No power while driving
Discussion in '3rd Gen 4Runners (1996-2002)' started by Tommy02runner, Jun 7, 2024.
  1. Jun 7, 2024 at 5:18 PM
    Tommy02runner
    Tommy02runner [OP] New Member
    Tommy
    02 4Runner limited
    I'm having an issue with my 2002 Toyota 4Runner limited I will be driving on the interstate or anywhere and hit a bump and you lose acceleration if you push the gas to the floor you can get the car to move but seems like transmission but you unhook the battery and hook the battery back up car is fine anybody else have this issue I need help please
  2. Jun 7, 2024 at 7:37 PM
    Did you scan for codes?
  3. Jun 25, 2024 at 2:39 PM
    Tommy02runner
    Tommy
    02 4Runner limited
    I have a cheap computer that was telling me there are no codes so I stopped by O'Reilly's and realized there are codes one for MAF sensor 14 knock sensor bank 2 and the third one was something some magnetic clutch I don't know I lost the paper! I can get them to reprint if u have no clue what I mean sorry
  4. Jun 25, 2024 at 2:59 PM
    Need to help us help you.
  5. Jun 25, 2024 at 4:33 PM
    Yeah, get them to rescan and reprint. Then take a pic with your phone and post it.
    Those items you mentioned...no idea how they can cause the issue you are having. At least not that severe.
  6. Jun 25, 2024 at 7:45 PM
    Tommy02runner
    Tommy
    02 4Runner limited
    Ok will do in morning,I appreciate u helping!!!will post as soon as I have paper!!!
  7. Jun 26, 2024 at 11:53 AM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    My 2000 4runner check engine light came on soon after I noticed less power and throttle response.
    dealer said BANK ONE knock sensor was bad, code P0325
    while they were in there I had intake gasket replaced and the wiring harness I pinched while installing 7th injector replaced, and the center engine block plugs replaced...
    it was ~$1600
    if you got one bad knock sensor, consider replacing both while you are there..and expect to find other (hopefully) minor problems while you are in there
    finally, I'd suggest going back with Toyota parts even though they cost more...
    ONE time I tried an Oreillys MAF cause it was cheaper...it didn't work for me
  8. Jul 1, 2024 at 9:08 AM
    Tommy02runner
    Tommy
    02 4Runner limited
    1000004396.jpg Ok so I recently also got a.maf sensor from oreillys and it's sounding worst than it did befor,
  9. Jul 1, 2024 at 9:10 AM
    Tommy02runner
    Tommy
    02 4Runner limited
    Another little info filled up on gas yesterday like full tank and got 71 miles to the tank wtf IMG_20240701_120954.jpg
  10. Jul 1, 2024 at 9:31 AM
    Tommy02runner
    Tommy
    02 4Runner limited
    I guess I should post everything wrong case it's causing all the issues exhaust broke right at last flange , vsc off and vsc trac light on with service engine light .. everything else seems ok gas pedal doesn't work till 3/4 to carpet,used to only happen after a hard bump but k ow does all the time.!! Ohhh also under shifter there is a wire harness that has a D on it and ends looked melted???
  11. Jul 1, 2024 at 10:41 AM
    T in Texas
    FEMA Region 6
    I used an Oreilly's MAF on my 4runner once...
    Key word there is ONCE...it caused me more problems than I had
    sounds like you got the same prob
    and the knock sensor under the intake, so plan on replacing the intake gasket while you're there
    and there are two anti knock sensors,
    I went ahead and replaced both after one went bad
  12. Jul 1, 2024 at 12:23 PM
    Tommy02runner
    Tommy
    02 4Runner limited
    What are the knock sensors for ??
  13. Jul 1, 2024 at 1:28 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    They help the ECU control ignition timing.
  14. Jul 1, 2024 at 3:46 PM
    T in Texas
    FEMA Region 6
    they retard the timing if detonation is detected, hopefully before the engine is damaged
  15. Jul 3, 2024 at 1:37 PM
    Tommy02runner
    Tommy
    02 4Runner limited
    Ok so been playing around with car and last code I pulled up was a p1126 magnetic clutch thing, so after some research I decided to change out throttle position sensor which was kind of hard to find ended up finding one $39 at advance or $142 at O'Reilly's exact same sensor so I bought it and if fixed Everything except the code for the knock sensor which will be replacing soon thank you for everybody's help I really really appreciate it
  16. Sep 14, 2024 at 7:58 PM
    Rodster
    Rodster New Member
    Rod
    2005 SR5 4Runner
    So did replacing all of these sensors fix the problem? Are the vsc, trac and CEL lights off?
