My name is Tyler and I own a 2021 4runner limited..and I have questions..lol
Discussion in '5th Gen 4Runners (2010-2024)' started by Tygger31, May 5, 2024.
  1. May 5, 2024 at 6:14 PM
    Tygger31
    Tygger31 [OP] New Member
    Just installed a 3-2 leveling kit and upgraded my tires to 275/60/20. My X-treas system now has my ride bouncing like a bouncy house...New shocks?? or new coils or both??
    CC-2224 likes this.
  2. May 5, 2024 at 6:25 PM
    I have a question too. Why did you install a leveling kit? The rake is there for a reason.
    Marchy and catbrown357 like this.
  3. May 5, 2024 at 6:27 PM
    What kind of lift did you get?
  4. May 5, 2024 at 6:33 PM
    Ya but it doesn’t look as cool lol. Raising the front one inch usually doesn’t put you totally flat anyway. Bigger question is if the “leveling kit” (it’s actually a substantial lift) was accomplished by spacers, or with new shocks and coils.
    If it’s shocks and coils, then the OP doesn’t need to worry xreas anymore.
    Harringbr99 likes this.
  5. May 5, 2024 at 6:48 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Can you just throw spacers on the Xreas for that kind of lift without ripping it out?
  6. May 5, 2024 at 6:54 PM
    I didn’t think so, but I’m not sure if maybe they sell xreas specific spacers.
    The OP’s post says the “xreas system is bouncy.” The only way that she has xreas system anymore is if spacers were used, otherwise, it’s long gone.
  7. May 5, 2024 at 7:34 PM
    Tygger31
    I installed spacers..had a 2-1 leving kit and had no problems..just went to a 3-2 spacers and that's when it started..I am removing the 3-2 spacers and going back to the 2/1..
    TimGinCentralNJ and McSpazatron like this.
  8. May 6, 2024 at 4:55 AM
    welcome
  9. May 6, 2024 at 7:32 AM
    Agent_Outside
    Built 2011 T4R Limited
    You can definitely put a spacer on top of the strut mounts without opening the system.
    If it’s really bouncy I’m wondering if someone messed up and did open the system to install spacer - that would make the dampeners useless while their entire purpose it dampen and control spring oscillations.
  10. May 6, 2024 at 9:34 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I replaced my coils, struts and got the nice firm but controlled rebound and the suspension feels like it's working together now. Definitely rides and drives better. Handles great. I tried factory springs first but to much bounce
  11. May 6, 2024 at 9:36 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    They mount the same. I like my 5100s better. Much
  12. May 6, 2024 at 9:41 AM
    Sounds like the best bet. At a certain lift height the ride characteristics can start to get harsher simply due to geometry, or maybe even harshness from reaching full extension on normal bumps. Hopefully, that’s the only issue.
  13. May 6, 2024 at 9:46 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I set my struts at highest level front with OME 2883s and 2" lift springs in rear. I don't have a lot of extension. I didn't want to harsh or heavy of spring. I like controlled rebounds and chaos rather than jarring fillings loose.
  14. May 7, 2024 at 4:56 AM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Hoping this corrects it for you. If it does, I'd be curious to hear more about the kit/spacers you installed for your X-REAS system. This was actually the solution that several other Limited owners here have recommended...at least until X-REAS begins to leak, but I also understand some kits add the spacer above the shock, and others below. Anyway, fingers crossed this does it for you.
    Oh...and welcome to the board
    TimG
    CC-2224 likes this.
  15. May 7, 2024 at 7:46 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    By adding the spacers you removed some of the travel in the spring or shock which stiffened your suspension.
  16. May 7, 2024 at 8:20 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I used OME 2883s springs up to 3" lift specs it said. My Xreas leaked a long time and still worked, it just got clunky in cold weather and doesn't ride well. I think it finally got low on hydraulic oil. I initially set 5100s at 2nd height setting which says 0.5" and achieved about 2" lift with the 5100s. Then I tried the lowest setting about 1". I then went to top setting which is supposed to be 2" raise on the strut. I received 4+" then measuring at fender opening. I didn't like rear Xreas spring response or ride and used 2" lift springs in rear. I'm around 4" lift all around now. The springs feel like they are working together as one on bumps, bounces and rebound. Drives like a 4wd more to me. I really didn't know what I was going to like or end up with using bits and pieces. 3rd setting is supposed to be 1" lift on
    5100s. Even though I got really good dropping and resetting struts, I got tired and I liked the way it rides and drives. It drives as good as Xreas but I know it will flip now. Calms me driving. I read and researched to learn what I could. Experience is the best lesson and I was able to learn something about it. I did not use any spacers. Energy isolators in rear springs 0.5". Probably need to add to rear height total. Starting to settle and respond better. 1st picture is 2nd setting. 2nd picture top strut setting. That's my experience whether right or wrong.
  17. May 7, 2024 at 8:29 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I replaced UCAs with Freedom ORs. I like polyurethane durability but I read a lot about the squeaky and I have never worn or beat out any bushings. I will eventually replace the LCAs and have all greasable ball joints and tie rods.
  18. May 7, 2024 at 4:16 PM
    david9962000
    david9962000 New Member
    Los Angeles, CA
    What is the reason for the rake? Thank you
  19. May 7, 2024 at 4:58 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    When you load up the back with heave stuff or hook up a trailer, the back end will sag down. The rake is so the headlights (and the driver) aren't pointed up in the air when that happens. If you go completely level and then load it down you will blind other drivers
    david9962000[QUOTED] likes this.
  20. May 8, 2024 at 5:03 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    So it's level when you have 7 people and a load. Mostly Limited 3rd row have the rake from what I have noticed. I don't haul any people, just some gear.
