My 5vz burns oil.
Discussion in '3rd Gen 4Runners (1996-2002)' started by Bjorn722, Aug 31, 2024.
  1. Aug 31, 2024 at 6:30 AM
    Bjorn722
    Bjorn722 [OP] New Member
    Bjorn
    2000 Silver 4Runner Limited V6
    Hi! I just purchased a 2000 4Runner limited with the rear locker and I’m super happy with it. I knew it burned a little oil before I bought it but I got a great deal. I was wondering what the most likely culprit is for a 5vz that burns oil? Thanks for any help!
  2. Aug 31, 2024 at 8:01 AM
    that'smy4runner
    that'smy4runner New Member
    If I tell you, it might not seem like such a great deal.
  3. Aug 31, 2024 at 1:33 PM
    fox744
    fox744 New Member
    how many miles is on the car? most likely are rings and piston on hi mileage cars or if your are lucky valve seals, any smoke at exhaust?
  4. Sep 1, 2024 at 5:48 AM
    Bjorn722
    Bjorn
    It has 305k miles, but no smoke at exhaust and it runs great.
  5. Sep 1, 2024 at 8:36 AM
    fox744
    fox744 New Member
    The other possibilities are leaks from front oil or cam shaft seals or valve cover. when the engine is warm put a cardboard under the engine check for oil drips. you did not mention how much oil you are losing.
  6. Sep 1, 2024 at 9:53 AM
    Bjorn722
    Bjorn
    Sorry I should’ve mentioned, it’s not much oil at all.
  7. Sep 1, 2024 at 9:53 AM
    Bjorn722
    Bjorn
    I definetely will try out that cardboard trick, thank you!
  8. Sep 1, 2024 at 10:42 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    How much oil is not much oil at all? How many miles between oil changes?
  9. Sep 2, 2024 at 7:46 PM
    The 5vz does NOT burn oil.
    You probably have a rear main seal or a valve cover leak which is super super common.
    Regardless, if you can't find external leaks, do a (dry and wet) compression and leak down test for all the cylinders. of the engine.
