Need help to pass smog
Discussion in '2nd Gen 4Runners (1990-1995)' started by marucus, Aug 29, 2023.
  1. Aug 29, 2023 at 4:41 PM
    marucus
    marucus [OP] New Member
    Head gasket was done 1k miles ago and the TB, WP with new spark plugs and wires. Ask the pvc is change out. What is missing to get pass the smog?
    Some friend recommend put a new catalytic converter. I have no idea how long ago is the cats being change out
    NO CEL
    Thanks
  2. Aug 29, 2023 at 4:41 PM
    marucus
    This rig has 144k miles and it is 4x4 auto
  3. Aug 29, 2023 at 4:51 PM
    steelevo
    Utah
    Are you getting the tailpipe sniff test? Sometimes, if the cats aren't hot enough, they will output higher emissions than when at operating temperature.
    Mojave likes this.
  4. Aug 29, 2023 at 7:12 PM
    Mojave
    Mojave New Member
    zeak
    az
    5Th Gen 4Runner trd off Road
    take it out on hwy 70mph for 20 miles than go do test.
    steelevo and 2Toys like this.
  5. Aug 29, 2023 at 8:52 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    ^^^ This. Get the CATS good and hot. Take some off ramps and get back on the freeway using wide open throttle several times.
    Mojave and steelevo like this.
  6. Aug 31, 2023 at 12:29 PM
    if you have an infrared thermometer, once you have the cats "hot" you can check the temperature before the cat and then after the cat and compare. A cat should output hotter gases than it takes in. If the temperature is nearly the same...then the cat is definitely bad.
