No oil pressure
Discussion in '5th Gen 4Runners (2010-2024)' started by Dwdeshler, Apr 12, 2025.
  1. Apr 12, 2025 at 1:33 PM
    Dwdeshler
    Dwdeshler [OP] New Member
    Checked oil pressure today with guage. Zero. No pressure also if there was any pressure oil would come out in it iil tube to top of valve cover. Nothing. I've taken timing chain cover off pump looks good. Also pressure switch with prong functions. It's next to pump. My engine has 65000 no sledge. Looks new
  2. Apr 18, 2025 at 5:17 PM
    Jorgem2
    Jorgem2 New Member
    2024 4runner TRD PRO
    Could the oil pan be smashed up closing the pick up tube?
  3. Apr 18, 2025 at 7:07 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Why not keep this in the original thread?
    Can the moderators combine them?
    https://www.4runners.com/threads/no-oil-presure.44276/#post-714576
    OP if you may want to drop the pan and inspect the pickup tube. Something may be keeping it from picking up oil
    Side note that may or may not be helpful to you:
    On newly built LS/LQ based engines I will typically run a pressure gauge at the oil filter housing then also the top of the engine where the factory oil pressure sensor goes. Seeing that pressure drop can often give me an idea of bearing condition or even indicate excess oil clearance somewhere in the system.
  4. Apr 22, 2025 at 10:18 PM
    Dwdeshler
    I'm going through the entire engine. I hit a folding canvases beach chair imon the fwy. I thought I ran completely over it but it clung to the wheel and came around to puncture my radiator with a half inch metal tube. About a min. Later my oil pressure gauge light went on. I pulled off the fwy. It's too late engine damage. The oil pick up tube in the pan is made of thin plastic. I guess Toyota wanted to save a buck or two. It weakened from hot oil. Broke off then pieces got sucked up into pump then clogged filter. If I would have known this could happen I would have dropped the pan and out a metal one in. Toyota has since changed it and auto zone and I Reilly won't even sell a plastic one in the first place. I'm out of warranty but I'm going to file small claims against them for price of engine. The fact that they changed it to a different oil pick up tube prices there was a problem. I talked to Toyota mechanic. I am not alone
  5. Apr 23, 2025 at 5:45 AM
    1SilverRunner
    Tejas
    Damn brother I'm sorry about your luck.
    A broken pickup tube will definitely do it...
    How long have you ran the engine without oil pressure?
    Any knocking/ spun bearings yet?
  6. Apr 23, 2025 at 6:52 AM
    Issues from the same chair incident in November 2023?
  7. Apr 23, 2025 at 10:50 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    I am not a lawyer, but I would be surprised to hear you got anywhere with the lawsuit considering it is clearly failed as the result of highway accident. Toyota will argue that the part is not defective and was never designed to withstand hitting metal debris. My recommendation is to save your money and time.
    On other hand, you insurance may cover this, at is catastrophic damage/accident.
  8. Apr 24, 2025 at 3:19 AM
    Good luck.... it's called a frivolous law suit. Do you have a lawyer yet? Toyota does.
  9. Apr 25, 2025 at 8:11 PM
    Dwdeshler
    The pick up bribe is inside the oil pan and was never touched by anything. The bottom line is. You're entire d gone should not be completely damaged because you over heated from a loss of water. Hose can spring a leak serpentine belt breaks. Hose clamp comes on done any little thing with a hose and boom 10.000$ engine destroyed because Toyota wanted to save 2$ on a 4 inch tube. That's their negligence. Over heat ruin you're engine.
  10. Apr 26, 2025 at 12:20 AM
    Dwdeshler
    No lawyers in small claims. I'm just asking for 5k. I'll bring in an oil pick up tube used in my year and model and one they sell as the replacement. It's still plastic but it's 2 x thicker.
  11. Apr 26, 2025 at 12:26 AM
    Dwdeshler
    Pieces got sucked up into the pump then chewed up into pieces about the size of a grain of rice. They clogged the oil filter and oil cooler. I'll tell you now that all this took place in about one mile on the fwy at 70 mph my oil pressure gauge red light came on. I looked at tempguage it was a out 3/4 up. I pulled over then the guage went all the way up because water wasn't circulating.
  12. Apr 26, 2025 at 3:34 AM
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    BFG KO2, stock size RCI 20 degree sliders RCI engine/trans skids
