New battery suggestions
Discussion in '5th Gen 4Runners (2010-2024)' started by sherwood4runner, Jan 7, 2024.
  1. Jan 7, 2024 at 9:43 AM
    sherwood4runner
    sherwood4runner [OP] New Member
    2018 4Runner OFP
    Icon Stage 2 w/ SPC UCA, Spidertrax wheel spacer, Magnaflo exhaust, K&N CAI, Xenon Depot Full LED upgrade, Pedal Commander, Ridge Grappler 285x70x17, SCS Ray 10 Matte Gunmetal 17x8.5 w/-10mm offset, Full tint, Husky Liner floor and cargo mat, Morimoto XB headlights, Depo taillights, Diode Dynamic SS3 SAE Fog Lights
    I’ve been looking to replace my factory battery with something better. I don’t have a lot of accessories hooked up and not looking to mod the battery location.
    Any suggestions on a direct replacement that fits that would be a better option than the Toyota replacement? Thanks.
  2. Jan 7, 2024 at 9:49 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    If you can get the same battery they are pretty good. I believe they are a Panasonic?
    AGM batteries are "better" but they require a trickle charge now and then and a voltage booster since they have more capacity. I was impressed with my Odyssey 24F AGM
  3. Jan 7, 2024 at 10:21 AM
    Daddykool
    Better in what way? Have you experienced trouble with your factory battery? My 2019 has about 130k miles and is on the original battery. Still strong, but going to replace it on a preventive basis. Going with a factory battery again because how much better could a different one be?
  4. Jan 7, 2024 at 10:49 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    If you just need a battery to start the truck, the Panasonic is hard to beat. They’re super expensive if you can even find them.
    Costco has pretty good OE sized replacements and they have an AGM 24F if you’re looking for something with more Ahs. Just be aware that the alternator will not keep an AGM healthy on its own.
  5. Jan 7, 2024 at 11:00 AM
    wdsteven
    wdsteven New Member
    I been using the Duracell Batteries for 6 years now in my Boat and my Tundra not the 4Runner yet however No issues with them the 4Runner takes a group 24F and the factory one is 600 CCA where the Duracell is 890 CCA there are 2 different levels you can get depending on budget, first one is regular at $139.88 then the AGM one is $199.88 and that has 825 CCA.
    Technologic80 likes this.
  6. Jan 7, 2024 at 11:12 AM
    My original battery lasted 9 years/146k miles. I'm not sure there is a "better" battery available aftermarket.
    If it ain't broke, don't fix it.
    TRDPro19RN, photo8, SlvrRnnR and 3 others like this.
  7. Jan 7, 2024 at 12:39 PM
    scottiezilla
    scottiezilla New Member
    Can’t get the Panasonic in the states I believe
    just ditched mine at 75K but that’s cause I’m adding stuff now
    it was starting to dimmer down
    Sometimes horrible
    Sometimes great
    But it was time
    ‘16 so 7/8 years
  8. Jan 7, 2024 at 1:57 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I'm on my 2nd replacement battery. After the factory one, I replaced it with an 8 yr. old Optima Red-Top and now have an Interstate AGM from Costco. I kept the Optima and is currently on a shelf with a 3/4 amp charger.
  9. Jan 8, 2024 at 11:23 AM
    3JOH22A Toyota Gigolo
    Optima Red Top 35 will save 15-20 lbs compared to the stock battery while maintaining the cranking power. The battery has a lower height than stock, so you will need a replacement hold-down bar to avoid using the dodgy plastic spacer that comes with the battery. 1st gen Toyota 86/Subaru BRZ hold-down bar works; you can find those for cheap on eBay.
  10. Jan 8, 2024 at 12:07 PM
    I'm more likely to buy a Walmart lead acid battery when my factory battery gives problem.
    When tested my alternator doesn't have enough voltage to charge a AGM battery and I'm not willing to alter that by installing any kind of voltage booster.
    JET4, icebear and Trail Runnah like this.
  11. Jan 8, 2024 at 12:11 PM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    I purchased an Energizer AGM (group size 78 tho) for my other SUV this weekend and was impressed that after getting it home, and bringing a meter to the posts, it was resting at 12.9v. Unusual for a battery sitting on a shelf that doesn't get randomly trickle charged..... date code was 9/23 too. Anyways, was $199 with a 3 year warranty, $20 core charge.
