New member needing help on needle bearing issue
Discussion in 'New Member Introductions' started by Graymandude, Feb 16, 2020.
  1. Feb 16, 2020 at 3:50 PM
    Graymandude
    Graymandude [OP] New Member
    2014 Blue 4RUNNER
    Grille guard with LED’s, roof rack, running boards, custom floor mats
    Hey everyone,
    I’m a new member and have searched the threads on my 4Runner issue but thought I would share my experience to date and hope someone else can share any advice or info they may have.
    As experienced by other owners I started getting the noise and vibration in 2WD on my 2014 4Runner. It started around 30K miles and happens mostly between 30 and 40mph. After new tires, wheel bearings checked and other obvious fixes, I was still having the issue. I took it to my local Toyota dealer and explained the problem and after keeping it overnight they too noticed the problem. They told me there was a Technical Service Bulletin (TSB) for the issue - front differential needle bearing, but my vehicle was out of warranty and it would cost $5,000 to fix in addition to the $250 to diagnose the problem!! Not feeling good about this I took it to another a Toyota dealer 30 miles away and explained my dilemma. They diagnosed the same problem but gave me another option - an after-market bearing that showed success on other vehicles, particularly Tacoma’s and 4Runners, and usually with a lift kit (mine does not have one). Because this was $400 vs $5000 I opted to try it. No success!! I’m still having the noise/vibration, maybe even a little more now. The technician said it’s not a safety issue so there was no recall, but I don’t see how vibration (rattling my dash), and grinding noise doesn’t cause long-term problems. I’m out $650 so far with nothing to show for it. How on earth does a needle bearing fix cost $5,000 - as quoted by 2 dealers? Does anybody have ideas, solutions or suggestions? I’m at my wits end with this! Thanks!!!!
    Pinay likes this.
  2. Feb 16, 2020 at 5:01 PM
    Bob likes this.
  3. Feb 16, 2020 at 7:17 PM
  4. Feb 16, 2020 at 7:37 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    You should still be under powertrain warranty and this is a warranty issue. I successfully had mine replaced at....mmm....46-50k IIRC... it was after bumper to bumper warranty for sure. Dealer rejected the claim the first time and charged me $100 diagnostic, after some back and forth they covered it and reimbursed me. You'll have to get the dealer to warranty it and then complain to that same dealer for restitution after it's fixed.
  5. Feb 16, 2020 at 7:45 PM
    Good point! Powertrain should be 5 years/60K if I'm not mistaken.
  6. Feb 16, 2020 at 9:13 PM
    Graymandude
    2014 Blue 4RUNNER
    Thanks so much for the suggestions so far, I will do some more digging. I’ve always taken my rigs to the dealer for work, is there a difference or advantage to taking it to a local shop with a certified Toyota mechanic?
  7. Feb 16, 2020 at 9:23 PM
    Braves95
    Braves95 New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    Cheaper. What side did they replace? Is you runner ALL TIME 4wheel drive? Or is it non limited?
    But yes should try the bushing and get rid of the bearing. I was going to do it to mine but was told by ECGS that the limited's do not have the bearing and no need to change.
  8. Feb 16, 2020 at 9:33 PM
    Graymandude
    2014 Blue 4RUNNER
    Mine is not the Limited, just the SR5 model with 4WD but not all-time 4WD. Other than the front needle bearing they did not specify a side. I like the idea of the bushing replacement instead though. Thank you for the info!
  9. Feb 16, 2020 at 9:37 PM
    Braves95
    Braves95 New Member
    David
    None Yet!!
    The needle bearing that needs replaced is the driver side. For some reason no need to change the passenger side. Get the bushing, seal. Some people on here will lend the removal tool to you. If you do it put the bearing in the freezer it will shrink it enough to install a little easier.
  10. Feb 16, 2020 at 9:41 PM
    Graymandude
    2014 Blue 4RUNNER
    Good advice, will definitely look into this!
  11. Feb 18, 2020 at 6:28 AM
    Pinay
    Pinay New Member
    Monet
    2015 Tundra - SR5 - TSS - 4X4 - Blaaack 2010 Tacoma
    Welcome from SoCal!
  12. Feb 28, 2020 at 5:39 PM
    Georgia Native
    Georgia Native New Member
    2019 OR Prem and 2017 Tacoma SR5 4x4
    I replaced the needlde bearing with the ecgs bushing on my tacoma. It is pretty straight forward.
