Need 4 color wire diagram for #6 cylinder on 2020
Discussion in '5th Gen 4Runners (2010-2024)' started by Dwdeshler, Nov 26, 2023.
  1. Nov 26, 2023 at 12:24 AM
    Dwdeshler
    Dwdeshler [OP] New Member
    I tore off two plugs while doing a head gasket job. I need to know what order the wires go on #6 cylinder coil. Wht blu grn blk. Also cam pos sensor nearest to #6 cylinder. Thank you
  2. Nov 26, 2023 at 6:50 AM
    Head gasket needed on a 2020?
    LCJ77, Rocko9999, PVT Pablo and 2 others like this.
  3. Nov 26, 2023 at 7:47 AM
    Oakboro, N.C
    Found this based off 2010 model year. Not 1000% about any changes between this and what you are on. May get you pointed in the right direction if you compare to another cylinders wiring based off of what is on the pdf.
    Bob likes this.
  4. Nov 26, 2023 at 9:59 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    For real! We need the back story on this. This would likely still be under warranty unless it has a ton of miles on it.
    LCJ77 likes this.
  5. Nov 26, 2023 at 11:18 AM
    Dwdeshler
    Yes. I hit a metal folding chair on the 5fwy. The kind with canvas and 1/2 in aluminum poles. It circled around and punctured my radiator. A 1 in 1000 chance. I lost water and over heated I pulled over. Had my 4runner towed 40 miles home did a compression check and had low compression in #4 cilinder had a warped head did complete head gasket job myself except for a machine shop r,resurfacing. It runs but very poorly. Now I've tested all 4 cam shaft sensor plugs and have no power to any of them. I'm stumped
  6. Nov 26, 2023 at 11:24 AM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Brother, I am so sorry to hear this happened. Sounds like maybe some hidden wire bundle damage, maybe from underneath?
  7. Nov 26, 2023 at 12:26 PM
    Dwdeshler
    I also tried to pay 20$ to download a PDF file from a Toyota service manual website. My credit card went through I got confirmation. But I can't access the site. Toyota seems to change the 4 wires going into each sparkplug every single t
    Year never the sam
  8. Nov 26, 2023 at 12:47 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Sorry to hear about your misfortune. Have you checked all of your fuses? If those wires touched when the plugs pulled apart, one of them may have blown.
  9. Nov 26, 2023 at 1:26 PM
    Oakboro, N.C
    Did any of the wire colors interchange with the 2010 diagram posted above, Just acting for knowing in the future?
    CygnusX-4 likes this.
  10. Nov 27, 2023 at 8:20 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Why not file insurance claim?
    MeefZah likes this.
  11. Nov 27, 2023 at 11:08 AM
    Dwdeshler
    52k miles and 32 fault codes. Does anyone know what could keep all 4 cam shaft position sensors from receiving power to the plugs. I have even used a plug that I stripped the wires from and tested all 4 of them.with a volt meter. With ignition on. I test battery got 13.2 volts. I test cam pos sensor. No power to any of the 4. Why is this. I'm going crazy. I just spent 50 hrs of time doing head gasket job. Now it runs poorly because all 4 cam sensors are not getting juice
  12. Nov 27, 2023 at 11:13 AM
    Dwdeshler
    Toyota changes the wire colors every year to the 4 cam sensors the same with spark plugs 36 wires in all just from the entent
    Two and there always diffrent from year to year
  13. Nov 27, 2023 at 11:14 AM
    Dwdeshler
    If anyone knows why I would have no power to all four cam position sensor plugs. Please let me know.
  14. Nov 27, 2023 at 11:30 AM
    hvac guy
    hvac guy New Member
    I'm not a mechanic, but would they get power while starting ?
  15. Nov 27, 2023 at 5:43 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    @Dwdeshler, here you go. This should be all the ignition coil assemblies, VVTI sensors for intake and exhaust, and the Oil control valves for the Cam timing. Compare your wiring to this diagram, as it is specific for the 2020MY. Let us know on here if this get's you sorted out. Sorry to hear about the overheat and subsequent hassle!
    EDIT: Also, here are the connector drawings so you know what you are looking for; Connectors B1-B52
    LCJ77, MeefZah and 2Toys like this.