  12. Jan 8, 2024 at 12:39 PM
    Had a battery die with no warning in a previous car (started fine in the morning, dead as a door nail in the afternoon) and had to get a boost from a coworker. I now replace batteries preemptively every 5 years before the winter.
    I've had regular flooded batteries spill acid from the vents just transporting them a few city blocks in the footwell of a car. I strongly recommend an AGM sealed battery for off-road use. The flooded battery would still work after spilling acid, but your inner fender area may get heavily corroded. The plastic tray under the battery is Toyota's solution to spilled acid...
  13. Jan 8, 2024 at 12:42 PM
    I am running the odyssey thing...but I am not impressed. It has lost its charge after 3 weeks of me not using the 4R, and I have to jump it, this in two different occasions. Maybe I got a bad one but I don't think I'll use this again. Panasonic is what I will try next.
  14. Jan 8, 2024 at 12:45 PM
    Ripper238
    2019 TRD OR
    Odyssey batteries are awesome, but you need a voltage booster and trickle charge it now and then. They are designed for capacity and charge differently.
  15. Jan 8, 2024 at 1:04 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I think it really depends on where you live, and that should be taken into consideration. For example: I live in Tempe, AZ. As you can see the life expectancy of batteries here is LOW. I buy mine from Costco, they are Interstate. I've only bought one because they need to be replaced every 2 years. The heat absolutely kills batteries. Costco replaces every time for free. No questions asked. Seems like I'm scamming them, but:notsure:.:yes:
    2ndGen22re, 3JOH22A and Toolguy73 like this.
  16. Jan 8, 2024 at 1:47 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    JET4 and kmeeg like this.
  17. Jan 8, 2024 at 2:26 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Elka 2.5, Apache Offroad UCA, durobumps, RCI full skids, RSG sliders, 10 lb Powertank, Maxtrax, Hi lift jack, Westscott Designs modular roof rack and ladder, ARB rear diff breather relocate, ECGS bushing upgrade, c4 low profile bumper, Baja designs S8 lightbar, warn evo winch, factor 55 ultrahook
    Costco just changed the battery replacement policy to be pro rated. It was too good to be true. Had to buy a battery last week and they made sure to tell me of the change
    icebear and 3JOH22A like this.
  18. Jan 8, 2024 at 2:54 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    I was wondering when that was going to happen. Still a good deal if I'm replacing often, I think...
  19. Jan 8, 2024 at 3:13 PM
    Durango Dave
    Durango Dave New Member
    Durango, Colorado
    2023 4Runner Off-Road Premium w/ KDSS
    I've had good luck with Optima Red Top batteries which are AGM and I've never had to do any special charging with them in several different vehicles :confused: I like the fact that they are sealed so you never need to check the water level and as I recall the spacer that came with mine went under the battery (on the battery tray) so I could use the original battery hold-down hardware :) Here it is installed in my 2015 Trail Premium:
    3JOH22A likes this.
  20. Jan 8, 2024 at 3:14 PM
    This is actually what I went with when I replaced my battery last November. No issues so far, and this battery actually did quite well in Project Farm's battery comparison test a couple years ago.
    kmeeg[QUOTED] likes this.
  21. Jan 8, 2024 at 4:33 PM
    nova
    nova New Member
    mike
    I see a Noco in your future :sorry:
  22. Jan 8, 2024 at 4:46 PM
    steelevo
    Utah
    Costco battery is my vote also. Easy returns when needed.
  23. Jan 13, 2024 at 4:01 PM
    icebear Recovering Kia Owner
    I saw a discussion thread somewhere on Reddit where someone was being trashed for expecting a 36 month warranty to mean that they will receive one unit that lasts 36 months (like your situation and that is generally my expectation too since replacements sometimes explicitly have a lesser warranty) rather than a 36 month warranty meaning that it’s a guarantee of having something working 36 months of service only. (so if a warranty replacement dies within say, a month, but made it past 36 months of original purchase you’d be SOL)
    Guess it varies on the fine print.
    On a similar note, Shark Ninja’s warranty is a lie and you have to argue to get it (but well, I did get the part I was entitled to for free after arguing and they kept dropping the price multiple times) but don’t buy their things. (no the entire vacuum is not a “consumable” like a “filter”)
