Need advice on tire sizing for new wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by MPH034, Jul 5, 2021.
  1. Jul 5, 2021 at 6:54 PM
    MPH034
    MPH034 [OP] New Member
    Max
    Florida
    2014 White 4Runner
    Hey y’all! So I just order some aftermarket wheels with a -12 offset and I’m about to be running a 2in(front) 1in(rear) leveling kit and I wanted to ask if I could run 285/70/17 pretty easily with minor rubbing.
    GrantA likes this.
  2. Jul 5, 2021 at 6:59 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I have 2.5 inches and I am running 285/75/17
    There is some rubbing but honestly I love the look and the little extra capability off-road. I personally think a 285/70/17 would be a great fit with that lift as I hear a lot of people running it. You might need some extra caster but honestly idk.
    0B2FFBD8-684C-4FA9-B2D6-E42F6AF8D371.jpg 5213F8A4-D74F-4945-A5D0-ED27EA67ECFD.jpg
  3. Jul 5, 2021 at 7:03 PM
    MPH034
    Max
    Florida
    2014 White 4Runner
    Yeah absolutely love your car! And yes I’ve been researching for weeks and have found that just wanted to be validated by fellow 4Runner owners so I can make a full decision. I appreciate it!
    GrantA[QUOTED] likes this.
  4. Jul 5, 2021 at 7:23 PM
    After your lift is installed, have a good alignment shop max out your caster as much as possible while keeping camber and toe in spec. This will be your best chance at minimal rubbing. Even at stock height, some have been able to run 285's with proper alignment.
    Even with that, due to the -12 offset, you might to modify or remove the mudflaps, and inner fender liners. These are easy to do. There are write-ups about the fender liner mod around here somewhere.
    285's look perfect on a 4runner with a mild lift. I'm at 2.4/1.5" and 295/70/17's are good. They're really pushing the limit on stock gearing, though. I had 285/70/17's before and rarely noticed the difference from stock size in normal driving.
  5. Jul 5, 2021 at 7:29 PM
    GrantA
    North Carolina
    ^^^ what @Thatbassguy said… Forgot to add… here is what a -12mm and 285 will look like…
    9038C827-A689-448E-8495-517C925172B1.jpg 107C6003-50FF-4DB0-9002-B02E42DD500D.jpg 2928914F-89DB-4D5A-BE7A-C046F6CDD7B2.jpg
  6. Jul 10, 2021 at 1:32 AM
    Fishbum
    Fishbum New Member
    So what's a consensus on going 2 - 2.5 front and 1-in rear and whether or not I will need uca? This will be a daily driver so I want to make sure nothing gets half-assed as far as alignment
  7. Jul 10, 2021 at 3:02 AM
    GrantA
    North Carolina
    Well…. It really depends on what your need is… I don’t like reverse rakes when towing something. I want my front-end planted on the ground. But if you see yourself never towing anything moderately heavy or putting anything in the bak of the 4runner that has a little weight to it then that should bring you to about level.
  8. Jul 10, 2021 at 10:55 AM
    Fishbum
    Fishbum New Member
    Yeah sorry that kind of reads Goofy I meant a 2 inch lift in the front and a 1 inch lift in the rear. That should still leave me with some amount of rake so that if the back has weight in it then it sits level. But I'm more curious whether I can get a proper alignment without ucas with 2-2 and 1/2 in the front
  9. Jul 13, 2021 at 4:53 AM
    It seems like somewhere between 2.5 - 3" is where the factory UCA's run out of adjustment. I've never heard anyone needing them at less than about 3". I would just do the lift and get the alignment done and see where they end up. It's likely that it will be just fine.
    Mtbpsych likes this.
