Need to replace the fuel pump assembly. Recommendations?
Discussion in '4th Gen 4Runners (2003-2009)' started by Rocketdog, Jun 29, 2024.
  1. Jun 29, 2024 at 9:14 PM
    Rocketdog
    Rocketdog [OP] New Member
    2005 4Runner Limited 4.7L
    None
    2005 Toyota 4Runner Limited 4.7L (Wife's)
    Well, after 265,000+ miles the fuel gauge sending unit finally crapped out.
    With the high mileage involved I figure it's best to replace the entire assembly versus trying to repair it.
    Looking online, dealers are in the $600 range for an OEM replacement. Aftermarket is slightly cheaper for a known brand name such as Delphi and Carter.
    Are there any other recommendations I should be looking at or just bite the bullet and go with OEM?
  2. Jun 30, 2024 at 5:28 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    I would try and find a Denso fuel pump assembly, Denso is the OEM supplier for Toyota, you get an OEM part but without the Toyota name on it or the Toyota price.
  3. Jun 30, 2024 at 6:49 AM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    I recently did the the fuel pump and sending unit on my 2004 4.7, not the entire ‘assembly’ though. OEM Toyota parts for both. It was like $300ish for parts and $300ish for labor. Now fuel gauge is working flawlessly and I have a new fuel pump. Just another option besides doing the entire assembly.
  4. Jun 30, 2024 at 11:58 AM
    Rocketdog
    None
    I have read that the plastic carrier has a secondary internal filter. What did you do about that?
    gkomo[QUOTED] likes this.
  5. Jun 30, 2024 at 12:11 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    Ok sorry, for one I was off on my parts amount and two I did purchase the filter as well… here’s what I bought:
    (the ignition coil was just to have a spare one on hand)
    Labor was $363 if I recall.
  6. Jun 30, 2024 at 1:28 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 260K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Had my fuel sending unit replaced in June 2022 and did the fuel pump for good measure while the tank was out. from the other forum has a lot of info that may be helpful.
  7. Jun 30, 2024 at 1:50 PM
    Rocketdog
    None
    That secondary filter was my concern. They don't show up as a separate component on the parts breakdown.
  8. Jun 30, 2024 at 2:13 PM
    Bluesky 07
    Russell
    Northern Georgia
    The p/n for the housing is in my post and it’s not very expensive.
    Rocketdog[OP] likes this.
  9. Jun 30, 2024 at 2:34 PM
    Rocketdog
    None
    So...
    Fuel pump and strainer kit...$130 (Denso)
    Fuel level sending unit.. $80 (OEM on eBay)
    Secondary filter housing... $35 (OEM on eBay)
    Gasket/O-ring... $13
    I'm looking at $260 give or take to rebuild the fuel pump assembly.
    Strange though. When i input 23300-50120 for the secondary filter housing, Toyota parts show it does not fit a 2005 with the 4.7L.
  10. Jul 21, 2024 at 11:20 AM
    Rocketdog
    None
    Well, removed fuel tank and pump assembly today and nothing but the level sending unit matches up.
    Maybe there was a change up sometime during production?
    Should have just spent the $600 on a new replacement unit.
    RonT4R likes this.
