New AC belt squeaks against pulley no matter how much tension I put on it
Discussion in '3rd Gen 4Runners (1996-2002)' started by Trekker, Jan 24, 2025.
  1. Jan 24, 2025 at 4:27 PM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    I replaced my belt a month ago and the AC belt wont shut up. When I spray the belt with soapy water the squeak goes away for 20 seconds. I can repeat the noise with the car off just by pulling and pushing the belt.
    I think it was too loose, so I tightened the pulley but it still hadn't gone away by the time the tension started making my pulley bearing start squeaking under the strain.
    I used a Toyota belt. What is going wrong?
  2. Jan 24, 2025 at 4:51 PM
    You sure it’s not the tensioner?
  3. Jan 24, 2025 at 5:02 PM
    Either the tensioner, another pulley or its not aligned but could be caused by the tensioner or another pulley.
  4. Jan 24, 2025 at 5:22 PM
    Up, down and all around!
    Sounds like you found the source of the problem.
  5. Jan 24, 2025 at 6:05 PM
    Trekker
    1997 3rz 5spd
    I don't think it's misalignment because the belt squeaks when I push it against the pulley by hand. Can I spray it with something to make it be quiet?
  6. Feb 26, 2025 at 4:31 PM
    KrazyKarl
    KrazyKarl New Member
    1998 Desert Dune 4Runner
    Im late to the party but I’ll throw in my two cents. The bearing that allows rotation of the AC compressor pulley might be going out…. The AC compressor itself is okay, but it is a PITA to replace the bearing and clutch on our trucks without pulling it out. Be ready to have a pair of dikes or good cutters when it seizes up because it will melt that belt off….
    PhantomTweak likes this.
