New Member/Cold Weather Oil Weight
Discussion in '5th Gen 4Runners (2010-2024)' started by CJTrail5thGen, Nov 11, 2019.
  1. Nov 11, 2019 at 9:03 AM
    CJTrail5thGen
    CJTrail5thGen [OP] New Member
    Hello,
    I recently just bought a 2016 4runner trail premium in Reno, NV. I have a question about oil weight in extreme cold temps. My husband and I are preparing to make the trek back to our home in Alaska in January. Temps on the AlCan highway around this time of year will drop to around 20 below if not colder. I plan to have a block heater installed before we go. In Reno, I have been running the standard 0/30 Synthetic. Do any of you suggest that I switch to a 5/30 for this drive? Any other suggestions for the severe cold weather?
  2. Nov 11, 2019 at 9:11 AM
    standard is 0W-20
    I'm assuming people in cold temp warm up before going.
    WallyT4R and KSJ08 like this.
  3. Nov 11, 2019 at 9:12 AM
    CJTrail5thGen
    Yes, you definitely warm up the engine before going anywhere.
  4. Nov 11, 2019 at 10:40 AM
    CJTrail5thGen
    That is very useful information. Thank you so much!
    KSJ08 likes this.
  5. Nov 12, 2019 at 4:25 PM
    Tuco S.
    Tuco S. New Member
    There are many good options in 0W-20. Toyota Genuine Motor Oil (TGMO) is never a bad choice, and might be ideal for your application (runs thin, flows well in cold temps), but there are plenty of others which cost less. If an oil meets the ILSAC GF-5 spec, it should work fine.
    WallyT4R likes this.
  6. Nov 12, 2019 at 5:40 PM
    Tuco S.
    Tuco S. New Member
    Yeah Pennzoil is another good choice. I'm currently running bargain priced Havoline in mine, and have a stash of several others to try just for fun (Mobil 1 AFE, Rotella Gas Truck, QSUD, PP, Castrol Edge). I doubt I'll notice much of a difference in performance between any of them. As I said there are plenty of good choices available. I personally see no reason to pay up for TGMO since I live in Las Vegas, but if I lived in a cold climate I would want a thin 0W-20, and TGMO is one of the thinnest ones available.
  7. Nov 13, 2019 at 4:05 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Run the weight your vehicle recommends...Period... Brand well I ain't going there.
  8. Nov 13, 2019 at 5:12 AM
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    As said above there is no reason to run any higher weight than Toyota’s recommended weight of 0W20. I would wager that Toyota’s engineers know 99.5 percent more than us. Additionally there hasn’t been a rash of failed motors due to using 0W20 so in my opinion there is no reason to question its use. As far as brand is concerned any brand will get you to 200k. However in very cold regions I would stick in TGMO 0W20. I found (admittedly I don’t have any scientific proof to support my claims) that TGMO is one of the quietest oils at startup and slightly quieter during normal operation. So for 8 bucks a quart I will stick with it and I only change oil once a year. And allegedly the new formula has more moly which from my understanding is better for the engine...but I could be wrong and not sure how’s that affects cold start up.
    j cat likes this.
  9. Nov 13, 2019 at 7:00 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    Toyota engine oil spec is 0-20wt.. since your concerned about this vehicle you should get the vehicle manual to know what fluids to use. when you have fluids changed and when to change them the manual will give you the proper info.. make sure the service people will use the proper fluid spec...
    TOYOTA ENGINE OIL IS WITH SPECIAL ADDITIVES .. this will work best in harsh conditions. moly is in the TOYOTA oil 800PPM.. mobil 1synthetic has 60PPM .. this additive will cause the engine to start crank faster and lower engine noise on a cold start.. also higher MPG ..
