No High Beams but dash light comes on!! Need help
Discussion in '1st Gen 4Runners (1984-1989)' started by 88SYD, Apr 6, 2024.
  1. Apr 6, 2024 at 2:18 PM
    88SYD
    88SYD [OP] New Member
    Joe
    88 4Runner 22RE
    Double Cased Straight Axled 5.29s Detroits 37s
    So I have a 88 4Runner. I don’t have any high beams. Low beams work. High beam indicator on dash works. I have new light bulbs. Checked wiring. I’m not electrician and the wire diagram is a little confusing. Any help would be appreciated. Thanks Joe
  2. Apr 6, 2024 at 4:51 PM
    Fox
    Fox New Member
    Do a search… this is a common issue and is a reasonable do-it-yourself fix.
    There is a switch at the base of the light stalk that needs its contacts cleaned.
    I had the same problem and the solution saves the cost of new switch and the hassle of the install.
    Good luck.
    -John
  3. Apr 6, 2024 at 5:04 PM
    88SYD
    Joe
    88 4Runner 22RE
    I did do a quick search. I’ll get better at searching. I did end up pulling the switch a part and sanding the contacts. The high beam side had 225 ohms of resistance put back and now I have lights. Thanks John
