New Whip but a Problem!
Discussion in 'New Member Introductions' started by curbridin’10, Nov 11, 2020.
  1. Nov 11, 2020 at 5:33 PM
    curbridin’10
    curbridin’10 [OP] New Member
    Chadd
    2021 TRD Pro LR
    Hi All!
    Stoked to be a part of the community. I just got the TRD Pro 2021 LR and I’m obsessed with it.
    st Pete Florida - just a little bit of rain here right now!
    I had shifted it over from H2 over to L4 to try it out with all the rain but when I was trying to shift it back, I was getting a few error codes popping up and so I’m not sure what to do. Trac off, check engine and triangle with exclamation point.
    Should I take it to the dealer or is this an easy fix? I just bought it on Saturday...
    Looks like a great community and looking forward to interacting with everyone here soon.
    chadd
    Bob likes this.
  2. Nov 11, 2020 at 5:38 PM
    You go straight to 4L while in gear?
  3. Nov 11, 2020 at 5:38 PM
    You shifted into 4LO on pavement?
    2HI is for pavement.
    4HI is for slippery conditions; snow, mud, ETC.
    4Lo is for low speed maneuvering in low traction situations.
    How fast did you go in 4LO?
    Edit: you can engage 4LO and go straight and slow on pavement to test the system. You should never drive on pavement in 4HI or 4LO unless its very slippery.
    2Toys and A&P like this.
  4. Nov 11, 2020 at 5:46 PM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    I wasn’t in gear when I switched to 4L
  5. Nov 11, 2020 at 5:47 PM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    Welp, I’m a dumbass then. I probably went 40 or so in 4LO which I’m guessing is very bad.. Guess I’ll take it to the dealership and see what they say?
    A&P and Thatbassguy[QUOTED] like this.
  6. Nov 11, 2020 at 5:53 PM
    Dark Knight
    Dark Knight Get off my lawn
    Read your damn manual chadd.
    :popcorn:
    2Toys, A&P, CMark and 4 others like this.
  7. Nov 11, 2020 at 5:57 PM
    I don’t think you did anything by driving it, it may be how you tried to shift into 4 low, did you come to a complete stop, put it in N with your foot on the brake?
    DRobs, 2Toys, A&P and 2 others like this.
  8. Nov 11, 2020 at 6:00 PM
    Yes. Get it looked at. Hopefully it's not serious.
    4LO changes the gearing in the transfer case for maximum torque. It should never be used at high speed.
    As others have mentioned, if you didn't follow the procedure in the manual to engage and disengage 4LO, you might have just caused the computer to have a brain fart.
    Let us know what you find out.
  9. Nov 11, 2020 at 6:06 PM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    Gotcha, I did follow the instructions in the manual to switch it from L4 to H4 then H2.
    Appreciate the guidance! Will circle back once I go there tomorrow to have it looked at
    2Toys, A&P and Thatbassguy like this.
  10. Nov 11, 2020 at 6:10 PM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    Last dumb question, should I tell the service department exactly what I did since it’s under warranty or am I backing myself in to a corner if I do that?
    A&P, 7385 and Thatbassguy like this.
  11. Nov 11, 2020 at 6:16 PM
    That's a tough question. You might be better off leaving out some details.
    A&P, Jynarik, 7385 and 2 others like this.
  12. Nov 11, 2020 at 6:40 PM
    CMark, keroque, Toy4X4 and 2 others like this.
  13. Nov 11, 2020 at 6:47 PM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    :annoyed:
    7385 and nimby[QUOTED] like this.
  14. Nov 11, 2020 at 6:49 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Good luck!
  15. Nov 12, 2020 at 2:25 AM
    Welcome from Wisconsin! Hope you get it figured out.
  16. Nov 12, 2020 at 3:13 AM
    jvinhj240
    jvinhj240 New Member
    Ben
  17. Nov 12, 2020 at 4:10 AM
    SCMountaineer
    SCMountaineer New Member
    Upstate South Carolina
    In the OP's defense, I think they ought to do a much better job of explaining the 4WD system when you buy them. When I bought my first one, I knew I needed to run it in 4WD once a month to "exercise" the system, but didn't know that dry pavement was a no-no. Naturally, it sounded like I threw marbles in a blender when I cranked a hard right into a dry parking space.
