My 2023 TRD ORP 4Runner build
Discussion in 'New Member Introductions' started by Netloop, Aug 13, 2023.
  1. Aug 13, 2023 at 8:28 PM
    Netloop
    Netloop [OP] New Member
    ‘23 trd or pre
    Kings w/adj, ome 2” rear, kdss spacer, botck, slim bumper
    Got my 4r about 3 months ago. Here is what I’ve done so far.
    1-kings with adjusters front and rear. 3.4/2”. 550# front/ome 2895.
    2-drkdss botck
    3-drkdss spacers front and back
    4-kdss switch
    5 -285/70/17 aftmkt rims -12
    6-viper cut
    7-eBay slimline front winch bumper
    8-Amazon seat covers fit well
    9-5%tint all around with visor
    10- dashcam with mirror usb
    11-rear Molle panels w/gear
    12-emblem blackout kit
    13-Mictuning switch panel
    14-ditch lights
    15-rock lights 10
    Thats about it for now.
    I’m wondering about setting on the kings adjuster. They were at 0. But shop moved them to 13 or half. Idk. What should I run them at on road and off-road.
    I’m also wondering about bumpstops. Shop says I don’t need them. But I would what to wreck my shock. I have 3+in front and 2 in back. Any recommendations?
    I’ll post more pick tomorrow
  2. Aug 13, 2023 at 9:35 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Nice!
  3. Aug 13, 2023 at 9:45 PM
    steelevo
    Utah
  4. Aug 14, 2023 at 3:28 AM
    Welcome from Wisconsin! Very nice ride.
  5. Aug 14, 2023 at 3:43 AM
  6. Aug 14, 2023 at 5:43 AM
  7. Aug 14, 2023 at 6:23 AM
    HuskerRunner
    O,NE
    2023 SR5P
    How did you know what tires would fit without asking here??
    Welcome!
    RumHamRunner73 likes this.
  8. Aug 14, 2023 at 8:25 AM
    Oakboro, N.C
    Welcome to the forum. Liking that turf!
  9. Aug 14, 2023 at 8:41 AM
    Netloop
    ‘23 trd or pre
    Wow! thank you everyone for the welcome. I’ve been looking on here for a while. Lots of nice 4Runners and info. Hope to add to the community.
  10. Aug 14, 2023 at 9:46 AM
    Branden967
    Branden967 New Member
    6400' in CA
    2023 TRDOR Premium
    Kings Suspension SCS 17X9 -10 OS Ridge Grapplers If its chrome....black it out.
    Nice setup, Im running almost exact same setup. Except I went a tad heaver duty springs on the rear, which Im not sure if I like yet... My rear's a tad high right now.
    If you wouldn't mind, would you take axel center to fender top measurements front and back? Im curious how yours sits as I think I want to crank my front up higher.
    Thanks-
  11. Aug 14, 2023 at 10:08 AM
    Netloop
    ‘23 trd or pre
    Front measures 23 1/2” both sides
    Rear measures 24 3/4 driver-23 7/8” passenger kdss lean
    Shop wanted me to go 2.7” in front during break in. Idk. After 500 miles they went up to 3.4 I believe. I got 1 3/8” more in front. And they added 2” ome spring in back which really only added 1/2” in back from the spacer. But it drive better with the added height. During the break in I moved my pedal commander up. After breakin moved it back down. Then I added the kdss spacer and tracbar kit. That really helped on freeway doesn’t feel as tippy.
    Happy trails
    djwantke likes this.
  12. Aug 14, 2023 at 10:23 AM
    Netloop
    ‘23 trd or pre
    Didn’t know. I wanted 33x12.50x17. But shop said it was too much. Go for the 285/70/17. Found them on OfferUp. Fresh off a gladiator. With 500 miles. $600. Rims are aftermarket. No brand. $650. All in. 4 rims and tires and used spare. 1400 installed. I want some 24” to roll around the city but I have to pay bills off regroup and see where the funds are. Take care thanks for the comments. Peace
    HuskerRunner[QUOTED] likes this.
  13. Aug 14, 2023 at 10:31 AM
    Netloop
    ‘23 trd or pre
    I want to post a few more pic of what I’ve done. Rear Molle panel. Behind seat Molle and a grab handle. Rear window trim led brake light. I really like all the photos. Every bit counts make it yours.
  14. Aug 14, 2023 at 11:39 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Great work my friend, clicking 'watch thread' for sure
    Netloop[OP] likes this.
  15. Aug 14, 2023 at 11:41 AM
    DesertSurfer
    Wow, all I can say is that your rig is off the hook, totally cool, I’m super jealous. Owned my ORP a month and just got it tinted so far. All top cabin upgrades, that’s for sure. So…..keep it going and Welcome from San Diego!
