Need ‘03 4Runner blinker bulb help…
Discussion in 'General 4Runner Talk' started by Drumline119, May 11, 2023.
  1. May 11, 2023 at 5:07 AM
    Drumline119
    Drumline119 [OP] New Member
    2003 4Runner SR5 v8 205k
    One of my blinker bulbs went out, so thought I would research the neat LED options on Amazon. I did some research, and Amazon told me I had the right products for “front” and “rear” bulbs; since supposedly they are different sizes. (?)
    See attached photos. The “A” option didn’t fit the front socket, but seems to fit the back socket just fine; heard a solid click-sound. The “B” option kind-of fit in the front socket, but no click-sound… And, when I now test all four blockers, I’m getting the rapid-blinking all around; which tells me there is still a problem… :(
    Can anyone confirm which Amazon LED “front” blinker bulb size I need to make everything right?
    Thank you.
  2. May 11, 2023 at 2:28 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    A lot of the time, LED bulbs in a non LED flasher system will cause the "fast-flash problem. The resistance of the bulbs is so much lower, that the flasher unit sees them as a short circuited bulb. Thus, it gives the fast flash.
    You can get a resistor to install into the circuit. Just what the resistance is needed, I don't know. You'll need to do a little research on line to find that. Just check with the company that makes the LED bulbs. Often, they have the resistance required, or even sell the needed resistors. If not, once again, a little research will give you the answer. Sometimes, you can even find a flasher unit that fits your vehicle, and is designed for LED bulbs. Worth a check, anyway.
    Hope this is a small help...
    Pat☺
  3. May 12, 2023 at 6:44 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Pull you flasher relay, see how many pins are on it and then order an LED flasher relay. Like one of these.
    https://www.amazon.com/5-Pin-Waterp...=&hvlocphy=9033087&hvtargid=pla-1640199765490[/QUOTE]
  4. May 13, 2023 at 7:36 AM
    Drumline119
  5. May 13, 2023 at 7:41 AM
    4scooter19
    Oregon
    98 and 86 4Runners
    Hi 4scooter19. Below is an image of my control area. Can you help me ID which one to pull? I am an armature at this... Thanks you.
    [/QUOTE]
    I have older 4runners so I am not sure of the relay location on the 4th gens. It's probably in the fuse block under the hood or up under the left side of the dash. I would reference your owners manual or turn your blinker on and listen under the dash for the relay clicking.
  6. May 13, 2023 at 2:30 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    The "Flasher" for a 2003 T4R is not design for LEDS, that is why you're getting the "Hyper-Flash" effect, you need to replace your flasher for one that is compatible with LEDS.
    I'm not sure but I think the flasher is behind the fuse panel in your photo, but as mentioned turn on your blinkers and listen for the sound of the flasher to locate it.
