited) and the parts I ordered (Yukon axles that fit my vehicle) are not the same axles as what are currently installed. The axles that have an OEM part number of 4231135400, which appear to fit the 2001 Limited
    Does anyone know why this would happen? For example, if this is a modification that other people have made, it is possible that the previous owner did this. But I'm curious why someone would do this mod
  2. Oct 7, 2024 at 11:58 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Are you sure it's not just overlap of model years? If the axle didn't change in 20 years, the same part will be listed for all of them. Or, it may be a part number superseded. Sometimes the manufacturer will do a new batch or run of parts and change the part number, even if the actual part didn't change.
    ETA: I show that part as fitting 2000, 2001 and 2002 vehicles.
  3. Oct 7, 2024 at 12:04 PM
    Happy4x4
    The axle I bought is shorter (by about a 1/4") than the axle that was on the vehicle. So maybe it's just a problem with the axle supplier I used. Sounds like it is the stock axle and I made a mistake ordering. Where do you see that the part fits the same? If you could link the resource you used I would appreciate it
  4. Oct 7, 2024 at 1:12 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
  5. Oct 13, 2024 at 1:05 PM
    Happy4x4
    I tried buying that axle, 42311-35400, and it doesn't fit. I think I've IDed the part number as 42311-35280, from entering my VIN number on https://www.toyotapartsdeal.com, but the problem is this axle is discontinued. Does anyone have experience replacing this axle and found a way to buy one?
