Need some help.
Discussion in 'Canada' started by Novaman1975, Mar 28, 2025.
  1. Mar 28, 2025 at 5:26 AM
    Novaman1975
    Novaman1975 [OP] New Member
    I'm looking at a 2020 Toyota 4runner trd pro it has 164,000kms no accidents for
    45 thousand. Looks good and drives good. Or 2020 4runner nightshade with 92,000kms no accidents clean and drives excellent for 45 thousands.
    I don't know which way to go?
  2. Mar 28, 2025 at 5:48 AM
    welcome, only you can decide that.
  3. Mar 28, 2025 at 5:50 AM
    Novaman1975
    What kills me on the TRD Pro is the Kms
  4. Mar 28, 2025 at 5:53 AM
    With proper care will last 300,000 plus miles
  5. Mar 28, 2025 at 6:11 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    That’s a lot of miles in 5 years - go with the limited imo
  6. Mar 28, 2025 at 6:19 AM
    dan777
    dan777 New Member
    Dan
    South Jersey
    19 ORP
    If you’re going to go off-road often go with the Pro. If not go with the limited. Too much work needs to be done to make the limited as capable as the Pro off-road.
    1SilverRunner likes this.
  7. Mar 28, 2025 at 6:29 AM
    Novaman1975
    Thanks for giving me advice. Here are some pictures.
  8. Mar 28, 2025 at 6:39 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Typically I'd avoid the limited but if you're mainly on pavement it will still be capable for occasional trails. (XREAS problems aside)
    If you intend to off road, having the rear locker will be worth the price difference imo. I'd hold out for a TRD Off Road or a Pro but that's specifically to avoid the hassle of XREAS, better approach and departure angles, and a rear locker. None of which matter if you don't intend to hit the trails much.
    So the choice is yours to make!
    dan777 likes this.
  9. Mar 28, 2025 at 7:38 AM
    Novaman1975
    I sent pictures. They both look great It's just the kms and in the future which one will give me a better resale value in 3 to 5 years from now.
  10. Mar 28, 2025 at 7:48 AM
    kolter45
    Denver
    Which ever is the least rusty is really what it boils down too. We need to see the rust on both to make a clear choice
  11. Mar 28, 2025 at 7:56 AM
    Novaman1975
    They both have surface rust underneath. I should of taken pictures when I was there but I wasn't thinking at the time.
  12. Mar 28, 2025 at 8:13 AM
    Both will likely need shocks within your span or ownership. OEM shocks will be expensive for both (think $5k), but cheaper aftermarket ones are available.
    The Pro is overpriced for its mileage because it's a Pro. In 5 years it'll have quarter-million kms and be worth maybe $25k, while the Limited may be worth $30k. A lot of unknowns with future resale value as we may be in a severe recession at that time with severe inflation.
    (My hood deflector experienced hyperinflation after I ordered it, going from $95 to $150 in 8 days. That is 7% inflation per day, on par with inter-war Germany and early '90s Russia.)
    andrewtheadventurer likes this.
  13. Mar 28, 2025 at 8:20 AM
    Novaman1975
    Thanks that is a good advice. But I won't be driving it as putting in many kms I'm averaging about 10 to 13 thousands kms a year. I love the Pro but the kms is what's holding me back.
  14. Mar 28, 2025 at 8:45 AM
    1SilverRunner
    Tejas
    Not sure if I'd worry too much about the mileage. Look into the service history and check for rust. If both check out these things will last 500,000km no problem.
    *Yes I converted from freedom units for you... 300,000 miles = 482,803km
    PS black will be a bitch to keep clean and looking scratch free. White tends to hide small scratches pretty well...
  15. Mar 28, 2025 at 9:08 AM
    Novaman1975
    If it just surface rust and I start rustproofing now it will stop from getting worse.
  16. Mar 28, 2025 at 1:34 PM
    kolter45
    Denver
    plug both vins into the toyota owners app and look at the maintenance history
  17. Mar 28, 2025 at 4:20 PM
    Novaman1975
    Kolter45 thank you so much. You are my Angel in the sky. The 2020 Toyota TRD Pro the carfax says no accidents, no issues. I looked up what you sent me it says there's 25 problems and the black 4runner it say 0 problems. How these people cheat the carfax.
    Unbelievable with theses Bananas.
  18. Mar 29, 2025 at 3:38 AM
    Welcome. these were gotten rid of for a reason with that high of odometer ticks. The limited may be the better choice, just to not pay for the pro badge and problems you found.
