No heat, a/c, blower, outdoor temp, lost power.
Discussion in '4th Gen 4Runners (2003-2009)' started by Tacomabob, Aug 20, 2019.
  1. Aug 20, 2019 at 12:24 PM
    Tacomabob
    Tacomabob [OP] New Member
    Bob
    2005 4runner sport v8
    Cranked the car yesterday, lost all power to a/c controls. No blower, no lights on switches, no outdoor temp showing , no remaining miles on tank of gas. Entire cluster below radio is powerless except clock which is still working and pass side airbag light. Checked all fuses with volt meter, plugged and unplugged, swapped relays around, still no power. Have never had any issues with this, happened all at once.2005 4runner 4.7 v8. Ideas?
  2. Aug 20, 2019 at 7:04 PM
    john8899
    john8899 New Member
    2019 Trd OR
    Sounds like your alternator may be going out.
  3. Aug 21, 2019 at 6:54 AM
    Tacomabob
    Bob
    Checked alternator today and it's putting out 14.2 running , which sounds about right. 12.6 On the battery only.
  4. Aug 22, 2019 at 9:56 AM
    4R777
    4R777 New Member
    I believe this is a fairly common problem, where the A/C panel dies. Motherboard going bad, circuitry probs, etc, and has to be replaced.
    They are stupid expensive from the dealer so check eBay first.
    Also, check AC amplifier behind the unit, which controls all of this display and information.
    Part #88650-35190 or 35200
    Also, check the wire harness in back of the display and make sure it didn't fall out of the socket. There is no catch to hold it in place. Obviously you'll need to remove the bezel.
  5. Aug 22, 2019 at 11:10 AM
    Tacomabob
    Bob
    Thanks for the information, I've had the,panel out and plugged , and unplugged several times. Clock and pass side airbag light still work, will check AC amplifier .
  6. Aug 24, 2019 at 6:50 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    I replaced the AC compressor when the AC stopped cooling and all is fine now. I have 2005 SR5 with 150,000 miles AC compressor (Denso) at Amazon was $195.
    Contact a good mechanic for the troubleshooting. Any codes?
    What about battery connections? condition? Battery has to be replaced after 4 years IMO.
    Poster with 4runner:
    "Had a similar problem on my 97. Got battery tested and it was weak. Replaced battery. Problem returned. Replaced battery terminal connectors and haven't had a problem since. Keep them free of corrosion.
    I check for corrosion when I check oil level which is every fill up."
  7. Sep 6, 2019 at 6:30 PM
    Tacomabob
    Bob
    Purchased the A/C panel on EBay used, plugged it in and it did exactly the same thing, nothing worked. Ordered the A/C amplifier, plugged it in and everything worked. Solved that issue with the help from this forum, thanks so much.
    chassis likes this.
