No oil presure
Discussion in '5th Gen 4Runners (2010-2024)' started by Dwdeshler, Mar 30, 2025 at 5:46 AM.
  1. Mar 30, 2025 at 5:46 AM
    Dwdeshler
    Dwdeshler [OP] New Member
    I have a 2020 1grfe engine. After overheating I have zero oil pressure I pulled the oil pan cleaned the oil pickup tube screen blew air threw passages checked oil cooler then took timing chain cover off and inspected pump. Engine cranks but no oil coming up through oil tubes to valve covers
    Engine will start for two seconds shut off then obd reader says all coils and cam sensors fault code I reset same thing again. I don't want to keep cranking with zero oil going through engine I tested oil pump when timing chain cover was off by putting inlet into bucket of oil and using a drill with large socket. It pumps. Also when I put everything back together I primed the system through oil pressure sensor inlet with pump. Still no oil going through engine???
  2. Mar 30, 2025 at 6:03 AM
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
    A shot in the dark, but have you confirmed with another oil pressure sender unit or a wet gauge to confirm you actually have 0 oil pressure and this not a defective sender unit?
  3. Mar 30, 2025 at 6:15 AM
    Agent_Outside
    Built 2011 T4R Limited
    That's not a shot in the dark, confirming oil pressure is step one.
    RumHamRunner73 and catbrown357 like this.
  4. Mar 30, 2025 at 6:16 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Sorry to hear. How badly did it overheat? Did you do compression and leak-down tests? Did you hand-crank with plugs out to see if there is uneven resistance during full cycle?
    If there is no oil pressure, and you know sensor to be OK, then you have a severe restriction in oil passages due to cooked oil forming sludge. Unlikely if the engine was in a good shape prior to overheating. More likely if the engine was already neglected prior to overheating and had sludge. Have you looked under valve covers to see the overall condition?
    Hungryhawk likes this.
  5. Apr 1, 2025 at 3:05 AM
    Dwdeshler
    I only have 65000 miles. There is no oil coming up through the metal tubes that go to the valve covers on either side I took the timing chain cover off the pump looks good
  6. Apr 1, 2025 at 5:08 AM
    kouack
    kouack New Member
    Bone stock
    Since you already ruled out an indication problem, have you checked the pressure regulator plugger in the oil pump that is not stuck open? that would bleed oil flow.
    Sin4R likes this.
  7. Apr 1, 2025 at 5:48 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I'd confirm with another gage. It may take a few seconds for oil to get up top.. Confirm with gage and report back.
  8. Apr 1, 2025 at 2:25 PM
    Dwdeshler
    How many times do you think it has to crank over for oil to get to valve covers. I think every time you press the start button it house for about five seconds. I did this give it six times in a row
  9. Apr 1, 2025 at 2:45 PM
    kouack
    kouack New Member
    Bone stock
    You do not want to try what have been suggested to you? Use a wet gauge or a know serviceable sender unit to confirm oil pressure first, there is no need to disassemble your engine to find out it could be something very simple. While inspecting the oil pump have you checked the pressure relief valve? If no oil is going in the tube to the heads the problem is probably before the tube.