    A&P, Thatbassguy and 7385 like this.
  18. Nov 12, 2020 at 4:44 AM
    I was thinking of recommending this, but I didn't want to encourage it in case it would cause more trouble.
    I'm not sure how long this actually takes, but it can be sped up by removing BOTH terminals and touching the cables together. This will reset the computer, deleting the codes. It they come back, then there is actually a problem.
    I learned this when my '03 went into limp mode after hitting a deep slush puddle too fast.
    A&P and 7385 like this.
  19. Nov 12, 2020 at 4:46 AM
    jvinhj240
    Ben
    Exactly right. Shouldn't cause any trouble just reset all modules. Touch both terminal is a good recommendation too.
    A&P, 7385 and Thatbassguy[QUOTED] like this.
  20. Nov 12, 2020 at 6:30 AM
    ATrn
    ATrn New Member
    2018 4runner TRD Off Road
    Welcome!
  21. Nov 12, 2020 at 6:45 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Why is that the dealership’s responsibility?
    When you buy a sports car, do they make you go drive a track to learn how to handle the power?
    thirdyota likes this.
  22. Nov 12, 2020 at 10:40 AM
    curbridin’10
    Chadd
    2021 TRD Pro LR
    Alrighty, so GREAT news to report and lesson learned to not make that mistake again.
    I took it to the dealership and they said one of the speed sensors was off, so when I shifted it, it produced those errors codes because of it.
    Everything is all good and no issues with the car as a result. Needless to say, she’s staying in H2 until further notice :p
    Thanks for all the sound advice and the well deserved roasting!
    WizzMcFly, Red_5, 7385 and 9 others like this.
  23. Nov 12, 2020 at 10:45 AM
    jvinhj240
    Ben
    Really great news. Whatever dealer said "_)
  24. Nov 12, 2020 at 11:16 AM
    Good to hear! Thanks for being a good sport!:D
    A&P and nimby like this.
  25. Nov 12, 2020 at 11:43 AM
    Goes to show even the assembly techs in Japan can let their mind wander on the job...congrats on the easy fix!
  26. Nov 13, 2020 at 11:35 AM
    SCMountaineer
    They don't make you, but any of the ones I would consider at least offer something like that.
    Trail Runnah and A&P like this.
  27. Nov 13, 2020 at 1:00 PM
    jvinhj240
    Ben
    Aren't salesman suppose to show you features? so they show you how nice the engine, radio buttons, and no time to show you how to engaged 4Hi, 4Lo, 2L. NOT EVERYONE driving manual 4WD. There are females buying 4runner, now they expect everyone knows how to engage manual 4WD. Don't' Sellman ask you first: hey, what do you use this for? towing, trailing ect? They can go on about how powerful these rigs can do but not once talk about how they work and expect all customers know what to do with it. They would walk thru the whole car show you everything except that. Yes sure this is almost the most important break down in powertrain and yes salesman does not suppose to tell their product capable of doing.
    "When you buy a sports car, do they make you go drive a track to learn how to handle the power " <<not even correlation. SO buying OFF-ROAD, you suppose to go to trails and test drive -now engage all you want with it. Then come back, hey your transmission is F___. I am buying Subaru now.
    7385, A&P, Toy4X4 and 1 other person like this.
  28. Nov 13, 2020 at 1:04 PM
    Dark Knight
    Biggest problem is the sales people don’t usually know how the 4wd system works.
    Unless it’s a veteran sales person who actually gives a shit, a car sales person is usually shit.
    7385, 2Toys, A&P and 1 other person like this.
  29. Nov 13, 2020 at 1:06 PM
    jvinhj240
    Ben
    Correct. Then we're not supporting the fact they wrong. When we say salesman its dealers.
  30. Nov 13, 2020 at 1:09 PM
    Dark Knight
    The whole car sales culture needs an overhaul
    A&P, Toy4X4 and jvinhj240 like this.