  16. Aug 14, 2023 at 12:38 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    For bump stops, wheelers offroad superbumps are nice but kinda expensive for what the are, or energy suspension makes some for less then 1/2 the price
  17. Aug 14, 2023 at 12:49 PM
    Netloop
    ‘23 trd or pre
    Ok. I’ll check them out. I was looking at sumosprings. Shop says I don’t need them. But from what I’ve read they help save the shock. They think it’s a pavement princess. But it’s new and I want it ready to battle not break. Give me time I’ll test it. Again thanks for ur input. Happy trails
  18. Aug 14, 2023 at 12:52 PM
    Netloop
    ‘23 trd or pre
    Well I have some extra money. Always work in ur budget. And I try to a good deal. Hi Neighbor from ElCajon
  19. Aug 14, 2023 at 12:54 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I've heard mixed reviews with sumo springs, durobumps are another popular option.
    https://www.amazon.com/Energy-Suspension-89104G-Bumper-Stop/dp/B01E1SUO2A?crid=1X5D0GF1PQGBN&keywords=4runner+bump+stop&qid=1692042792&sprefix=4runner+bump+st%2Caps%2C129&sr=8-3
    I know members on here used these for the front atleast
  20. Aug 14, 2023 at 1:37 PM
    Netloop
    ‘23 trd or pre
  21. Aug 14, 2023 at 8:22 PM
    HuskerRunner
    O,NE
    2023 SR5P
    All good, my guy. The longer you're here the more you'll see the question asked. You came in the door with a great looking build. I should have just said that.
    Netloop[QUOTED][OP] likes this.
  22. Aug 15, 2023 at 6:56 PM
    RetiredTRDowner
    RetiredTRDowner 2022 TRD Off-road Premium
    Fain
    Bella Vista, Arkansas
    Tint windows, replaced valences (black), 3x2 READYLIFT, Black Rhino Abrams (olive green) wheels, 185/70/17 Falken Wildpeak AT3 tires, AMP Power Running Board
    Good looking ride!
    Welcome from Arkansas!
    GO HOGS!
  23. Aug 18, 2023 at 10:57 AM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    Welcome from the center of the bourbon universe.
  24. Aug 22, 2023 at 6:08 PM
    Netloop
    ‘23 trd or pre
    Hi Everyone. I installed the bump stops. Shop didn’t like it. acted like I was limited up travel or something. Idk. But Don’t want to blow out my shocks. He mentioned them at first but later said I didn’t need the extended bumpstops. What do you think. Did I need extended bump stops. Or did I limit my travel. Thx
  25. Aug 22, 2023 at 6:15 PM
    Netloop
    ‘23 trd or pre
    Okay here’s another one. I got some previously mounted rock sliders. They are painted black. I want to raptor coat them. Is it really rough on feet. Scrapes and cuts. Any ideas , comments, advise.
    Also thinking of raptor painting them white. Just to be different. Look like snow. Idk. Or just black.
  26. Aug 22, 2023 at 6:57 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You bought the energy suspension ones? Only way to find out is to test them out
  27. Aug 24, 2023 at 3:26 PM
    Netloop
    ‘23 trd or pre
    Any guess what did this. Took it to my show. They blamed me. I haven’t been in anything. And I would have known. The shop have just fixed a safety wire on a ball joint boot same side. Said they seen it but didn’t say anything. BS. No other damage scratches in area. What you think shop full of it. Covering their own. Or does this happen often. Or am I being paranoid. There is no contact. Uca has a spot of paint. Scratches line up with the wire they replaced. I’m going to let it go. But I hate liars. I painted it already. Walmart krylon. Patriot blue. Peace
  28. Aug 24, 2023 at 6:08 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    So the uca are hitting the coilovers?
  29. Aug 24, 2023 at 6:15 PM
    Netloop
    ‘23 trd or pre
    Shop says no. And I don’t hear any noises. There was only one spot of paint on uca. And shop worked on it 2 days before I noticed it. Didn’t check after shop. It’s scraped like a sideways motion not up and down.
    Idk. Just venting. It’s painted. I’ll watch if it’s hitting. Sloppy mechanic. Thx
  30. Aug 30, 2023 at 1:34 PM
    Netloop
    ‘23 trd or pre
    I have a couple extra Molle panels for the seat back. They were only 22 for the pair. I want to cut one to make a seat jacker Molle. Things are like 30 each. Anyway it wasn’t long enough. So I slide it under the center console, a little bend and instant Molle panel. Rago wants 250 for their center console Molle. It’s much nicer. But this one stays in place. I’m going to space it and 3m it to center console. What you think 22 or 250. U pick. Peace and keep Running.
