Need help ignition 2nd gen
Discussion in '2nd Gen 4Runners (1990-1995)' started by 34bluemoon, Apr 19, 2021.
  1. Apr 19, 2021 at 8:58 AM
    34bluemoon
    34bluemoon [OP] New Member
    Reese
    1993 blue 4Runner
    Went to start my 93 runner this morning cranked over for a second then lost all resistance in the key so now just flips back and forth after the ACC with no crank but battery still putting in power turns lights on tried to get a jump too also put in a new lock cylinder but still does same thing?? Anyone have a clue what’s going on also thinking it could be the ignition inter motor too lmk what you think?
  2. Apr 19, 2021 at 10:42 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Sounds like you need a new starter motor.
  3. Apr 19, 2021 at 11:49 AM
    34bluemoon
    Reese
    1993 blue 4Runner
    Car turns on fine with screw driver
  4. Apr 19, 2021 at 7:04 PM
    ZARTT
    ZARTT New Member
    Art
    1995 4Runner, Black,Tan Interior, 5spd.,(convert from A340) 207,000 mi., on its 3rd 3VZE.
    Ford Taurus 2 spd. elec. cooling fan, GM CS-144 alternator upgrade. Intimidator AGM battery.
    Hi:
    Do you mean that the key switch has lost the spring back ability that happens when you turn it to the crank the motor position?
    If so, there is a removable electric switch on the rear of the key assembly.
    That is where the "spring back" function lives.
    You can change out that switch, and still keep the same ignition key.
    What is an ignition inter motor too lmk?
    Good Luck
    Art.
    Moon Landing likes this.
  5. Apr 20, 2021 at 9:20 PM
    mjamgb
    mjamgb New Member
    mike
    Son's Gen2
    None yet
    And use some punctuation, too, eh?
    LOL
