Need some ideas for upgrading my 4 runner.
Discussion in '5th Gen 4Runners (2010-2024)' started by JROutdoorMedic, Aug 11, 2024.
  1. Aug 11, 2024 at 10:47 AM
    JROutdoorMedic
    JROutdoorMedic [OP] New Member
    2022 TRD Off Road in Barcelona Red
    Hi Y’all,
    Was looking for some ideas to upgrade the look of my 4Runner without breaking the bank. I’ve upgraded a Jeep wrangler before but really have no idea where to start on the 4 runner. Any advice is helpful. Thanks.
    JR
  2. Aug 11, 2024 at 11:02 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Definitely Raptor lights. They add 150 HP. And a cute widdle wadder on the rear. Cause there's no way you can climb onto the bumper to see the roof.
    Seriously, @JROutdoorMedic there are hundreds of thing to do. It all depends on what you want to achieve. The 4R is a damn capable vehicle without doing anything. I think you'll find most people will say tires and suspension are the first things. But, do consider what you will primarily be using your 4R for before pulling the trigger on any mods.
    scurvy, 2Toys and jeepster09 like this.
  3. Aug 11, 2024 at 11:04 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Not much different than upgrading a Jeep. First decide what your goal for vehicle is, then go for it. Looks? Off road use?
    nova and icebear like this.
  4. Aug 11, 2024 at 11:18 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Tires, skid plates, sliders, then wait to find your next hard limits (assuming you want upgrades for off-road use).
  5. Aug 11, 2024 at 11:20 AM
    david9962000
    david9962000 New Member
    Los Angeles, CA
    Tires,
    WilVis and Slopemaster like this.
  6. Aug 11, 2024 at 11:25 AM
    JROutdoorMedic
    What about a viper cut? Yes or no. I do have access to a dremmel and angle grinder. What benefits if any does it provide. Tires are def on the list, my rig has street tires. I’ve definitely thought about upgrading to a prinsu roof rack but am reluctant to pull trigger cuz I want to get a Yakima roof box cuz I am usually driving places with a lot of gear.
  7. Aug 11, 2024 at 11:33 AM
    You need ideas? Hell, just give me your CC and I'll buy you about $5k in mod's & accessories.
    Aftermarket LED Headlights.
    Aftermarket LED Tail lights.
    Rock Rails.
    Puddle lights.
    Front Steel bumper with lights & a winch.
    Black out kit.
    LED Interior light kit.
    Padded center arm rest.
    Window Tint.
    Roof rack - Prinsu?
    Upgraded tires: Falkens or KO3's.
    Trail Grid Pro speaker upgrade - Kickers.
    Interior floor mats front & rear.
    Cargo area protector, with rear seat back option.
    Molle Panels for rear windows w/accessory bags.
    Slide out cargo tray.
    Automatic light control sensor mod (This one is great and very cheap).
    FitCamX Dashcam
    Interior blackout kit (for door handles - You can also black out the knobs).
    LED footwell lights.
    A lift (that's up to you though)
    Aftermarket grill - Swap out the oval for the "Toyota" one.
    Okay, that's a good start. Now, go max out your credit card and stand at the front door smiling like an idiot when the Amazon/UPS man shows up. :)
  8. Aug 11, 2024 at 11:35 AM
    My goal is simple: To look damn cool in the parking lot of my work and at the mall. I crawl hard at the mall.
  9. Aug 11, 2024 at 11:37 AM
    JROutdoorMedic
    lol. You might have a good point.
  10. Aug 11, 2024 at 11:43 AM
    Here's some education for ya': https://trail4runner.com/2022/10/18/viper-cut-how-to-step-by-step-guide-5th-gen-4runner/
    The above link will answer and discuss the following:
    Here are the Pro's/Cons:
    Pros:
    • Added clearance for improved approach angle.
    • Added clearance for larger tires.
    • Customization
      • There are so many types of viper cuts out there, with different measurements, and different slopes.
    • For Instagram users, it’s going to improve your total number of likes and comments by at least 15%.
    • When it comes to adding a LoPro that has Stage 2 options, you are already more than halfway done with your chop.
      • My cut is not as high up because the Southern Style Offroad and C4 Fabrication Stage 2 cuts are so different. SSO’s cut is lower and C4’s cut is higher. I went with the former because I still have both options when it comes to adding a bumper and Stage 2s. You can read more about that here.
    Cons:
    • Your washer fluid reservoir will become exposed.
      • Not doing so will allow debris to break through your plastic reservoir.
