New 2021 TRDORP incoming - wheel and tire questions
Discussion in '5th Gen 4Runners (2010-2024)' started by TakedownDDT, Aug 16, 2021.
  1. Aug 16, 2021 at 1:40 PM
    TakedownDDT
    TakedownDDT [OP] New Member
    Dennis
    2021 TRDORP
    Hello,
    New member here, learning a lot by reading a ton. In two weeks I'll be taking delivery of my first T4R, a 2021 TRDORP in magnetic gray. This being my first foray into the T4R world I have a few questions:
    1) stock tires - how well do they perform on roads in rain/snow
    2) I've seen more than a few posts about upgrading those stock tires. But I also want to change out the stock ORP wheels. Which would you recommend first?
  2. Aug 16, 2021 at 2:08 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I think most people would agree the stock tires never tend to be good, but I’d still get my miles out of them, then switch out. I’m willing to bet they will be fine for a year or so.
  3. Aug 16, 2021 at 2:14 PM
    Welcome to the forum!
    I would try to change both at the same time, if possible. I did the tires first because the Dunlops were awful in the snow.
    If you do the tires right away, some places will actually give you some money for them. Or, you can sell them to someone for a few bucks.
    Toy4X4 and TakedownDDT[OP] like this.
  4. Aug 16, 2021 at 2:23 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    When I put new sneakers on my taco, I did wheels and tires, and I’m glad I did it that way. After putting on the new stuff, I had an front wheel well issue, not even space in front and behind the tire. The dealership tried to tell me it was the new tires. I switch back to the factory setup, and showed them it was the same issue, just not as clear as the new tires had more meat. Then they tried to convince me the body panels moved. Well after pushing back, it was discovered after a front end accident, they (the same dealership) never did the front end alignment they said they did.
    so after that issue was cleared up, I had a wicked vibration with the new setup, so I again switched back to prove the vibration wasn’t the truck, but the new tires where out of balance even though balanced twice. And now that I am think of trading in, I can slap the factory setup back on and already have a new set for the possible new 4Runner.
  5. Aug 16, 2021 at 2:26 PM
    Pavo
    Pavo New Member
    If you plan to just drive on road stock tires are fine. My buddy is fully stock and he refused to get new tires swearing up and down they're good, he finally relented after 30k miles and getting stuck a few times in mild snow and mud
    TakedownDDT[OP] likes this.
  6. Aug 16, 2021 at 2:31 PM
    interceptor
    interceptor Crash Test Dummy
    '21 ABM Venture
    In my case, I would have done both wheels and tires at the same time, except I was satisfied with the factory rims. I felt it important to at least get the tires upgraded since I had a lift/level coming. Glad I did, because I had minor mud-flap rub issues with the new BFG KO2's (which was resolved with the lift/level). FYI it helped that Discount Tire cut me a deal and gave me some $ back for the factory tires.
  7. Aug 16, 2021 at 2:33 PM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    Just my two cents but I have an SR5 I swapped out the tires to BF good rich KO twos left a stock rims and I’m having a blast with that
  8. Aug 16, 2021 at 2:42 PM
    Regardless what people say, stock tires are just M+S so it will never be good on snow as an after market 3peak mountain snow flake rated all weather or all terrain tire. You should be able get good amount of money when you sell stock tires when they are new with Craigslist / FB market place for all 5 tires.
    My fav tire brand is BFG KO2. Next is GY Wrangler Duratrac. Third best Falken Wildpeaks.
    I absolutely love TRD ORP wheels because they are wider wheels which is recommend to use with bigger tires like 285/70R17 or even 285/75R17 (34 inch) tire. I would not recommend buying TRD Pro wheels like some do. If you ever think of changing wheels look at a good after market wheel.
    TakedownDDT[OP] and interceptor like this.
  9. Aug 16, 2021 at 2:44 PM
    Pavo
    Pavo New Member
    Most aftermarket wheels are junk, believe it or not your stock trd off road wheel is better than 99 percent of the crap out there
  10. Aug 16, 2021 at 3:09 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Why not pro wheels? That’s what I put on my taco and plan to switch over if I get a 4runner
  11. Aug 16, 2021 at 3:39 PM
    TRD Pro wheels are narrower than TRD ORP wheels. They do not meet the minimum to mount bigger tires like 285/70R17.
    Toy4X4 and Spare Parts[QUOTED] like this.
  12. Aug 16, 2021 at 6:32 PM
    TakedownDDT
    Dennis
    2021 TRDORP
    Thank you all for the feedback and intel. Very helpful as I figure out how to prioritize what I want to customize first. I’ll post pics when I pick up the new ride.
    interceptor likes this.
  13. Aug 17, 2021 at 2:25 AM
    We put upgraded tires on the factory rims at first (275-70-17 Cooper AT 3) Then we bought some aftermarket rims and moved the Cooper tires over to them. Both rims look ok, but the grass is always greener..... right? Here's pics of both. 20200807_200946[455] 4runner.jpg 20200905_161649[511] 4Runner.jpg P.S.- we sold the stock tires back to the dealer before we drove it off the lot.
  14. Aug 17, 2021 at 10:17 AM
    TakedownDDT
    Dennis
    2021 TRDORP
    Did you get the tires from the dealer? Or buy separately, deliver to dealer, have them install and work out a deal for the stock rubber? And why go with the 275-70-17 vs the 265-70-17?
  15. Aug 18, 2021 at 2:06 AM
    We got the tires from the dealer, who got them from the tire shop close by. The dealer installed a lift and tires at the same time. We went with the 275 because of the 'E' rating, that's what we run, I'm very "anti-rock abrasion", and when we go off road that's what we encounter most...rocks. Not that 'E' rating is the best, it just affords a little more protection, at a little more weight/reduction in fuel mileage (18+)
