Morimoto XB led headlights fuse help
Discussion in '5th Gen 4Runners (2010-2024)' started by Shane Smithy, Mar 12, 2023.
  1. Mar 12, 2023 at 10:16 AM
    Shane Smithy
    Shane Smithy [OP] New Member
    Alex
    2015 Black 4runner
    I’m currently changing out my stock headlights to the morimoto XB amber headlights. I plugged the fuse Drl harness into the INJ slot under the hood but when I go to start it, it won’t start, all it does is crank but won’t fully start. I’ve plugged the dlr harness into the EFI 2 fuse slot and the headlights come on with the start up sequence and the drls come on but on the dash the TRAC OFF comes on. Where can I plug the Drl harness at without going to the cabin fuse box?
  2. Mar 12, 2023 at 2:04 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    How do you want the DRL's to come on?
    When the key is on? Car is running? DRL lights or Low Beams on?
    Get a multimeter or test light, and see what fuse is powered and tap into that one. I have seen a lot of people running raptor lights and other aux lights using the INJ fuse or any other that powers some sort of "important" system have issues. Thats why I wired mine to the LH-Low fuse. So mine come on when I turn the lights on and no other time...