    • There is no going back unless you order a new bumper.
      • You can see an example here, although it isn’t exactly what we’re talking about here.
    • If you are planning to have an SSO LoPro but you cut too high, you may be S.O.L. C4 will be your only option when it comes to Stage 2s as their cut is higher.
  11. Aug 11, 2024 at 1:09 PM
    Beachguy
    2024 TRP ORP
    Stickers man. Lots of stickers.
  12. Aug 11, 2024 at 1:27 PM
    Be careful, if say the word stickers three times, then @djwantke shows up!
  13. Aug 11, 2024 at 1:46 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    265/70/17 BFG AT KO2/KO3
    /mic drop
    4Hopper and BC Hunter like this.
  14. Aug 11, 2024 at 2:10 PM
    TrailSpecial22 New Member
    PA
    imo: suspension, good set of AT tires (Falken or Mickey Thompson) body armor (steel front or rear bumper or both) if your wallet can take the hit.
  15. Aug 11, 2024 at 2:41 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Nailed it!
  16. Aug 11, 2024 at 7:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    You called!?
    dgrenier15 likes this.
  17. Aug 11, 2024 at 7:48 PM
    Welcome here!! @JROutdoorMedic
    Great question, and the perfect place to ask it.
    1. If your off-road 4R has KDSS suspension, I think everyone would agree with me to highly recommend the Dr. KDSS Control Harness Kit and dash switch (kill switch to disengage the system).
    2. The 4R has inadequate towing hooks in the front end. There’s factory hooks in the front but they are tie downs for shipping and the manual specifies do not use them in emergency vehicle recovery.
    Invest in high strength Recovery Points than bolt to your frame. Brands like APEX Overland.
    Goodluck
  18. Aug 11, 2024 at 10:31 PM
    JROutdoorMedic
    So what I am gathering is,
    New tires…on order
    Steel bumper…check’s wallet
    And a prinsu roof rack to start off…
    Good thing I have fire money to spend on upgrades…now to purchase more stickers…
  19. Aug 12, 2024 at 7:25 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    just know steel bumpers can lead to new suspension (heavier springs at minimum), especially if combined with armor and/or sliders. The domino effect…
    djwantke and TrailSpecial22 like this.
  20. Aug 12, 2024 at 7:47 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Consider the weight of everything you add. I have been very mindful of this anticipating end result would be it all adds up. Going into it I hoped to not need a regear if I kept weight and tire size down.
  21. Aug 12, 2024 at 7:55 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    How about a sleeping platform?
  22. Aug 12, 2024 at 8:05 AM
    2016Pro
    Raptor litez and a chrome bar hell to the yeahs!!!
    No please don't do either of those, I'm just joking.
  23. Aug 12, 2024 at 8:09 AM
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Since this is my first 4x4 vehicle, they advised I switch into 4x4 mode every couple of months to keep the differentials lubed. Looks like this will give me a good excuse to go out into the Ocala National Forest and hit those dirt roads and the fire roads! I'd just as soon skip the mall after buying my 4Runner.
    Any suggestions on side steps for us short people? It's not a major ordeal getting in but some side rails would make it that much easier. Need something that won't rust since the beach is so close.
  24. Aug 12, 2024 at 8:28 AM
    2021venture
    Todd
    2021 Venture
    Not an issue for beach but steps are a magnet for catching stuff on trails. I have seen several get sheared off. OEM predator tube steps are aluminum and can often be found cheap as take offs if they meet your needs.
  25. Aug 12, 2024 at 9:08 AM
    All the side steps/rock rails will rust, eventually. Especially when exposed to the salt water air in Florida.
    Pick the set that best matches your budget and needs. For short people though, if your wallet can afford it, I recommend the after market power steps. The kind that the Limited has. They drop down very low, so vertically challenged people like you, can step in to the can with ease.
    If you can't swing that cost, I recommend getting a running jump.
    Jennyjo14[QUOTED] likes this.
  26. Aug 12, 2024 at 9:22 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    This looks perfect, Toyota OEM accessory, and doesn't break the bank:
    Part Number PT938-89200
    Jennyjo14 likes this.
  27. Aug 12, 2024 at 11:02 AM
    PA
    domino effect is good
  28. Aug 12, 2024 at 12:42 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
  29. Aug 12, 2024 at 12:50 PM
    PA
    As a follow up to 5thToys comment about steel bumper, my SSO slimline with full hoop was only 45-50 lbs over stock set up. Thats less than a C load tire. :)
  30. Aug 12, 2024 at 5:26 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
