Need new front skid plate to simplify oil change?
Discussion in '5th Gen 4Runners (2010-2024)' started by GeoW, Apr 22, 2021.
  1. Apr 22, 2021 at 10:42 AM
    GeoW
    GeoW [OP] New Member
    Geo
    2016 Toyota 4Runner Trail
    Hi all,
    Who makes an aftermarket skid plate that will bolt on my 2016 4runner that has the cut out for access to the oil filter canister?
    I am planning on purchasing an adaptor to use an older spin on filter. I would like to change oil and not have to completely remove the front skid plate, just remove a small plate covering the filter.
    Anyone have an aftermarket front skid plate that can share source? Want one to just bolt on to replace factory plate and don't want to buy all three plates, just the front.
    Reason I need this is I am no longer a spring chicken and a disabled vet... I do want to do as much as I am able to maintain my vehicle.
    Thanks for any help!
    George
    DrewMan likes this.
  2. Apr 22, 2021 at 11:03 AM
    Most of the aftermarket skids have access panels for the oil filter. RSG, Victory, CBI, RCI, etc...
    A&P and ruiz4251 like this.
  3. Apr 22, 2021 at 11:12 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    RCI, and it replaces the front 2 skids with a one piece unit. Trapdoor held on by button head bolts covers the filter. Easy peasy.
    Trapdoor visible towards center driver side if you look closely, underneath the "CI" of "RCI". Don't really have a "better" pic from below.
    Roland, QAS, Bodie the Dog and 3 others like this.
  4. Apr 22, 2021 at 11:14 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Well, to be clear, one does not really "remove" the factory plate for an oil change, rather you "swing it down." It's actually quite easy, especially if you've ditched the front bumper lower valence piece (which I believe all aftermarket skids require). That said, if you aren't using a vehicle lift to change the oil, you might not have enough room to fully swing the plate out of the way.
  5. Apr 22, 2021 at 12:18 PM
    GeoW
    Geo
    Thanks all. Looks like the RCI is what I need. Will get one on order!
    George
    DrewMan, Rainier42 and travelinscout like this.
  6. Apr 26, 2021 at 5:45 AM
    tmil0911
    tmil0911 New Member
    Tom
    Pittsburgh, PA
    2016 SR5 Premium
    LED Headlights / Turn signals. Switchback LED Driving lights. Westin LED Bull bar. MESO Customs Dome light. LED Interior lights. MESO Customs Puddle Lights. RAV4 Blind spot mirrors. WESTIN Bull bar, Tyger steps
    I really wish that Toyota had put the oil filter on top of the motor like my FJ had. Simplest oil change ever. 4RUNNER oil change is annoying.
    DRobs, GoSlow, Bear76 and 4 others like this.
  7. Apr 26, 2021 at 6:12 AM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    I recently installed my RCI skid plate and access to the oil drain plug is easy. No need to remove skid plate. RCI makes a a great skid plate.
    QAS, DrewMan, Marchy and 1 other person like this.
  8. Apr 26, 2021 at 6:49 AM
    DaveW
    DaveW New Member
    dave
    2020 Toyota 4Runner TRD Offroad
    Your FJ must have been an early year. My 2011 FJ was almost the identical setup for changing oil as my 2020 4R. Only difference was the FJ did not have the front valence to remove. Otherwise, both had the same two skid plates and identical oil filters.
    A&P and DrewMan like this.
  9. Apr 26, 2021 at 7:11 AM
    I got RCI. It has maintenence cut out. Really easy to install. I see some skids require to remove stock support brackets but not RCI. Simply remove stock and fix RCI.
    https://youtu.be/rzoY7ilUxDQ
  10. Apr 26, 2021 at 1:12 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
  11. Apr 26, 2021 at 1:47 PM
    Rainier42
    Rainier42 New Member
    Johnny
    Bucks County, PA
    2020 Silver 4Runner Venture
    Sliding Cargo Tray, 265/70 R17 Falken WildPeak A/T3W tires, Interior Vled bulbs, LED Fog Lamps off of a 2020 TRD Pro w/Yellow Lamin-x film, Pedal Commander, TRD Pro shift handle, Subaru front tweeters.
    Daytonaviolet[QUOTED] likes this.
  12. Apr 26, 2021 at 1:59 PM
    Daytonaviolet
    Bay Area, CA
    They are non-oem but work well
  13. Apr 26, 2021 at 2:09 PM
    A&P likes this.
  14. May 4, 2021 at 7:44 AM
    tmil0911
    tmil0911 New Member
    Tom
    Pittsburgh, PA
    2016 SR5 Premium
    yes - it was right on top.
    BionicRandy and DrewMan like this.
  15. May 4, 2021 at 8:03 AM
    Daytonaviolet
    Bay Area, CA
    You can purchase type b and cut the side to fit kdss
    DrewMan likes this.
  16. May 4, 2021 at 8:31 AM
    That's true, thanks for pointing that out. I do like that skid plate.
    So I'm guessing the only difference between the two versions is the clearance cutout on the sides...all the mounting locations are the same?
  17. May 4, 2021 at 8:33 AM
    Daytonaviolet
    Bay Area, CA
    yes I believe so as kdss folks cut the oem pro skid plate to fit. This should be same
  18. May 4, 2021 at 9:03 AM
  19. May 4, 2021 at 9:10 AM
    Daytonaviolet
    Bay Area, CA
  20. May 4, 2021 at 9:17 AM
    I hope they did redesign it, it would save some modification work, and make installation a breeze. I also emailed CTH for confirmation.
  21. May 4, 2021 at 9:29 AM
    Daytonaviolet
    Bay Area, CA
    2Toys, Rainier42 and glwood54[QUOTED] like this.
  22. May 4, 2021 at 11:01 AM
    Got one, thanks!!
  23. May 4, 2021 at 11:42 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    The RCI one that I got for my 2016 works perfectly for this reason. Didn't have to remove it at all. A really nice design.
    DrewMan likes this.
  24. May 4, 2021 at 6:21 PM
  25. May 4, 2021 at 6:31 PM
    Daytonaviolet
    Bay Area, CA
    Mine was r&r. But if you have a diff drop, you may need shorter skid plate bolts for the rears.
    glwood54[QUOTED] and DrewMan like this.
  26. May 7, 2021 at 7:52 AM
    tmil0911
    tmil0911 New Member
    Tom
    Pittsburgh, PA
    2016 SR5 Premium
    So that gets you access directly to filter housing?
  27. May 7, 2021 at 8:56 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
  28. May 7, 2021 at 9:42 AM
    If you mean how long does the shipping take - I ordered mine Tuesday 5/4 and got notified of UPS shipping and tracking number this morning. I expect to see this mid next week, I suppose. @Daytonaviolet mentioned these are probably stocked stateside, and it seems he was correct.
  29. May 7, 2021 at 10:46 AM
    edgesalon
    Te
    18 FunRunner :-)
    thank you please post pics after the install i am very interested special due to having access to oil filter
  30. May 7, 2021 at 2:37 PM
    TrailGuy2016
    Yep! Remove the Allen screws, take the plate off, and as they say in Canada, Bob's your uncle. Easy.
    tmil0911[QUOTED] likes this.
