Need Help with Intermittent Misfire Issues P030X on 2010 4unner and P0351-P0356
Discussion in '5th Gen 4Runners (2010-2024)' started by WellDunn281, Jun 21, 2024.
  1. Jun 21, 2024 at 7:00 AM
    WellDunn281
    WellDunn281 [OP] New Member
    Houston Texas
    2010 white 4runner limited 2WD
    No specific or performance enhancing modification
    Hi everyone,
    I'm reaching out for some advice. I’ve been having ongoing issues with my 2010 4Runner Limited 2WD (258,xxx miles). For the past couple of months, I've been dealing with intermittent random multiple misfires (P0300-P0306) and ignition coil primary control circuit open codes (P0351-P0356). It was running fine for a while, but now it’s almost completely inoperable.
    Here’s what I’ve done so far:
    • Replaced the MAF sensor
    • Cleaned the throttle body and air filter system
    • Replaced coil packs with TRQ in 2022, along with new spark plugs
    After experiencing these issues, I took it to a local shop that specializes in imports. They suggested the aftermarket coil packs might be the problem and recommended switching to OEM Denso coil packs. The shop replaced two of the aftermarket coils with used Toyota-specific ones to test this theory. The vehicle seemed to run better, so I replaced the remaining four with new OEM Denso coil packs.
    Initially, the 4Runner ran fine for about 150 miles, but then I felt a misfire again, and the check engine and traction control lights came back on. This time, I got 13 codes indicating random multiple misfires and all coil packs open. I replaced the two used coils with new Denso ones, but now the 4Runner struggles to stay running. It idles roughly and dies when put in gear or just sitting idle.
    I suspect the ECM might be the issue. I’ve checked all connections and inspected for water damage, but everything looks fine. I know testing the ECM is difficult without the right tools.
    I'm at my wit's end. I called the shop again, but they are stumped and don’t know how to tackle this problem. They have more resources than I do, but I'm getting increasingly frustrated.
    Has anyone experienced something similar or have any suggestions on what I could try next? Any advice would be greatly appreciated.
    Thanks in advance!
  2. Jun 21, 2024 at 8:16 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    Have you checked crankshaft position sensor? Seems like a candidate. After checking that, I'd look into compression on each cylinder. After that I would check for timing issues (chain is stretched and/or jumped a notch).
