*Need Help* Head Unit Not Loading
Discussion in '5th Gen 4Runners (2010-2024)' started by bradyv, Jun 30, 2024.
  1. Jun 30, 2024 at 10:46 AM
    bradyv
    bradyv [OP] New Member
    Brady
    Iowa
  2. Jun 30, 2024 at 10:51 AM
    bradyv
    Brady
    Iowa
    Disconnected the battery, didn’t work. Checked the amp fuse, all good there. What’s next?
  3. Jun 30, 2024 at 12:20 PM
    Upload the video to YouTube and post the link or embed it into the post. When we click on the link to your Google drive, it's marked as private.
  4. Jun 30, 2024 at 12:26 PM
    bradyv
    Brady
    Iowa
    Links updated. Thanks for the heads up!
  5. Jun 30, 2024 at 12:30 PM
    Oh, Apple Car play isn't working. Well, wasn't working.
    Do you still have your phone connected to it? If so, disconnect it. I had a similar problem on my 2021 Tacoma. I disconnected the battery, then pressed the horn for 30 seconds before reconnecting the battery. The problem stopped and it never happened again.
    I have no idea what caused it, but that fixed it, for me.
  6. Jun 30, 2024 at 12:34 PM
    bradyv
    Brady
    Iowa
    I disconnected my phone and AM/FM radio volume isn’t working either. I’ll try the disconnect horn trick and see if it works!
  7. Jun 30, 2024 at 12:45 PM
    bradyv
    Brady
    Iowa
    Tried it and radio still won’t load. Just keeps going through the reset phases.
  8. Jun 30, 2024 at 12:49 PM
    I found this, see if it helps:
  9. Jun 30, 2024 at 1:13 PM
    bradyv
    Brady
    Iowa
    Followed video exactly and still nothing :(
  10. Jun 30, 2024 at 1:15 PM
    That indicates your head unit is dead or dying. I doubt it's under warranty. Start shopping around for a used OEM.
  11. Jun 30, 2024 at 1:19 PM
    bradyv
    Brady
    Iowa
    Bummer. I bought as a CPO and it’s still under the 12 month comprehensive so fingers crossed it’s covered under that. I’ll check with the dealer tomorrow. Thanks for your help. Much appreciated!
  12. Jun 30, 2024 at 1:20 PM
    I found this thread.
    Post #68 is something you may want to try, but if that doesn't solve it, then yeah, you'll def have to toss it into the dealers lap.
  13. Jun 30, 2024 at 1:25 PM
    bradyv
    Brady
    Iowa
    Nice, I’ll give it a shot. Will pull those fuses now and give it until tonight. Thanks again!
  14. Jun 30, 2024 at 6:08 PM
    bradyv
    Brady
    Iowa
    4.5 hours with Rad 1, Rad 2, and Amp fuses removed; no fix. Off to the dealer!
  15. Jun 30, 2024 at 6:15 PM
    Sorry to hear that. I tell ya' what I'm gonna do...
    When I'm driving to work tomorrow and listening to and enjoying my radio, I will think of you!
    bradyv[QUOTED][OP] likes this.
  16. Jun 30, 2024 at 6:16 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    is this a known issue?
    I've never heard this before...but, I am a newby
  17. Jun 30, 2024 at 6:19 PM
    It's not a known issue, and since it's electronic it can go out at anytime. Regardless of age. With mechanical components you can base failure rates from how old the vehicle is or the mileage. I've seen radio's last 40yrs or 40 days.
    However, when the radio is stuck in a restarting cycle, that's a red flag that the head unit is dead.
    Steely123 and T in Texas[QUOTED] like this.
