Need help front end vibration
Discussion in '3rd Gen 4Runners (1996-2002)' started by elguapo4runner, Dec 6, 2020.
  1. Dec 6, 2020 at 7:23 AM
    elguapo4runner
    elguapo4runner [OP] New Member
    Lloyd
    2000 4Runner Limited
    Hey peeps
    Hope everyone had a great thanksgiving.
    Just lifted my 2000 limited which has 300k miles. Also got some 17inch wheels and some Goodyear’s on her.
    At first everything was fine under 50 mph but over had a terrible vibration, then at 60 would go away but back after 63mph
    did two road force balances and now a slight vibration over 70. Also changed out with spare due to problems with balancing on front drivers tire.
    Anything else you guys think I should check???
  2. Dec 6, 2020 at 6:02 PM
    kbp810
    kbp810 rebmem wen
    What tires? Stock wheels or aftermarket?
    if you have an aggressive at or mt tire; a slight vibration at high speeds sometimes is just par for the course.
    Vibes can be tough to track down; but other things that come to mind could be wheel itself, especially if it’s aftermarket and not hub centric; could be rotors (though often you’d feel a shake when braking then too); could be a cv axle starting to go; could be driver side diff needle bearing.
  3. Dec 6, 2020 at 8:36 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    I assume this wasn't an issue before you made the changes but check your lower ball joints, front end vibration is a symptom of them being worn. LBJ failure is a common issue on third gens, and it can cause your wheel to fall off.
  4. Dec 7, 2020 at 5:17 AM
    elguapo4runner
    Lloyd
    Goodyear Wrangler 265/70 R17 with method wheels. Thanks for the help. I’ll look into it.
  5. Dec 7, 2020 at 5:19 AM
    elguapo4runner
    Lloyd
    they don’t look great but had mechanic and place that installed lift take a look and said they are fine. Thinking about just changing the lbj just for piece of mind.thanks for the info
  6. Dec 9, 2020 at 12:11 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    Let me know if this solves your problem - I'm having a similar issue
  7. Dec 9, 2020 at 8:52 PM
    elguapo4runner
    Lloyd
    will do. It’s going to shop tomorrow
  8. Dec 11, 2020 at 10:17 AM
    elguapo4runner
    Lloyd
    Ok here’s an update. Mechanic stated no issues on front suspension. So going to start looking into the lug / hub centric. Didn’t have to issue with factory 16in wheels after lift was installed. However I didn’t drive it at highway speeds since tires were in poor condition.
    Any ideas where to start with the hub / lug centric bs??
    thanks so much for the help, y’all rock
  9. Dec 13, 2020 at 5:35 AM
    Toyotafvr
    Toyotafvr New Member
    Joe
    They make a ring that can be added to make it a hub centric wheel or I would starte by searching for wheels styles that you like and check if they are a 106mm hub bore . I believe the hubs are the same on the 4runners as the Tacomas . I had the same issues with after market wheels on my Tacomas in the past and the I hard that Toyota trucks use hub centric wheels. Hope this helps !
  10. Dec 13, 2020 at 7:28 AM
    elguapo4runner
    Lloyd
    from what I’ve seen so far is the method 703-704 wheels I have are 106.25mm. Will the .25mm be an issue?
    the quick looking around on internet found some rings that are around $12.00 each, any suggestions on which ones are better?
    I appreciate the help
  11. Dec 13, 2020 at 9:24 AM
    Toyotafvr
    Joe
    The .25mm shouldn't make that much if any difference in my opinion. It really isn't much. My after market wheels are 106.2 as for the rings . I cannot commit due to I have never ran rings . Maybe some one that has any knowledge with them can chime in .
  12. Dec 13, 2020 at 5:32 PM
    elguapo4runner
    Lloyd
    I appreciate it.
  13. Dec 19, 2020 at 4:13 AM
    Toyotafvr
    Joe
    Not a problem buddy! Aways happy to help!
  14. Jan 8, 2021 at 7:15 PM
    Silliw98
    Silliw98 New Member
    Willis
    98 white 4runner 4WD
  15. Jan 8, 2021 at 7:16 PM
    Silliw98
    Silliw98 New Member
    Willis
    Rotors maybe.. If its an automatic are the auto front hubs un locking? Good luck sounds like s nice truck..
  16. Jan 8, 2021 at 9:38 PM
    elguapo4runner
    Lloyd
    I’ll definitely check into the hubs. I doesn’t feel like they are locked. Been running it around. Just a light vibration at around 70.
  17. Jan 9, 2021 at 4:17 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    So it did not have any vibes before wheels and tires from what it seems like your saying. Obviously, it’s either the wheels or tires. I would only run hub centric wheels. I have owned many Toyota trucks over the years and the only time I had a vibe was when I tried to run lug centric wheels. Lesson learned.
    oh, another time I had vibes was when discount let a new guy balance my tires and he screwed up. Took it back and rebalanced, vibes gone.
  18. Jan 9, 2021 at 5:02 AM
    Toyotafvr
    Joe
    X 2 ^^. Over the years I have found the same to be true!
  19. Jan 16, 2021 at 12:48 AM
    Ambush
    Ambush New Member
    AJ
    99 Black Limited (Kitt) 99 Tan limited (Desert Storm) 2001 Silver SR5 (Silver Surfer)
    Hello everyone
    I am your 3rd gen genie. Your issue is not your rotors as you did not state it vibrates when you brake. It is not the tires as they have been road force balanced. Your issue that EVERYONE has or will experience is the draftshaft is out of balance. TADA! How do I know? 2 of my 3rd gens experienced the same. You have a few choices: 1. Take your truck to a driveline shop that deals with driveshafts (18 wheelers or something like that), 2. Order and aftermarket one (example: https://driveshaftstore.com/Toyota-4Runner-Driveshaft-1999) DO NOT GET RIPPED OFF FROM THE STEALERSHIP! 3. Last but not least, go to a junk yard and snatch one off of one!! just change the ujoints on it if they have not been changed. You want ZIRC fittings anyways.
    Yes I accept cash only. No bitcoin at this time :) LOL!!!
    Let me know your results.
    -Ambush
  20. Jan 16, 2021 at 10:37 PM
    treyus30
    treyus30 New Member
    Trey
    Your driveshaft doesn't just one day get out of balance unless you smack it on something and dent it...
  21. Jan 16, 2021 at 11:17 PM
    Ambush
    Ambush New Member
    AJ
    Unfortunately our 3rd gens do suffer it. Why? There is a unserviceable rubber gasket that is at the head/front and it warps the driveshaft. Trust. Take a look at some overpriced driveshafts. That new driveshaft is welded instead of open with that silly open gasket area. I have been through this. Trust me.
    See pictures for reference - Aftermarket left OEM right
  22. Jul 19, 2021 at 7:03 PM
    Nic_04
    Nic_04 New Member
    2002 Limited 4Runner 2WD & 2002 Limited 4Runner 4WD
    What aftermarket brand/company did you purchase the left one from?
  23. Jul 21, 2021 at 9:46 PM
    Trekker
    1997 3rz 5spd
    The last owner of my 4runner was diligent about greasing the zerks on the drive shaft. Haven't had any issues with play,
  24. Sep 4, 2021 at 7:06 AM
    elguapo4runner
    Lloyd
    Ambush
    thanks I will be definitely looking in to this. Just got her running again after new alternator, plugs, wires, coils, and injectors. So now it’s vibrating at highway speeds once again. Work always gets in the way!
