Morimoto xb evo headlight review
Discussion in '5th Gen 4Runners (2010-2024)' started by rproc, Nov 16, 2024.
  1. Nov 16, 2024 at 7:33 PM
    rproc
    rproc [OP] New Member
    Richard
    Calgary
    21 Black 4Runner ORP
    Fantastic lights, noticeably brighter then the stock led lights.
    The high beams on these lights are amazing. I didn't go with the supercharged drivers, these lights are bright enough without them.
    My only complaint is the aiming screw is tight, and strips VERY easily. I completely stripped the screw, and had to finish aiming them with a socket.
  2. Nov 16, 2024 at 8:18 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Thacrow and brownersd like this.
  3. Nov 16, 2024 at 8:39 PM
    rproc
    Richard
    Calgary
  4. Nov 17, 2024 at 9:11 AM
    yotahead858
    yotahead858 New Member
    2023 4Runner Limited
    Looks awesome! I have a pair on the way and can't wait to install them!
    rproc[OP] likes this.
  5. Nov 17, 2024 at 1:52 PM
    rproc
    Richard
    Calgary
    Be very careful when aiming them, the screw is made of tin foil and will completely strip. I recommend using a socket instead.
  6. Nov 27, 2024 at 8:08 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    How do you like them? We have the Gen 2 XB's on our 2020 but we just picked up a 2016 with halogens. I don't know if I want Morimotos or OEM leds.
  7. Nov 27, 2024 at 9:18 AM
    rproc
    Richard
    Calgary
    They're good, I really like them.
    If you decide to go OEM, I have a set of OEM LED's from my 21 that I'm selling
  8. Nov 27, 2024 at 9:41 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Can we see a pic of them at night, against a wall?
    Mainly looking for light scatter above the cut-off line.
    Thx
  9. Nov 27, 2024 at 9:51 AM
    rproc
    Richard
    Calgary
    I'm still dialing in the aiming. I'll try and get some night vids later this week
    alittleoff likes this.
  10. Nov 27, 2024 at 11:34 AM
    LA260
    LA260 New Member
  11. Nov 27, 2024 at 12:11 PM
    alittleoff
    Steve
    406
    '16 TP
    Thanks for those pics @LA260.
    There seems to be a little light scattering above the cut-off line that affects oncoming vehicles.
    Which is why I won't be buying aftermarket headlights.
    They just can't seem to get it right no matter how much money one spends.
  12. Nov 27, 2024 at 12:50 PM
    LA260
    LA260 New Member
    Lots of OEM headlights have light scattering on top but it's not strong enough to affect oncoming traffic. It's just to light up reflective signs. For what its worth I haven't been flashed once in the last two months that I've had the Morimotos. Cant say the same for my other cars with OEM headlights. If the headlights are adjusted properly there shouldn't be any issues.
    rproc[OP] and alittleoff[QUOTED] like this.
  13. Nov 27, 2024 at 1:17 PM
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    they look really good. Not ready to get rid of my OEM LEDs yet, but I think that of the aftermarket options, these new headlights are undoubtedly the best. I want to wait a couple of years and see if these "yellow" like the old Morimotos did.
  14. Nov 28, 2024 at 9:22 AM
    yoshi i
    yoshi i New Member
    What you called scattering above the cut-off is regulation required "upper illumination" This is lamp I designed including projector being used inside, allow me to add some explanation, this is rather common confusion among many lighting discussion
    Glare is defined by red box Orange arrow is for 100m road sign illuminator( seen as bit of blue blurred band very slightly above cutoff line, yes this blue shall be very slightly above horizontal line) red arrow is 50m road sign illuminator
    Floating rectangular box is for overhead signs.
    All of above cutoff line illumination except glare box has required minimum value, and maximum allowable value.
    To enhance potency of driver comfort within regulation limit, I set upper illumination capability at upper range.
    This is NOT glare. Most of aftermarket headlamp does not have any consideration to such safety required distribution. Sharp cutoff without upper illumination is the one did not get it right, which is 99% of aftermarket headlamp.
    Very precisely designed in optics for specific roll
    Thank you for aiming lamp correctly. Hope lamp giving you great comfort!
    If anyone has technical questions about optics, reach me out anytime. I want everyone to have full understanding and enjoy lamp to the fullest.
    Sorry about such headache, I will have team review and take action to change material, improve functionality Thank you for feedback
  15. Nov 28, 2024 at 8:40 PM
    alittleoff
    Steve
    406
    '16 TP
    Thank you for that detailed information. I appreciate the effort that you put into this post.
    My '16 with projector technology (factory stock) is what I'm working with.
    My Cibie' Z-Beams in my '03 Jeep are old school tech with H-4's.
  16. Nov 30, 2024 at 7:47 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Looks great! I want to do this but the heating element is holding me off. I don't want to run any fuse taps. I reached out to Morimoto to find out if the heaters need to be wired or if you can leave that part disconnected but no response.
  17. Nov 30, 2024 at 9:19 AM
    yoshi i
    yoshi i New Member
    If disconnected, Welcome sequence/DRL/Heater won't get powered. is yours newer than 2019YM? and concern about fuse box lid won't close with any fuse tap?
  18. Nov 30, 2024 at 9:49 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    That is a bummer. It's a 2023. I'm not concerned with the fuse lid issue. I know I can drill a small hole to run the cord. I'm just not a fan of tapping into anything of significance. If I recall for the Morimoto installation video they say to tap into ING fuse which I'm not a fan of.
  19. Nov 30, 2024 at 10:05 AM
    yoshi i
    yoshi i New Member
    You are fusing downstream to ING line, so ING fuse is natively and independently fused away from XB Evo harness, will not get compromised, that's the point of fuse downstream. For 2023, there won't be enough height for any fuse tap, so lid won't close, can't drill hole on side wall ( unless you try to cutout top) You either not use fuse box lid or get fuse box lid raiser. Fuse junction are external component design, lids are pretty much fuse assignment note pad, I would keep somewhere in vehicle.
